more power
Discussion in '2nd Gen. Tacomas (2005-2015)' started by vtragweed, Oct 16, 2008.
  1. Oct 16, 2008 at 4:54 PM
    vtragweed
    vtragweed [OP] Beef Slut
    Willie
    VA
    08 2.7 SR5 Debadged
    afe pro-dry s filter, LCE headers, painted black steelies,color matched grill surround, URD short shifter, UWS black tool box
    ok so ive done my intake exhaust what else can i do or get more power out of my 2.7 without turbo or s/c
  2. Oct 16, 2008 at 5:25 PM
    allrsdup
    allrsdup Well-Known Member
    Sahuarita AZ.
    2018 dcsb trd offroad 4x4 Inferno
    when i had my 99' taco i had the 2.7 in it and i put a full length header on it. i bought it from downyoffroad. that made a noticeable difference. i only did it because the factory manifold was cracked and the header was cheaper. but i was sure glad i did it after wards. not that hard a job either.
  3. Oct 16, 2008 at 5:25 PM
    Taco's for All
    Taco's for All Well-Known Member
    Lake George, NY
    2019 Tacoma TRD Off Road Double Cab
    Nothing at the moment
    :rofl:Add stickers!!!! 15+ hp each
  4. Oct 16, 2008 at 5:32 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    X2 on the headers.
  5. Oct 16, 2008 at 5:34 PM
    derekabraham
    derekabraham Living vicariously through everybody
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    Stick on hood scoop from Autozone.
    X2 on the stickers.
  6. Oct 16, 2008 at 5:35 PM
    Taco's for All
    Lake George, NY
    On a more serious note, do you have A/C? How much do you enjoy your A/C? When I still had my mustang, I got a new belt to eliminate the A/C compressor pulley and it allowed the motor to free up a little bit. Never did a dyno so I don't really know how much it helped. Also not sure if you can do this with a Tacoma as I usually only see people do this mod to muscle cars.
  7. Oct 16, 2008 at 5:42 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Not a good mod on a TAcoma. Since the AC is clutched, it is really only drawing power when in use. When not in use, the pully freewheels.
  8. Oct 16, 2008 at 5:53 PM
    Taco's for All
    Lake George, NY
    Good to know, learn something new everyday. Thanks
  9. Oct 16, 2008 at 6:41 PM
    vtragweed
    Willie
    VA
    08 2.7 SR5 Debadged
    what do yall think about the maf calibrator
  10. Oct 16, 2008 at 6:48 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    that will probably be one of the biggest power improvements, besides a sc/turbo setup. its a bit expensive, but set up the right way...should be very noticeable. even with the stock map they use........should do well.
  11. Oct 16, 2008 at 7:23 PM
    beastlytaco
    beastlytaco Well-Known Member
    Ian
    08 Access Cab SR5
    yeah MAF calibrator definitley.
  12. Oct 16, 2008 at 7:36 PM
    vtragweed
    Willie
    VA
    08 2.7 SR5 Debadged
    stock map, is there a different map where you can adjust it
  13. Oct 16, 2008 at 7:40 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i think you can get them from urd, and i also think you have to have it hooked to a lap top to adjust everything. im not 100% sure on this, but i believe thats how it works.
  14. Oct 16, 2008 at 7:42 PM
    vtragweed
    Willie
    VA
    08 2.7 SR5 Debadged
    have you done this to yours
  15. Oct 16, 2008 at 7:47 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    nah.....i got an 04......i dont think they have them for the first gen. tacomas, but i dont really need one anyway. about the only thing i ever change performance wise on a car or truck is intake and exhaust. i dont like messing with the electronics too much.:D
  16. Oct 16, 2008 at 7:49 PM
    vtragweed
    Willie
    VA
    08 2.7 SR5 Debadged
    i see, well you wouldnt know how hard it would be to adjust the maf sensor, or would i have to call urd
  17. Oct 16, 2008 at 7:50 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    im pretty sure they send detailed install and adjustment instructions, but they also have their tech help line too incase you run into any problems.
  18. Oct 16, 2008 at 7:55 PM
    mainerinexile
    mainerinexile Well-Known Member
    central Maine
    2014 SR5 Access cab I4 4x4 5 spd
    For 'more power': if you have a cap, take it off; if you don't, take off the tailgate and put on a net. It'll feel like a new truck.
  19. Oct 17, 2008 at 4:06 AM
    beastlytaco
    Ian
    08 Access Cab SR5
    mythbusters did a thing about that. only helps to leave the tailgate on. it creates a cabin effect with the actual tailgate. yeah getting a net would make it lighter, but thers nothing there to create that cabin effect with it on.
