More suspension travel without lift??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bandit, Aug 15, 2009.
  1. Aug 15, 2009 at 4:10 PM
    Bandit
    Bandit [OP] Well-Known Member
    North Charleston, SC
    2007 Tundra CrewMax 4x4
    Leveling kit, 295/75r18 nittos, banks exhaust
    Redacted
  2. Aug 15, 2009 at 5:06 PM
    rzimm001
    rzimm001 Tearmytaco
    Bobby
    Wildomar
    08 PreRunner SR5 Long-Travel
    King 10" coilovers w/ resi. 3.5" over long travel kit. Factory spindles w/ ALLPRO gussets. Total Chaos tower gussets. Energy Poly cab mounts and steering rack mounts. Glassworks fenders and bedsides. Home fabbed bed cage. King 2.5x16 bypass shocks in the rear. DMZ long travel rear end. Race radio (2meter). Removed secondary carbon air filter. Exhaust dumped before the axle / no muffler. Phram fresh air cabin filter. K&N replacement filter, After market stereo, Grillcraft grill, custom fabled roof rack with 7" HID's, PRP race seats.
    Take off the sway bar! Rides smoother and gives very little extra body roll. Try it and you'll be surprised.
  3. Aug 15, 2009 at 5:08 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    San Antonio, TX
    2016 TRD Off-Road 4x4 DCSB - Super White
    Some extended travel coilovers set at zero lift, with a pair of uniball upper control arms will do the trick.
  4. Aug 15, 2009 at 5:45 PM
    r12rex
    r12rex Well-Known Member
    Cleared headlights, Black emblems, Painted black valence on front bumper, 2.5" 5100 Billys front, 1.5" AAL rear, Satin black TRD O/F wheels with 265/75 16 Definity M/T, Spidertrax spacers
    ^^^ He said it! Removing the sway will make the ride a LITTLE bit more compliant, but the shock valving and spring rates don't change :p Extended travel shocks set to 0 lift with nice upper control arms are the perfect set-up! It'll be butter smooth too!
    Kind Regards,
  5. Aug 15, 2009 at 6:38 PM
    Bandit
    Amazing! thank you!
  6. Aug 15, 2009 at 7:10 PM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    how much travel do we get stock anyay? my guess is 7-8" but i dont really know
  7. Aug 15, 2009 at 9:03 PM
    Bandit
    not enough to compensate for the weight of the vehicle when gravity pulls it back to the earth from its glorious flight thru the crisp morning air over the sand covered roads my truck lives to conquer.
  8. Aug 15, 2009 at 9:27 PM
    Kelson
    Kelson My Truck is Cuter than Yours
    Kelson
    Honolulu, Hawaii
    08 5-Lug Reg. Cab SR5
    SR5 Exterior/Interior (Color matched Front Bumper, Chrome Grille Surround and Chrome Rear Bumper/Silver Scoshe Dash Kit, A/C Bezel, A/C Vent Surround) LED license plate and white interior lights, Wet Okole Seat Covers, iPad in-Dash, JL CL-RLC, JL 13TW5 sub, JL 500/1 Slash V1 amp, JL XR 6.5 Components, Rockford Fosgate 6X9s in Boxes Front XRunner Coils, DJM Control Arms and Rear 4X4 Leafs, Custom 2" Angled Streetacos.com Blocks Front XR Bilstien Struts and Rear XR Bilstien Shocks, CravenSpeen Antennae, RX-8 Rims w/ Fronts:235/40-R18 Sumitomo HTR Rears:245/40-R18 Goodyear Eagle GT, 35% Tint front windows, OEM Sliding Privacy Glass w/ 5% Ceramic Tint, Flowmaster Super 44 dumped before the axle, URD Short Throw Shifter, Door Sill Protectors, Door Edge Guards, OEM Sport Pedals,The Retrofit Source Morimoto Mini D2S Stage III 35W 5K HID Headlights, OEM Fog Lights w/ piss yellow bulbs, OEM Cruise Control, Porsche 944 Bucket Seats, BeefedTaco Skid Plate, Whale
    last gen. was 4" up & 4" down.
    not too sure bout this one though....the 6 lugs have good susp. travel...its just the springs are pretty stiff up front. i think rear wise there's only like 3.5" travel between the bumpstop and frame.
