motor shutting off ater heavy throttle
Discussion in '1st Gen. Tacomas (1995-2004)' started by ebayollis, Jun 30, 2012.
  1. Jun 30, 2012 at 6:23 PM
    ebayollis
    ebayollis [OP] MY DIXIE WRECKED
    josh
    spruce pine nc
    2017 tacoma trd sport ddbl cab 4wd auto
    for the past few monhs ive noticed when i driving my truck around 45-55mph nd then WOT to pass a person,as soon as i get around them the truck dies.
    i have to pump the gas to get it to restart and when it does its dies again. It takes about 3-4 times f this and it finally runs...i was thinking maybe a clogged fuel filter but i changed it and it still does it...
    as long as I drive normally and dont wide open throttle, its does fine.
    My truck just started reading a p0420 code but this problem has been occuring much longer than the code has been showing.
    the truck has 180xxx miles and has never gave me any trouble...any ideas?
  2. Jul 1, 2012 at 12:25 AM
    TRDGRL
    TRDGRL My Toys.....
    TRDGRL
    RainForestVille, Honolulu, Hawaii
    '11 BLK Tacoma PreRunner TRD SR5 Access Cab
    See Signature.....
    Fuel Pump.....:cool:
  3. Jul 1, 2012 at 12:32 AM
    650H1
    650H1 Well-Known Member
    NH
    2010 Tundra TRD OR C/M 5.7l 4x4
    X3245435643653454145656586
  4. Jul 3, 2012 at 5:56 PM
    ebayollis
    josh
    spruce pine nc
    sso does everyone think fuel pump?
  5. Jul 3, 2012 at 8:40 PM
    Afwrestler1986
    Afwrestler1986 Well-Known Member
    Johnstown, NY
    01 trd 4X4 ex cab manual
    Gray wire, Some lights in the bed area, and some character marks throughout.
    I dont think so. So what you are saying is you can cruise fine, but when you whack it, I mean really giver hell, it will stall unless you keep the pedal down. If you take foot off the gas it just dies again right? But this is only on a sudden skinny pedal attack, you can slowly get it up to the redline and back off with no issue.
    My truck has done this since I bought it, it isn't the fuel pump. I think if anything, the computer is trying to send more fuel too fast causing it to flood. but I really don't know. My fuel pump has over 200k miles and hasn't taken a shit yet. Might just be a sensor causing it. What, if any, mods do you have done?
  6. Jul 4, 2012 at 4:07 AM
    ebayollis
    josh
    spruce pine nc
    after i WOT it dies no matter what...if i ease off of it or just completely let off the throttle. only mod i have is a K&N air filter...had it since day one but this just started happening maybe a year ago
    And it only seems to do it after cruising for a while...after changing the fuel filter i got out onthe highway and hammered it and it was fine so i thought i fixed it...but my whife and i were going down the interstae the otherday and i hammered it to pass a car and it stalls out and dies when i get around the car....then i have the pump the gas to get it to start again....
    i
  7. Jul 4, 2012 at 4:19 AM
    Greensystemsgo
    Greensystemsgo 1 owner with clean car fox.
    Dirty Nickers
    Peoria, AZ
    18 year old black taco...
    Bone Stock.
    id get the fuel pressure tested. if the filter is in fact good, the next suspect would be the fuel pump.
    do you have any check engine lights on?
    You might consider the timing, when was the last time you had the chain/belt adjusted/changed/timed?
  8. Jul 4, 2012 at 4:51 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Fuel pressure is the only non variable it is fixed and it must be with in spec. every thing else depends on a fixed pressure. So the first thing before blame can be placed on any thing else is fuel pressure check. The code is probably from a lean mix possibly from low fuel pressure at wot.
  9. Jul 5, 2012 at 6:51 PM
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    Bone Stock.
    Just because you cannot adjust the pressure, does not meana faulty part can't.
  10. Jul 6, 2012 at 4:32 AM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    Bingo! that's the point.
  11. Jan 5, 2013 at 2:52 PM
    Mray2007
    Mray2007 New Member
    Ky
    05 trd sport
    K&n air
    I've been having this same issue, I thought it was the chip in my ignition key because I had gottin it wet and sometime my truck will not start, after replacing the key the truck ran fine for about a month, now it will run fine unless I get the rpms up over 3k, if I get over 3k the truck will shut off and I have to stop pull over and restart it. My check engine light is on a says I have a bad o2 sensor, and these are gonna cost me about $260 for the 2 I need, I'm wondering if the o2 sensor could cause my vehicle to stall like it does?
