Moto Metal Part 951 17x9 blk P/No?
Discussion in 'Wheels & Tires' started by mhagio, Jun 1, 2009.
  1. Jun 1, 2009 at 9:21 PM
    mhagio
    mhagio [OP] Active Member
    San Diego
    06 DC Silver 4x4
    Anyone have the specific part number for Moto Metal 951 Black
    17x9?
    4.5" backspacing
    -12 offset
    I want to be certain the one I order will fit my 06 tacoma 4x4
    Thanks
  2. Jun 1, 2009 at 9:42 PM
    BlueNorthToyo
    BlueNorthToyo Well-Known Member
    07 DBL Cab, TRD, SR5 & Tow Package, 3" Lift
    3" Revtek lift, Access Laredo Tonneau Cover (awaiting delivery), Debagged Tailgate, Pop and Lock Tail Gate Lock (awaiting delivery), Grom I-pod hardwire, Chrome Side Step Bars, Hood Deflector, Window Vents, 15" Stubby Antenna, GE NIghthawk Headlights, Fog Light Mod, Hose Clamp Tailgat
    sorry dude, I was deciding between the 17x9 and the 16x8 I went with the latter and I couldn't be happier. Heres a pic:
  3. Jun 2, 2009 at 2:37 AM
    FoxySandChick
    FoxySandChick Well-Known Member
    Kristin
    Henderson, NV
    07 DC 4x4 Base model V6 Impulse Red Pearl
    De-badged, limo tint, black wet okole's, weathertechs, extra d-rings, TSB bilsteins
    Motometal Series MO951 Wheel
    Part Number: W/PMO9517960312
    • 17x9, 6 on 5.5 Bolt Pattern
    • Backspace 4.53 in.
    • Max Load = 2200lbs
    • Finish = Black
    • Hubcentric = No
    • Offset = -12 mm
    Where are you ordering from and how much?
    I see them for $140/wheel with free shipping.
  4. Jun 2, 2009 at 9:25 AM
    mhagio
    San Diego
    06 DC Silver 4x4
    Thanks for the help on the p/no!
    I'm actually going to buy them from a guy for $100ea (as long as p/no matches). They are brand new in box.
    He had them mounted and balanced at discount tire, and then they figured out it wouldn't fit his jeep so he couldn't return them.
    I think he paid $163ea online. I saw them recently at 4wheel parts for about $516/set of 4 which was with a 15% discount (not sure this is still available)
    So I think I'm getting a pretty good deal for these. I checked them out and no scratches they just have the balancing tape attached.
    Thanks again
  5. Jun 3, 2009 at 4:41 AM
    FoxySandChick
    Kristin
    Henderson, NV
    Cool, sounds like a good deal then. :D
    You said they already have tires mounted? So you realize you will not be using your tire pressure sensors and the light on your dash will be on?
    Make sure you get those out of your stock wheels before you get rid of them, they are pricey to replace and are set to work on your truck only (unless reset by the dealer which is said to be $$$). You can always have them put into the new wheels/tires, but will have to pay for the mount/dismount and install.
