more power
Discussion in '1st Gen. Tacomas (1995-2004)' started by robpad, Jan 20, 2007.
  1. Jan 20, 2007 at 6:17 PM
    robpad
    robpad [OP] Member
    looking for more power out of my taco 2.4l. i have a cold air intake with a k&n filter and a 2 3/4in cat back with a flowmaster exhaust. any ideas about other mods?
  2. Jan 20, 2007 at 6:43 PM
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    How much are you looking to spend?
    Boost it!!!!
  3. Jan 21, 2007 at 8:23 AM
    007Tacoma
    007Tacoma I dub thee malicious!
    Mark
    San Antonio, TX
    2015 4Runner Trail Edition Premium
    Cloaking Device
    I agree. That will get you the best bang for your buck.;)
  4. Jan 21, 2007 at 1:33 PM
    twoarezee
    twoarezee Well-Known Member
    esco, ca
    00 Dropped Mini
    rims,tires,3"/6" drop, 4x4 front end, 01 tails and corners, prerunner buckets,tenzo r steering wheel w/ momo hub, b&m shifterw/ jdm trd knob, alpine system, tint, 3 3/4" autometer tach, jardine cat back, k&n, debaged, hellwig rear sway bar, kyb monomax shocks, tundra v8 oil filter w/ mobil 1 in ever
  5. Jan 30, 2007 at 10:37 AM
    yota8282
    yota8282 Member
    what about a header cause i have the same problem will a 2.7 header work on a 2.4
  6. Jan 30, 2007 at 1:00 PM
    twoarezee
    esco, ca
    00 Dropped Mini
    i dont think so. if you want a 2rz header get the one from www.lcengineering.com because it is the best quality and works the best. or you could get the cheap pace setter header, but it burns the paint off of itself and rusts, and likes to blow out gaskets.
  7. Jan 31, 2007 at 8:19 AM
    yota8282
    yota8282 Member
    thanks ill check that out
  8. Mar 18, 2007 at 8:47 PM
    orbea_adam
    orbea_adam New Member
    What about the TRD Supercharger?
  9. Mar 20, 2007 at 5:50 PM
    twoarezee
    esco, ca
    00 Dropped Mini
    the power gain for the price isn't really worth it if you want big power gains unless you go all out with injectors, fuel pump, fuel computer, tuning, smaller pulley, water injection etc,header... but if you just want a little more power and not go crazy fast it would work out ok. if his truck is pre 2000 than he can only run 4psi on the stock fuel system, and then it is not really worth it.
  10. May 24, 2007 at 6:34 PM
    nedams1
    nedams1 New Member
    For more power and more mpg change the original fan cluth instaling one doble electric fan with relay. 2500 cfm 12" /14" diameter. one option doble electric fan nissan sentra 2 speedfan.my taco is 2000 2.7 and i put the electric dualfan.funcion is very good temp is normal.
  11. May 25, 2007 at 1:33 AM
    jrallan26
    jrallan26 Well-Known Member
    Iowa
    2004 White D-Cab TRD
    convert to a 3.4L...
