Morimoto VS Xenondepot Philips
Discussion in '3rd Gen. Tacomas (2016-2023)' started by NJtaco421, May 31, 2017.
  1. Jul 15, 2017 at 4:45 PM
    #181
    NAVVetCV62
    NAVVetCV62 Member
    That my friend is why you need to run D2S projectors. Rebased bulbs are OK, but like I said earlier, running the Morimoto D2S mini 4.0 with these bulbs is incredible. My Vermont winter road panzer truck is a 05 Ranger FX/4 that is running this setup and it is just incredible. You should see the MB and Beemie Boys look when I pull along side at night. LMAO. Is that a flippin' Ranger they ask? I can read lips. LOL.
    Now, if the dealer and I can ever come to an agreement on that '17 Black Limited I have an eye on, I will find out what it takes to do this conversion on a Tacoma.
    Sedyn[QUOTED] likes this.
  2. Jul 17, 2017 at 6:14 AM
    #182
    XenonDepot
    XenonDepot Well-Known Member Vendor
    @NAVVetCV62 : I agree that a relay harness is a good idea, but it really depends on what types of ballasts you are using. I can safely say that with the ballasts in our kits the relay harness is optional. The only reason you would need it is if your vehicle isn't able to supply a stable 12V. Unfortunately, there are varying levels of quality when it comes to aftermarket ballasts, so it really depends on what type of ballasts you're running.
    @xola3que - did you see these?
    http://www.xenondepot.com/h16-h8-h11-philips-Ultinon-LED-12793UNIX2-2700K-p/12793unix2.htm
  3. Jul 17, 2017 at 6:20 AM
    #183
    NinjaT1985
    NinjaT1985 Well-Known Member
    '17 Tacoma
    I have these in my fogs and they are amazing! cut through the fog easily and provide awesome visibility in the rain. If these were legal in the headlights I would use them there as well. I have the XD pure white led's in the headlights. I've been a long time XD fan and have used them in my past 3-4 vehicles and will continue to use them!
  4. Jul 17, 2017 at 9:08 AM
    #184
    NAVVetCV62
    NAVVetCV62 Member
    Don't want to beat a dead horse here. As you know, stable 12VDC and circuit ampacity are two different things. Some of these guys are changing their fuses from factory spec and upping the amp ratings in order to run ballasts without a harness. Man, that is playing with fire. I am sure you have good product. I run XB35 ballasts which are good as well and would never ever consider running them without a relay harness. I would not run Denso's or Koito's without a harness for that matter. Maybe the factory does on OEM installs but if they do, the wiring and fusing is sized accordingly by the engineer.
    xola3que likes this.
  5. Jul 19, 2017 at 4:03 AM
    #185
    NJtaco421
    NJtaco421 [OP] Well-Known Member
    NJ
    17 DCSB Sport MGM
    I'm assuming you have them installed by now, but i did have to apply a decent amount of force to get my bulbs to seat properly. Ive installed hundreds of bulbs, these were probably the most effort to seat.
  6. Aug 25, 2017 at 10:06 AM
    #186
    CH Luke
    CH Luke Active Member
    Ann Arbor
    2017 TRD Sport
    Factory stuff so far. Mud flaps,tow package, weather mats, bed mat.
    Jumped on the XD Phillips 4300k bandwagon with my order this morning. At this point I plan to use the "optional" harness.
    Looking for any new install tips, including keeping the harness install as clean as possible.
  7. Aug 25, 2017 at 10:21 AM
    #187
    biker921
    biker921 Well-Known Member
    Austin
    '17 TRD Pro
  8. Aug 25, 2017 at 10:31 AM
    #188
    rnicholls
    rnicholls Well-Known Member
    2016 TRD OR DCLB
    :puke:
  9. Aug 25, 2017 at 10:35 AM
    #189
    Scooby24
    Scooby24 Well-Known Member
    Greg
    2017 DCSB OR 4X4
    Why are you linking to an interior LED kit in a thread about headlamp replacements?
    rnicholls likes this.
  10. Aug 25, 2017 at 12:05 PM
    #190
    biker921
    Austin
    '17 TRD Pro
    That wasn't supposed to hyperlink. I was referring to the LED headlights made by them. My bad
  11. Aug 25, 2017 at 12:14 PM
    #191
    Scooby24
    Greg
    2017 DCSB OR 4X4
    Check out the hylux thread to see what a former OPT7 LED owner said about transitioning to HID. HID > LED.
    Vbpiper likes this.
  12. Aug 25, 2017 at 1:16 PM
    #192
    XenonDepot
    @CH Luke - Thank you for your business :)
    You're going to like our harness... 2 relays, 2 fuses, 2 grounds, 2 completely independent relay harnesses should something ever fail. The ballasts we use in our kits are low draw, so you can safely power them right from the OE wiring, however there is no downside to using the relay harness - it's extremely well made.
  13. Sep 20, 2017 at 2:10 PM
    #193
    XenonDepot
  14. Sep 21, 2017 at 9:58 PM
    #194
    Facts Only
    Facts Only Well-Known Member
    State Of Jefferson
    17 TRDOR DCLB Quicksand
    Well after tons of reading and comparing TRS Morimoto kit vs. XenonDepot I decided to go with the XenonDepot 35w kit with Philips bulbs. Excited to get these installed!
    Siblue and XenonDepot like this.
  15. Sep 22, 2017 at 5:57 AM
    #195
    cosmic_3000
    cosmic_3000 Well-Known Member
    '17 OR DCLB w/ JBL
    To the people that installed a 20A fuse instead of the 15A in the H-LP LO fuse spot: Any issues so far?
    @XenonDepot - Do you have a copy of the installation guide? Looking at the pictures on your website I'm a little confused. There seems to be a lot of extra things going on.
  16. Sep 22, 2017 at 7:21 AM
    #196
    XenonDepot
    Our HID kits are designed to be plug n play. What were you getting confused by?
    And here is the link to our HID install guide: XenonDepot HID Install Guide
    Danny
  17. Sep 22, 2017 at 8:32 AM
    #197
    rooster32
    rooster32 Well-Known Member
    Utah
    2017 Magnetic Grey TRD OR DC LB
    5.29 gears 6112/5160 w/Dakar Hvy SPC UCA's 255/80/17 Wildpeak AT3 Nitro
    XenonDepot....when are you getting more of the Philips bulbs in? I had an order placed recently, but cancelled due to back order.
  18. Sep 22, 2017 at 8:39 AM
    #198
    XenonDepot
    We are expecting them to arrive by the end of next week :)
    Danny
  19. Sep 22, 2017 at 10:47 PM
    #199
    cosmic_3000
    '17 OR DCLB w/ JBL
    On the website there is a large rubber grommet with four wires going through it. Where does that go? I'd like to use the existing wiring of the truck, will the ballast input plug into the existing low beam harness?
    Don't get me wrong, I install electronics and avionics on aircraft on a regular basis at work, so electrical wiring is no problem. It's just there seems to be more connectors and wires than there should be.
    The two relays and wiring, are they included in the kit? They are not listed on the What's Included tab for the kit.
    The link to your install guide seems to be broken.
    Thank You!
  20. Sep 23, 2017 at 6:08 AM
    #200
    cosmic_3000
    '17 OR DCLB w/ JBL
    Awesome, thanks for the info!
    What kind of homebuilt do you fly?
    Vbpiper likes this.
