Morel Tempo Ultra 6x9 Component sets
Discussion in 'Audio & Video' started by CoastieRon, Aug 23, 2018.
  1. Sep 5, 2018 at 6:20 PM
    CoastieRon
    CoastieRon [OP] Hammocking Fool
    Ron
    Nashua
    Lil' Silver
    Too much.
    Are they giving you an issue?
  2. Sep 6, 2018 at 12:46 PM
    jasperkat
    jasperkat Business cat
    2021 Cement TRD Offroad DCSB
    I don't have them installed yet, just been mocking up the fitment to decide if I'm going to keep them or return for the 6.5" tempo set. If the speaker is right into the back of the door grill I'm concerned it'll add noise and possible damage the speakers. Basically, if the dremel has to come out I'll skip it and go with a different set.
    The plan is to dial this in tomorrow. Most likely they work fine without further modification.
  3. Sep 6, 2018 at 1:00 PM
    CoastieRon
    Ron
    Nashua
    Lil' Silver
    Too much.
    I'll have to take a closer look at where they sit in relation to the door panel. I didn't think they would be close at all.
  4. Sep 9, 2018 at 7:45 PM
    CoastieRon
    Ron
    Nashua
    Lil' Silver
    Too much.
    How did it go?
    I ordered the integras for the rear doors.....
  5. Sep 10, 2018 at 12:57 PM
    jasperkat
    I got them installed on Friday, and checking the top mount clearance the 6x9 door panel "ring" doesn't come into contact with the speaker. If I had to guess there's maybe an 1/8" gap between the speaker and that ring. The shallowest point on the door grill is about 3/16", so there's room but it's pretty close.
    Having swapped to the Tempos from the Maximo Ultra 6.5" set it was a definite step up in audio quality. The tweeters are slightly larger and sound even better. I don't have them running with an amp yet but I imagine they would sound amazing with more power.
    CoastieRon[OP] likes this.
  6. Sep 11, 2018 at 6:29 AM
    CoastieRon
    Ron
    Nashua
    Lil' Silver
    Too much.
    I think I might have a harmonic vibration, but only at certain frequencies. I may take the panel off and throw a couple noico strips her and there on the panel itself.
    It surprises me that the speaker is that close to the panel. I still haven't had the chance to take a look.
    There is certain music that sounds absolutely fantastic on these speakers (ex: The Beatles, Hamilton soundtrack, all heavy bass rap/metal/pop-well produced music) and there is other music that could use just a little help (ex: 80s/early 90s metal with poor production, Mastadon) from the EQ.
    I tend to listen to music flat on the EQ. I'm extremely satisfied right now though. Once the rears come in, I might dial down the highpass for both back and front from 90 to 70 (or somewhere in between) as these can be set down to 50. Right now, I'm good though.
  7. Sep 19, 2018 at 10:17 AM
    CoastieRon
    Ron
    Nashua
    Lil' Silver
    Too much.
    I installed the Integras last night in the rear doors.
    Unboxing:
    [​IMG][​IMG]
    The speakers have soldered in resister style crossovers to protect the speakers from going too high on the woofer or too low on the tweeter.
    The terminals in my opinion should be more robust for a $269 pair of coaxials
    Side by side comparison
    [​IMG][​IMG]
    Look at the size of that magnet on the Morels!
    And we're installed:
    SUMOTNK likes this.
  8. Sep 19, 2018 at 12:22 PM
    mach1man001
    mach1man001 eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    How do they sound?
  9. Sep 19, 2018 at 12:36 PM
    CoastieRon
    Ron
    Nashua
    Lil' Silver
    Too much.
    Right now they sound OK, but I am not using them at the right amp setting. My rears are set with a high pass of 100hz for about a week, then I will switch the rear channel from high pass to full. I tested them at full and they sound fantastic. I just want to break them in for a week responsibly..... Same with the fronts, though those are set at 90hz, and will be going down to 70 soon.....
    mach1man001[QUOTED] likes this.
  10. Nov 26, 2018 at 10:51 AM
    CoastieRon
    Ron
    Nashua
    Lil' Silver
    Too much.
    mach1man001 likes this.
  11. Jan 26, 2019 at 3:56 AM
    CoastieRon
    Ron
    Nashua
    Lil' Silver
    Too much.
    Update:
    I've been running this set up for a good amount of time, so I believe these speakers to be well broken in now. The bass out of the front woofers is incredible. You could run these speakers with a 4 channel amp without a sub if you were so inclined to....
    Bridge4 likes this.
  12. Mar 17, 2019 at 4:26 PM
    CoastieRon
    Ron
    Nashua
    Lil' Silver
    Too much.
    I want to circle back to this. I've updated my head unit to a Kenwood DMX905S and retuned the amp using a SMD DD-1. Set the gains using 40hz @-5dB and 1000khz @-5dB.
    Holy crap, these speakers shine at high volume. Way better than with the OEM head unit.
  13. May 31, 2020 at 10:31 PM
    toucan
    toucan Stupid truck
    Sam
    Oregon
    2013 DC offroad MGM. 2012 Super White SR 4x4 RC
    SCS/Bilstein/Icon/JBA/ Relentless/ATH/Smittybilt/Meso/Mobtown/Archive Garage/BAMF/Pioneer/Rockford Fosgate/Sundown/Wet Okole/Spiker Engineering/I'mMr.Yo/RAMMounts/Softopper/Weathertech/Factor55/Morel/DD
    Anybody know if these 6x9's will fit in a 2nd gen?
  14. Jun 1, 2020 at 8:22 AM
    destin_meeks
    destin_meeks I used to fix people's crappy stereos
    Destin
    Tuscaloosa, AL
    2017 SSM DoubleCab TRD Off-Road 4x4
    yes. just be sure you grab the correct adapter bracket
    toucan[QUOTED] likes this.
  15. Jun 1, 2020 at 6:25 PM
    #35
    toucan
    toucan Stupid truck
    Sam
    Oregon
    Awesome. I got a great deal on a pair and as usual I did no research until after I hit the pay button. I just put a set of maximo 6.5 comps in my sons car and they sound light years better than my RF t2's. So I got the itch again.:spending:You have a link for the proper bracket? for a 13 ORDCSB.
  16. Jun 1, 2020 at 6:59 PM
    #36
    destin_meeks
    Destin
    Tuscaloosa, AL
    Just the standard Toyota 6x9 bracket. Metra 82-8146 I think
    can grab a pair online, or most Best Buy’s keep them in stock if you want to pick it up
  17. Jun 5, 2020 at 11:36 PM
    #37
    toucan
    toucan Stupid truck
    Sam
    Oregon
    This dustcap look sketchy?
  18. Jun 6, 2020 at 10:12 AM
    #38
    jjglass535
    jjglass535 Well-Known Member
    Tampa, Fl
    2018 TRD Sport 4x4
    KDMAX Pro v.9
    That doesn't look normal. I have a 2 month old set of these for sale if anyone is interested. They are like new
  19. Jun 6, 2020 at 5:33 PM
    #39
    toucan
    toucan Stupid truck
    Sam
    Oregon
    I spent the afternoon looking up images of these on the net. The squiggly light circle appears to be quite normal. Or lots of folks are getting fakes.
  20. Jun 6, 2020 at 11:36 PM
    #40
    jjglass535
    Tampa, Fl
    2018 TRD Sport 4x4
    KDMAX Pro v.9
    Looks like fakes to me. Can’t imagine a company with such high end equipment making something like that but I’ve been wrong before. I know mine don’t look at all like that
