mountain bikers! can i get your opinion on this?
Discussion in 'Sports, Hobbies & Interests' started by 113tac, Dec 28, 2010.
  1. Dec 28, 2010 at 1:17 PM
    113tac
    113tac [OP] Well-Known Member
    Stephen
    Northern Virginia
    2017 Magnetic Gray Tacoma
    Mostly Stock for now, 265 75 16 Falken AT3W, Tinted fronts...
    okay so im trying to get back into riding, i used to ride everyday like street stuff, stairs, jumps stuff like that, i really enjoy riding and want to get into mountain biking so i went to a local bike shop and the guy working there recomended me to the Trek 4300, Gary Fisher wahoo and Trek Marlin single speed gary fisher edition. the Marlin SS really caught my eye cause its a 29er and single speed which would feel like my old bmx bike....kinda haha...anyways i think im gonna get the marlin so i just wanted to get everyones opinion
    here it is
    Frameset Sizes 15.5, 17.5, 19, 21, 23"
    Frame 6061 T6 aluminum, butted & hydroformed tubing, sliding vertical dropouts, G2 29" Geometry
    Front Suspension SR Suntour SF11 XCT V3 w/mechanical lockout, preload, custom G2 Geometry, 51mm offset crown, 100mm travel
    Wheels
    Wheels Formula DC20 front hub, KT TB5R SS disc rear hub; Bontrager Ranger Disc 32-hole rims
    Tires Bontrager 29-2, 29x2.1"
    Drivetrain Shifters n/a
    Front Derailleur n/a
    Rear Derailleur n/a
    Crank Truvativ E400 1.1G, 32T
    Cassette 20T freewheel
    Pedals n/a
    Components
    Saddle Bontrager Evoke 1
    Seat Post Bontrager SSR, 27.2mm, 20mm offset
    Handlebars Bontrager Approved Big Sweep, 15 degree sweep
    Stem Bontrager SSR
    Headset 1-1/8" threadless, semi-integrated, semi-cartridge bearings Brakeset Tektro Novela mechanical disc brakes, 6-bolt; 160mm rotors
    what do you all think?
    http://www.trekbikes.com/us/en/bikes/gary_fisher_collection/29er_hardtails/marlinsinglespeed/
  2. Dec 28, 2010 at 1:20 PM
    theduck911
    theduck911 Max's Canadian Twin
    Max
    Northwestern Ontario, Canada
    Locked and Geared!
    I actually do alot of MTB and Dirt Jumping and in my opinion it's a good bike, maybe see if there is an upgrade for better forks though.
    Never ridden a 29er though, so I don't know what's available for them.
  3. Dec 28, 2010 at 1:27 PM
    rbeezy
    rbeezy Well-Known Member
    Ron
    Bay Area
    2011 Tacoma SR5
    well since you did jumps and stairs, i think a 29er wouldnt be for you imo. 29er bikes tend to accelerate more slowly since the diameter of the rim is bigger, you need more braking power, tight handling and steering response is decreased when going at slow speeds. also larger wheels require more force when climbing uphill
  4. Dec 28, 2010 at 1:35 PM
    dirtJMW
    dirtJMW Member
    joel
    VA
    2003 Tacoma V6 TRD
  5. Dec 28, 2010 at 1:35 PM
    elutheros
    elutheros Active Member
    Copperas Cove, TX
    07 Crew Cab
    Bike rack above bed Locking Fuel door
    It all depends on what type of riding you plan on doing. Hardtails are fine for most of the not to technical trails, but you better be in really good shape if you plan on doing repetitive hills on a single speed. Where are you located in VA? The hard tail 29ers don't have the versatility of an "all mountain" bike like my Ellsworth Epiphany, but they are probably cheaper. Paying for a little more bike than you need in the beginning will keep you from immediately spending more on upgrades and changes. Like I said, it all depends on what kind of riding you want to do.
  6. Dec 28, 2010 at 1:39 PM
    dirtJMW
    dirtJMW Member
    joel
    VA
    2003 Tacoma V6 TRD
    or if you want a single-speed do it all mtb, my buddy has this bike for sale (in Virginia!):
    On-one Inbred singlespeed mountain bike – 18” medium; Thomson stem and post; White Industries ENO freewheel 18t; Mavic 717 rims - Chris King front hub, White Industries rear hub; Truvativ crank; XTR V-brakes; Kenda Karma tires; Surly 32 T front ring, no saddle, no pedals.
    $500
  7. Dec 28, 2010 at 1:40 PM
    Dibblit
    Dibblit Eh?
    Paul
    Stony Plain
    Truck
    Icon Suspension ARB OBA
    If your looking for a BMX type bike try one of the specilized or RMB Dirt jump style bikes, they are fairly nice. I think youcan only get them in 24 or 26 though
  8. Dec 28, 2010 at 1:49 PM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    That's strictly a cross-country bike...
    If you want something to play around on hard get something else:
    If you are actually going to pedal on singletrack all day, that bike will be fine. I highly suggest gears but apparently not having options is popular right now.
    If you plan on leaving the ground very often go back to a 26er with some fork travel 150mm+, lockout is a must.
    If you want to ride everything, get a 26er, with gears, full suspension, 150mm fork w/lockout, rear shock w/lockout, disc brakes.
  9. Dec 28, 2010 at 1:52 PM
    113tac
    Stephen
    Northern Virginia
    Thanks for all the quick responses! im probably not gonna be doing much urban stuff if any, ill be doing mostly trails, sorry if i made it seem like i was gonna be doing more urban.
    but elutheros im in northern virginia, fredericksburg/stafford area. i think im in pretty good shape, i work out almost everyday and i am currently doing conditioning for soccer season so im only getting in better shape every week, i also dont mind going up hills, when i test rode the bike it felt really good and i dint have a problem riding it, it is also reallyyy light compared to some of the other bikes they had
  10. Dec 28, 2010 at 1:55 PM
    nvdeserted
    Reno, NV
    Don't get me wrong, that's a fine bike, it just seemed a bit specific for your wants... but, the best bike out there is the one you'll ride!
  11. Dec 28, 2010 at 2:01 PM
    113tac
    Stephen
    Northern Virginia
    yeah i see where you are coming, i do plan on doing single track since there are a few trails out here, but ill also ride whatever i find like if i see a nice jump riding around town or something haha
    im definitely going to do a little more research, these three bikes were more in my price range, pretty much the next level bikes i saw were breaking $1k and thats a little more than i want to spend right now
  12. Dec 28, 2010 at 2:05 PM
    ekard
    ekard Well-Known Member
    San Jose, CA
    2011 DC SB 4X4 OR
    TRD Exhaust, Bilstein 5100's, Eibach coils, TSB Leaf pack, Toyota Bed Mat and D-Rings, Dakine Tailgate Pad, Wet Okoles, WeatherTech Floormats, PA15-TOY iPod Adapter, Goodyear Duratracs 265/75/16, SCS F5 wheels
    29er singlespeeds are fun bikes, I think it would be fine choice for exploring your local trails. You might have to experiment to find a gear ratio that you can use everyday, but the stock setups are usually pretty good these days.
    Hard to beat that Marlin for an entry level 29er (and I'm usually biased towards Specialized).
  13. Dec 28, 2010 at 2:33 PM
    Jimmyjohn
    Jimmyjohn Well-Known Member
    Jim
    Big Sky Country Montana
    06 SR5 4x4 DLB CAB
    Smitty Blt Bull Bar& Skid Plate, PIAA 525SMR lights
    Go a full suspension 21 speed Gary Fisher is built in the Trek factory and is a good bike. You may look at Cannondale if you are serious.
  14. Dec 28, 2010 at 2:43 PM
    dirtJMW
    dirtJMW Member
    joel
    VA
    2003 Tacoma V6 TRD
    and sadly, neither are built in the US anymore...
