Morimoto VS Xenondepot Philips
Discussion in '3rd Gen. Tacomas (2016-2023)' started by NJtaco421, May 31, 2017.
  1. Sep 23, 2017 at 7:59 AM
    #201
    cosmic_3000
    cosmic_3000 Well-Known Member
    '17 OR DCLB w/ JBL
    I plan on not using a relay harness at all. Instead, I will use the factory relay and fuses. I've calculated that a 20A fuse in the 15A H-LP LO position should not cause damage to the wires. Chapter 11 of AC 43.13-1B helps with that lol. The high current is also intermittent and only happens during startup.
    So my wiring would be: Fuse>Relay>Fuse>H11/9006 Adapter>Ballast>Bulb. This should be a very simple and clean install since it is mainly the ballast and wire going in.
    Vbpiper likes this.
  2. Sep 24, 2017 at 8:11 AM
    #202
    XenonDepot
    XenonDepot Well-Known Member Vendor
    Thanks for the replies, guys!
    Yes, the ballast has a 9006 style input connector, whereas the OEM headlight harness has an H11 style plug. You cannot plug an h11 plug into a 9006 plug -- although they look similar.
    The black/white wires that go through the grommet convert from 9006 to H11.
    Hope this helps (although the question has been answered),
    Vbpiper likes this.
  3. Sep 24, 2017 at 8:51 AM
    #203
    NJtaco421
    NJtaco421 [OP] Well-Known Member
    NJ
    17 DCSB Sport MGM
    I didnt use the relay harness and mine are functioning perfectly fine. People make things over complicated
    GotToyota and Vbpiper like this.
  4. Sep 24, 2017 at 10:22 AM
    #204
    GotToyota
    GotToyota Well-Known Member
    Portland, OR
    No relay harness here. I changed the fuses to higher rated ones per recommendations and haven’t had a problem.
    I’m using the XenonDepot 4300k Philips bulbs and Hylux ballasts I had leftover from an old set up.
    Vbpiper likes this.
  5. Sep 24, 2017 at 11:38 AM
    #205
    Bradd1146
    Bradd1146 Active Member
    2016 White TRD sport
    Anyone got anymore pics of the 4300K Phillips HID after install ?
    Facts Only likes this.
  6. Sep 24, 2017 at 9:06 PM
    #206
    Bradd1146
    Well I ordered the 5000K lights :)
    Only thing I was concerned with is not having as much usable light with 5000K as with 4300K as I saw someone post.
  7. Sep 24, 2017 at 9:49 PM
    #207
    r1200gs4ok
    r1200gs4ok Well-Known Member
    O. K.
    Irvine, Ca
    2016 Tacoma TRD Sport DCLB w/ Tech, Nav, Tow Pkg, MGM
    4300 does give you more usable light......you want to see more than be seen in the truck.......if on motorcycle, you want to be seen so the more light the better
    CH Luke and Hank Heel like this.
  8. Sep 25, 2017 at 4:41 AM
    #208
    Bradd1146
    Is there really that big of a difference between 4300K and 5000K ?
  9. Sep 25, 2017 at 5:17 AM
    #209
    pop639
    pop639 Well-Known Member
    Western PA
    16 SR5 DCSB 4x4
    Has anyone gone with the non philips bulb. And are the philips really that much better?
  10. Sep 25, 2017 at 5:35 AM
    #210
    pop639
    Western PA
    16 SR5 DCSB 4x4
    So the non philips bulbs are cnlight bulbs?
  11. Sep 25, 2017 at 5:41 AM
    #211
    Scooby24
    Scooby24 Well-Known Member
    Greg
    2017 DCSB OR 4X4
    XD are not cnlight to my knowledge but I have their Philips and then my cnlight. Both 4300k rated. The cnlight are whiter by a good margin. However the light output of the Philips is quite a bit more. I had been using the Philips for a few months and tried to go back to cnlight and while the color was more appealing, I noticed it seemed visibly dimmer in comparison so I've been sticking with the Philips.
    CH Luke and Vbpiper like this.
  12. Sep 25, 2017 at 5:46 AM
    #212
    pop639
    Western PA
    16 SR5 DCSB 4x4
    Gotcha, thanks
  13. Sep 25, 2017 at 5:51 AM
    #213
    XenonDepot
    The XenonDepot branded HID bulbs are not CN light bulbs. Our XD branded bulbs usee Philips UV quartz glass. Honestly, you are only losing about 300 lumens by going with the 5000K HID bulbs which is not a noticeable difference at this level.
    Here is another guide comparing the 5000K vs the Philips:
    https://www.xenondepot.com/highlander-led-headlight-kit-review-s/52.htm
    Danny
    Vbpiper and Facts Only like this.
  14. Sep 25, 2017 at 5:54 AM
    #214
    pop639
    Western PA
    16 SR5 DCSB 4x4
    Thanks...any idea on longevity differences?
  15. Sep 25, 2017 at 5:59 AM
    #215
    XenonDepot
    Would be the same which is 2500-3000 hours.
    Danny
  16. Sep 25, 2017 at 2:39 PM
    #216
    Facts Only
    Facts Only Well-Known Member
    State Of Jefferson
    17 TRDOR DCLB Quicksand
    Great read, and a thorough test. Glad I went with the Philips bulbs
    Vbpiper likes this.
  17. Sep 27, 2017 at 7:35 AM
    #217
    YDCtaco
    YDCtaco Well-Known Member
    Alexandria, VA
    2016 DCSB TRD OR 4x4-Auto
    If I have morimoto 35w ballasts with 5500k bulbs, can I get the 4300k phillips bulbs and replace them.
  18. Sep 27, 2017 at 7:39 AM
    #218
    XenonDepot
    Yep!
    We sell our H11 HID bulbs (philips is in the options) -- sold in pairs.
    Danny
  19. Sep 29, 2017 at 1:07 PM
    #219
    XenonDepot
  20. Sep 30, 2017 at 9:24 AM
    #220
    eraser
    eraser Well-Known Member
    Vancouver Island, BC
    2017 TRD OR
    If one wanted to do this what connectors/pigtails do those philips bulbs come with and are they compatible with the morimoto 35w ballast kit?
