More Trans. Temp Questions......
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Illini Tacoma, May 26, 2021.
  1. May 27, 2021 at 8:00 PM
    #41
    Anderson5290
    Anderson5290 Well-Known Member
    Brandon
    Corona, Ca
    2018 Tacoma TRD OR 4x4
    Tuned Fox 2.5 resi with dsc, JBA HD UCA, total chaos knuckle gussets, rear trd pro fox shocks, Deaver U402 stage 1 rear leafs, archive garage u bolt flip with fox 2.0 air bumps, White knuckle off road rock sliders, BAMF 1/4” steel skids, Magnaflow exhaust, Archive Garage Hammer Hangers, Cbi high clearance rear bumper, 285/75/16 tires.
    Awesome, we’re planning a trip soon, I’ll be sure and take that path the next time we roll up there either this year or next. The drive wasn’t the greatest on the 5. Also might hit the Dusy this year since I haven’t been.
    CPS-65[QUOTED] likes this.
  2. May 27, 2021 at 8:24 PM
    #42
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    :rofl:
    Skill buddy! Usually just pulling hills at speed.
    Lt. Dangle[QUOTED] likes this.
  3. May 28, 2021 at 2:59 AM
    #43
    enforcertaco91
    enforcertaco91 Well-Known Member
    West is best !
    2024 Tundra Terra (terror) Pro
    PPF Front grill, bumpers and headlights.
    Did you do a drain and fill every 60k as Toyota recommends ?
  4. May 28, 2021 at 6:29 AM
    #44
    GoldenBrew
    GoldenBrew Insufficient Privilege
    Golden, Colorado
    Gen3 4X4 TRD OR AT - SOLD not Forgotten
    I don't think the Tow Package Trans Cooler has fluid actively passing through it until the thermostat opens - then the fluid flows through it (and your TruCool) and back into the transmission. Until then the transmission cooler has no affect. Pin the thermostat during warm weather season / tow season and remove the pin during winter / non-tow season. This is what I do - I have a Hayden. Temps pinned not towing are 180's - towing are around 210 when under max condition.
  5. May 28, 2021 at 7:15 AM
    #45
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    Awesome!
    That powertrain combo seems to be unbreakable.
    MaverickT883[QUOTED] likes this.
  6. May 28, 2021 at 9:21 AM
    #46
    MaverickT883
    MaverickT883 Paintless
    Maverick
    Ontario, Canada
    2021 Tacoma TRD Off-road Access Cab
    Check build thread!
    If I'm being honest, it's lucky if it gets an oil change every 25k. I don't think it's ever had a fluid change.
    hiPSI and Junkhead like this.
  7. May 29, 2021 at 12:55 AM
    #47
    enforcertaco91
    West is best !
    Well at almost 400k that's impressive. I'd still do a drain and fill but certainly not a flush, if you plan to have it last for another 400k.
  8. May 29, 2021 at 6:10 AM
    #48
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Is your transmission without abnormally shitty behavior? No shudders, slipping, etc.
  9. May 29, 2021 at 6:35 AM
    #49
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Yeah none of that. Just frequent shifts.
  10. May 29, 2021 at 1:04 PM
    #50
    Smacky2020
    Smacky2020 Well-Known Member
    Bristol, VA
    2020 TRD ORDC - Cement
    Stock wheels and suspension. Random "utilitarian" mods featured on this great forum.
    Just did a 1400 mile round trip from Bristol VA to CT (and back) using I81-I84 corridor. The only time torque conv went 227 was climbing some of the steeper hills in PA and NY with outside temps of around 85. As soon as things evened out, temp dropped to 190's and was the average temp for duration of the trip.
    Not hauling anything or loaded down with stock suspension and tires. I have to say, absolutely no gear hunting or other shenanigans prior years reported. Definitely like driving a brick with a headwind at times but it can keep up if you push it.
    Again, average pan temp was 190 and TC got up to 227 going 70mph in 5th up a gear for maybe a few mins. You could actually see the rapid temp drop when thermostat opened and load leveled out.
    SR-71A likes this.
  11. May 29, 2021 at 4:41 PM
    #51
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Are you tuned?
  12. May 29, 2021 at 5:23 PM
    #52
    Smacky2020
    Bristol, VA
    Negative. Bone stock and started the trip with 5100 miles on the clock. This was the longest highway trip this truck had up till now so I was honestly dreading gear hunting (to some extent) and horrible suspension but had none of it. 26h round trip and it drove great. Not Mercedes quiet or fast but no slouch either.
    Because I had nothing better to do, I looked at various pids from my scangauge. Nothing got crazy high but TC jumped up pretty quickly and steadily on climbs. It rained on the returned trip and was much cooler so temps stayed mostly below 200 even on climbs.
  13. May 29, 2021 at 5:27 PM
    #53
    splitbolt
    NW Arkansas
  14. May 29, 2021 at 5:30 PM
    #54
    MaverickT883
    Maverick
    Ontario, Canada
    Check build thread!
    Not my decision on what to do, but I agree with your analysis lol.
  15. May 29, 2021 at 5:34 PM
    #55
    Skydvrr
    Nick
    YMH
    Black '17 OR
  16. May 29, 2021 at 6:02 PM
    #56
    splitbolt
    NW Arkansas
    Not the same kit but close...this guy has some good data on what it does.
    Comparison starts at 13:52
    Greg.Brakes.Tacos likes this.
  17. May 29, 2021 at 6:59 PM
    #57
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    Not a 3rd gen but my experience using an ultra gauge, putting the tranny in “4” the torque converter stays locked and no heat is produced.
  18. Jun 1, 2021 at 6:50 AM
    #58
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Ahh cool. Thanks for the pics!
