Mounting a shell
Discussion in '3rd Gen. Tacomas (2016-2023)' started by LIazard, Oct 22, 2017.
  1. Oct 22, 2017 at 2:57 AM
    LIazard
    LIazard [OP] Well-Known Member
    Tacoma don't own one yet
    I realize it's probably not rocket science but what do I need to mount a used fiberglass shell on my 2017 Tacoma? Should I use foam tape or the kind with round beads? What kind of clamps? How to be sure before trying it on that it will fit? Any other advice would be appreciated.
  2. Oct 22, 2017 at 3:08 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Use this on the sides
    https://www.amazon.com/dp/B00C7VU9BA/ref=cm_sw_r_cp_api_D3g7zbSATGAA5
    And this on the front rail
    Front Rail Seal 6ft EPDM Rubber https://www.amazon.com/dp/B00C0WVV72/ref=cm_sw_r_cp_api_h4g7zbXV36QS4
    Clamps are dependent what kind of cap it is. To ensure fitment, you can either get the serial number and email the company, or just put it on your truck and see.
  3. Oct 22, 2017 at 8:46 AM
    LIazard
  4. Oct 22, 2017 at 8:47 AM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    @grrck
    grrck likes this.
  5. Oct 22, 2017 at 9:00 AM
    LIazard
    It's a fiberglass shell made by Century. No serial number. I was asking because I don't see how standard clamps like in the link below could work because the rail track thingamajig is in the way: https://www.amazon.com/s/ref=sr_gnr...oma+camper+shell+clamp&ie=UTF8&qid=1508687851
  6. Oct 22, 2017 at 9:18 AM
    Sagebrush
    Sagebrush Well-Known Member
    Gens 1, 2, 3, and 4
    My Century (which is the same as a Leer) uses clamps that use the bed rail. Nice and clean.
    Make sure you seal the bed joints near the cab. Any polyurethane sealant will work.
    SB
    Capt Jrod likes this.
  7. Oct 22, 2017 at 9:26 AM
    LIazard
    I guess I'll take fatfurious2's resend of the original reply as saying yes it should be 1-1/2" for the side rails? Right?
  8. Oct 22, 2017 at 9:27 AM
    sorgon82
    sorgon82 wanna go for a rip bud
    Ont. Canada
    2016 Grey Tacoma sport dc long bed
  9. Oct 22, 2017 at 9:31 AM
    LIazard
    Thanks for the advice on the sealant, didn't know that.
    I'm not finding any clamp that uses the bed rail. For example the Amazon link I sent is the full result from a search on "Tacoma camper shell clamp" and it doesn't look like any of them would work. Are these rail clamps something I need to get OEM from Toyota?
  10. Oct 22, 2017 at 9:32 AM
    fatfurious2
    David
    Ashburn, VA
    Im not sure. I was sending @grrck here for some info
    grrck likes this.
  11. Oct 22, 2017 at 9:36 AM
    Sagebrush
    Gens 1, 2, 3, and 4
    These were installed by the Century Dealer. I seriously doubt they are Toyota's
    grrck and Capt Jrod like this.
  12. Oct 22, 2017 at 9:44 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I just recommended that style of side ones. I have shitty foam on the side of mine and it doesn't leak, so it doesn't matter too much what's there. The problem area is the front rail.
    For the clamps, there are some made specifically for our side rails. I can't remember if they're made by leer or ARE, but I was able to buy them from a local cap store.
  13. Oct 22, 2017 at 10:23 AM
    LIazard
    Yikes! Thanks but it doesn't look like that would work for me. The shell bottoms don't extend in that far.
    Hey where did you get the thing you used to attach the eyebolt to the track?
  14. Oct 22, 2017 at 10:32 AM
    LIazard
    My local cap store is completely focused on high $$ items like caps, tonneau covers, etc. If you ask about installation accessories they pull out a catalog, which wasn't much help.
  15. Oct 22, 2017 at 10:40 AM
    Capt Jrod
    Capt Jrod Well-Known Member
    Jarrod
    Northern Ohio
    15 WHITE DCSB 4x4 TRD SPORT
  16. Oct 22, 2017 at 10:45 AM
    LIazard
  17. Oct 22, 2017 at 11:00 AM
    LIazard
    Other than width and length, what other measurements should I be checking on a used fiberglass cap? The seller has it on an older Nissan but says it doesn't quite fit right and says he thought it was made for an older gen of Tacoma. At the front it has a slight lean forward and there's a scoop top front center for a big cab brake light, which must have been 2nd gen Tacoma?
    Does anyone think it will fit decently before I drive an hour to try it on?
  18. Oct 22, 2017 at 3:44 PM
    fredgoodsell
    fredgoodsell Well-Known Member
    Salt Lake, UT
    2017 DC TRD OR
    No chance that it will fit well. Not worth the drive IMO
  19. Oct 22, 2017 at 4:37 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Do you have any pictures of it?
  20. Oct 22, 2017 at 5:16 PM
    LIazard
    Here are some photos of the Century shell.
