Most inaccessible bolt
Discussion in '2nd Gen. Tacomas (2005-2015)' started by foampile, Dec 18, 2021.
  1. Dec 18, 2021 at 9:25 AM
    foampile
    foampile [OP] Well-Known Member
    Mid-Atlantic
    2007 V6 4WD 6 speed Extended Cab
    What do you think is the most inaccessible bolt on 1GR-FE?
    I haven't tinkered around the drivetrain much but have taken the engine apart two times now and, so far, the worst b***h of a bolt to torque has been the lower rear (towards the driver, away from the mechanic standing in front) of the 4 bolts that hold the AC pump, assuming no drivetrain components removed out of the way. I was able to get it (the first obstacle being that you virtually have no way of seeing it from the above at all, or even when you get under but the wheel is on) but then the space to even fit the wrench is very tight, The torque is 18 ft/lbs, for which I would normally use my medium wrench that is denominated in ft/lbs and goes up to like 100 or so, but because of the tight space I went with my little one set to 206 in/lbs. I used a long 12mm socket. The short one with the shortest extension was already too long but a short one alone wouldn't reach.
    So far I haven't had a more difficult bolt to reach.
  2. Dec 18, 2021 at 9:26 AM
    Oreo Cat
    Oreo Cat Worst Member
    Coeur d’Alene, Idaho
    I’m pretty sure I only have 3 bolts in my ac pump for that reason
  3. Dec 18, 2021 at 9:27 AM
    foampile
    Mid-Atlantic
    LMAO. It's possible if you have the grit. It might be a job for the lady of the house (smaller hands help)
  4. Dec 19, 2021 at 12:08 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    To access the AC compressor bolts such as when you need to change the tensioner assembly take the drivers side wheel off and wheelwell mud shield and have several long 3/8 drive extensions and a universal joint (wobbly joint) and find the way thru the suspension as there is a way - been there. Torque wrench was not used by me down there I just tighten them up. It's a pain.
    Naveronski and foampile[OP] like this.
  5. Dec 19, 2021 at 10:17 AM
    foampile
    Mid-Atlantic
    I was able to do it without it (blind) but it wasn't by any measure easy nor pleasant for my hand (kept poking it).
    I wouldn't look forward to doing it again.
  6. Dec 20, 2021 at 5:22 AM
    ZColorado
    ZColorado Well-Known Member
    Near Boulder Colorado
    13 DCSB OR 6MT
    35's,Kings, NWF, 488, Harrop, SPC, Archive, Method, RCI, C4
