Motive Pressure Bleeder vs Speed Bleeders
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mikalcarbine, Oct 22, 2019.
  1. Oct 22, 2019 at 12:08 PM
    mikalcarbine
    mikalcarbine [OP] Well-Known Member
    Phoenix, AZ
    2015 AC TRD OR
    About to flush my system but I'm kind of torn with which direction to go. I maintain 3 vehicles so getting the Motive bleeder seems to make more sense for me and I'm really looking for a 1 man bleeder setup. Can anyone confirm that this will work with the TRD OR master cylinder? I've read the universal adapter is needed but how does one successfully "chain" the adapter around the big MC?
  2. Oct 22, 2019 at 12:16 PM
    GorgeRunner
    GorgeRunner Out There
    2005 PreRunner
    Speed bleeders work well. Basic.
    Norton likes this.
  3. Oct 23, 2019 at 9:49 AM
    mikalcarbine
    Phoenix, AZ
    2015 AC TRD OR
    Anyone who owns a motive bleeder have any feedback?
  4. Oct 23, 2019 at 9:56 AM
    TheDevilYouLove
    TheDevilYouLove You can’t polish a turd, but you can polish a TRD
    Marylandistan
    2010 Tacoma TRD Sport Access cab 4x4 silver streak
    I have one but I have TRd sport brakes. I love it!
  5. Oct 23, 2019 at 10:00 AM
    69L46Vert
    69L46Vert Well-Known Member
    Rick
    Maine
    2007 Regular Cab 4x4
    I don't have one yet but plan to buy it soon. I have read the chains work poorly and people prefer to use a large c clamp instead of the chains
  6. Oct 23, 2019 at 10:20 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    OP. are you an 09+ TRD OR 4x4 (that is do you have an electric boosted master cylinder?)
    If so, dont bother with any sort of speed bleeders, you have an electric pump that will continuously pump brake fluid for you. Simply get a piece of wood/pipe/prosthetic leg to stick between the driver seat and the brake pedal, slide the seat forward to depress the brake pedal a decent amount. Turn the truck to ON (engine does not need to be running), then go to whatever wheel you are trying to bleed and crack the bleeder and watch the brake fluid spew out.... just make sure to watch the reservoir level!
    Torspd, TacoFergie, 69L46Vert and 3 others like this.
  7. Oct 23, 2019 at 11:07 AM
    Rob MacRuger
    Rob MacRuger Well-Known Member
    2006 4X4 SR5 4.0
    Amazon has the Toyota reservoir cap for the Motive product. It's $50 but worth it.
    69L46Vert[QUOTED] likes this.
  8. Oct 23, 2019 at 11:26 AM
    TheDevilYouLove
    Marylandistan
    Rob MacRuger[QUOTED] likes this.
  9. Oct 23, 2019 at 12:29 PM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    Does this method auto-bleed both front brakes as well? All 5th Gen 4Runners use this same system and the doc in the 2010 4R FSM suggests the auto-bleed is for the rear brakes.
    mikalcarbine[OP] likes this.
  10. Oct 23, 2019 at 12:58 PM
    nd4spdbh
    SoCal
    all 4 corners!
  11. Oct 23, 2019 at 1:04 PM
    spencermarkd
    spencermarkd Well-Known Member
    Spencer
    07 Driftwood Pearl 4Runner
    Rob MacRuger and Lester Lugnut like this.
  12. Oct 23, 2019 at 1:10 PM
    nd4spdbh
    SoCal
    I think the biggest issue i see with any of the "speed bleeders" that replace the nipples or use the nipple itself is that air gets pulled in via the threads of the bleeder as those are not meant to seal air. Teflon tape helps but gets chewed up quick via brake fluid.
    But 13 bucks is WAY better than other options.
    Rob MacRuger likes this.
  13. Oct 23, 2019 at 3:27 PM
    Lester Lugnut
    Thanks - good idea. For those who want to see it in use - see YT video below - man doing brake work - but bleeder tool usage starts at about 17:17
    https://www.youtube.com/watch?v=A20REqK4gsI
  14. Oct 23, 2019 at 4:45 PM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    Never knew that was a thing
    nd4spdbh[QUOTED] likes this.
  15. Mar 3, 2021 at 12:17 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    :mind-explode:
    I'm glad I found this - I was about to buy some speed bleeders for my truck. I just need to have someone continuously feed brake fluid into the reservoir while I'm at each wheel.
    The 2nd gen doesn't have a load proportioning valve at the rear axle or anything, correct? On my 1st gen, there were 5 bleeders (1 on each wheel and 1 on the load proportioning valve above the driver side of the rear axle on the frame.
  16. Mar 3, 2021 at 1:17 PM
    nd4spdbh
    SoCal
    Correct. no porportioning valve on the second gen.
    FYI the electric pump will help you with the rears, the fronts you still need to do it the manual way. I like to hold the pedal down with a stick wedged between the seat and pedal. Then use some channel locks to squish the pistons back into the caliper to push lots of fluid out the bleeder (making sure to close the bleeder before releasing) then you can pump the pedal slowly a few times to get fresh fluid back into the pistons.
  17. Mar 3, 2021 at 1:40 PM
    JasonLee
    15 TRD OffRoad
    It’s going to be fun with the StopTech 6-piston calipers with two bleeders on each caliper...
  18. Mar 3, 2021 at 1:42 PM
    Hans Moleman
    Hans Moleman Well-Known Member
    Bay Area, CA
    2023 F-150 Powerboost
  19. Mar 15, 2021 at 5:53 PM
    Crow Horse
    Crow Horse Well-Known Member
    Central NY
    2012 DCSB TRDOR
    How did you connect the BA10 with the Motive unit? Did you use the QD?
  20. Mar 15, 2021 at 6:48 PM
    Waasheem
    Waasheem
    2007 xrunner
    I bought this a couple years ago. It worked good for a little while. Around the 5th use it stopped working.
