Morimoto Mini Stage III Kit (H1) bulb mounting?
Discussion in 'Lighting' started by sfcadams, Mar 24, 2012.
  1. Mar 24, 2012 at 10:37 AM
    sfcadams
    sfcadams [OP] Retired Senior NCO
    Dan
    Elizabeth, Indiana
    2011 TRD Off Road DCSB Prerunner Skeewped
    **** TITLE SHOULD READ MORIMOTO MINI STAGE III KIT (H1) bulb mounting, NOT (D2S) bulb mounting
    I purchased a Morimoto Mini Stage III Kit (H1) from TRS but can't for the life of me figure out how to mount the actual bulb into the projector housing. What exactly is supposed to hold the bulb in the housing? Maybe I didn't receive all of my parts or something? If someone could take pics of how their bulb is held in and post them up or at least try and give me an idea of what I might be missing, I would greatly appreciate it.
    Thanks!
  2. Mar 24, 2012 at 12:16 PM
    Noobaru
    Noobaru CAPS LOCK FTW
    Federal Way, WA
    2020 DCSB OR Voodoo Blue
    Stock for now...
    This is how mine look. These are the mini h1's.
  3. Mar 24, 2012 at 1:33 PM
    Cortland
    Cortland THIS IS AMERICA!!!
    Cortland
    Arizona
    Clifford aka Big Red
    Camburg 4" Spindles, 5100's All Around, All-Pro 1.5" Leaf Pack, All-Pro U-Bolt Flip Kit, Avid Sliders, AFE Pro Dry Filter, Wicked Flow 18" Muffler
    subbed for when I install my bulbs
  4. Mar 24, 2012 at 1:42 PM
    sfcadams
    Dan
    Elizabeth, Indiana
    Noobaru,
    That little metal clip was included with my kit but I don't see that little mounting plate anywhere....
  5. Mar 24, 2012 at 1:43 PM
    Cortland
    Cortland
    Arizona
    That mounting plate should have been screwed to the back of the projector (3 tiny screws)
  6. Mar 24, 2012 at 1:53 PM
    sfcadams
    Dan
    Elizabeth, Indiana
    Now I see it on one of the projectors but it isn't on the other projector....
    Damn it!!
    Can these be ordered separately?
    Do you happen to know what they are called?
    Happen to have any extra one by chance? (yeah right!)
  7. Mar 24, 2012 at 2:00 PM
    sfcadams
    Dan
    Elizabeth, Indiana
    Not only is it not screwed into the other projector housing, there aren't even any screws there that would have held it on.....
  8. Mar 24, 2012 at 2:02 PM
    Cortland
    Cortland
    Arizona
    I would just call TRS on Monday and let them know and I am sure that they will make it right.
  9. Mar 24, 2012 at 2:30 PM
    sfcadams
    Dan
    Elizabeth, Indiana
    I guess I will call Monday morning.
    On a separate note, anyone made heads or tails out of the wiring harness? It seems like there are a lot more connections than needed on this thing. Also, they include a connector by itself in a separate plastic bag. Anyone wired one of these up to a 2011 Tacoma yet?
    If it makes a difference, this is what I have...
    Ballasts: Morimoto 3Five
    Bulbs: H1 Morimoto 3Five
    Wire Harness Relay : H4/9003
  10. Jun 2, 2012 at 12:22 PM
    fullstream
    fullstream Well-Known Member
    steve
    Covington, Tn (between 2 corn fields)
    2010 trd offroad
    Tinted windows, tonneau, 3" procomp lift, vent visor's, bull bar, step bars, interior & exterior led's,anytime fog light mod, 35 w hid's 6000k fog, 3 Adv 60's w/ dimmer, color matched grill w/ satoshi, tinted taillights & fog lights, BHLM with mini h1's 35w 5000k, 2 hella 700's w/55 watt HID's, BAMF lightbar
    The wiring harness looks wild when you pull it out but when your setting it up on the truck just follow the little stickers on each lead. I had done very little wiring before I did my retro and one I started it all made sence and actually worked when I turned em on.
  11. Jun 3, 2012 at 1:06 AM
    jeverich
    jeverich Well-Known Member
    Jake
    PNW/Kodiak
    07 2.7 4x4
    OME 886/Old Man Doug Suspension Lift, ARB Bumper, Bruteforce High Clearance w/Swing Out, De-badge, Block Heater, Homemade IFS Skid, 7" Kragens, Blue Seas Fuse Block, BlitzPro Fogs, 12k BadLands Winch, BAMF Sliders, ARB Locker, 4.88s Yaesu FT-1900R, Larsen 150B NMO Mount Antenna
    The AMP connector, with red and black pigtails is a test lead. Enables you to connect to your ballast power lead and test your wiring via a 12V external power supply.
    The wiring harness is fairly easy to understand...
    Power from battery runs to relay, relay runs to ballast as well as stock H4 headlight sockets. High beam 12V leads should also be included in your harness as well.
  12. Jun 3, 2012 at 8:07 PM
    jeverich
    Jake
    PNW/Kodiak
    07 2.7 4x4
    Engrish?
