Mounting a Thule roof rack to the factory ditch on Tacoma 4-door
Discussion in '2nd Gen. Tacomas (2005-2015)' started by powdr_dayz, Dec 20, 2011.
  1. Mar 18, 2012 at 11:43 AM
    #41
    Indeepcamo
    Indeepcamo Well-Known Member
    Randy
    Portland, OR
    We can get two different weight limits with custom options. Fixed point will get you 125lbs and the track system is 165lbs
  2. Mar 29, 2012 at 2:40 PM
    #42
    honduraz10
    honduraz10 Member
    Nat
    DC
    07 DC SR5 4x4
    What feet would you use with the tk14 to be able to mount the aerobars?
  3. Jul 21, 2012 at 7:46 AM
    #43
    satcom221
    satcom221 Well-Known Member
    Rick
    Kingston, WA
    2023 Celestial Silver Double Cab SR5 4x4 SB
    VLEDS V tail conversion, gas cap holder
    Indeepcamo - What length tracks are those in the pic?
  4. Dec 15, 2013 at 6:22 AM
    #44
    drewp
    drewp Well-Known Member
    south Jersey
    '14 Sport/DCLB
    Anybody try any of the above mentioned ideas to mount to the factory holes? I just got a new '14 DC and am looking to do an install where I can continue to use all of my thule parts I've accumulated over the years. I notice that the TK14 is no longer available. Is there another best option to mount directly to the factory holes.....even if a mod is needed on the post? Has anyone used a thule system on the factory rack/rail? I don't want to mount inboard of the rail AND drill holes in my brand new truck. Any suggestions Indeepcamo? (I've gotten many of my parts from you in the past)
  5. Feb 1, 2014 at 4:44 PM
    #45
    wenkev
    wenkev Well-Known Member
    Kevin
    Louisiana
    2010 Double Cab TRD Off Road
    Stock
    This is what I have, Tying to use Yakima to match with the track rack on the back, but I will use the Thule if needed.
  6. Feb 1, 2014 at 4:47 PM
    #46
    MTopp
    MTopp Professional bear handler
    05 SR5 4x4
    trifecta tonneau, pop n' lock, Depo black bezel headlights, mb 352 wheels, 265/75r16 cooper at3s, visors, colormatched 2011 grille with raptor LEDs, much LEDs in and out Future/wanted: black valence, hood scoop, catback, CAI, 285/75r16s, OMD leaf pack mod
    subd
  7. Feb 1, 2014 at 8:37 PM
    #47
    wenkev
    Kevin
    Louisiana
    Stock
    Where did this pic come from?
    Did you ever find out if Thule or Yakima will fit the factory mounting points?
  8. Mar 2, 2014 at 2:52 AM
    #48
    JohnnyWayne
    JohnnyWayne The Past Through Tomorrow
    Johnny
    Lantana, FL
    '12 DCLB TRD Sport
    Look out for snakes in the grass guerrilla marketing.
    Bumping for justice - any resolutions to the op? Looking for something similar at the moment :)
  9. Mar 2, 2014 at 5:12 AM
    #49
    wenkev
    Kevin
    Louisiana
    Stock
    I have mounted the Yakima control towers to the factory mounts with the landing pad 11. It has a single mounting bolt. The supplied bolt is the exact fit. It is a perfect strong mount. I will post pics and details later.
  10. Mar 2, 2014 at 6:44 AM
    #50
    JohnnyWayne
    Johnny
    Lantana, FL
    '12 DCLB TRD Sport
    Cool deal thanks Kevin, waiting on pics :thumbsup:
  11. Mar 6, 2014 at 4:17 AM
    #51
    JohnnyWayne
    Johnny
    Lantana, FL
    '12 DCLB TRD Sport
    Here I sit broken hearted....
    Anyone else have any relevant info?
  12. Mar 6, 2014 at 6:03 AM
    #52
    wenkev
    Kevin
    Louisiana
    Stock
    Look for the Thule "landing pads" with one mounting hole and it should work. On Yakima, the load rating was the same. I just looked the mounting hole and drilled through the rubber gutter trim then pushed the bolt through. It was very easy. I used the middle set of bolt holes. With the front holes I would probably hit my head on with the 66“ bars.
  13. Mar 6, 2014 at 6:49 AM
    #53
    wenkev
    Kevin
    Louisiana
    Stock
    Here are the pics as promised. Sorry for the delay.
    uploadfromtaptalk1394117204181.jpguploadfromtaptalk1394117216339.jpguploadfromtaptalk1394117258890.jpguploadfromtaptalk1394117324745.jpg
    I married my tacoma likes this.
  14. Mar 6, 2014 at 12:28 PM
    #54
    JohnnyWayne
    Johnny
    Lantana, FL
    '12 DCLB TRD Sport
    Awesome thanks Kevin, +1 rep :thumbsup:
  15. Mar 6, 2014 at 1:41 PM
    #55
    tacoholic05
    tacoholic05 Well-Known Member
    05' 4x4
    Chris, did you ever have time to looking into this? I like your design and thinking about doing the same. I may cut some mounts at work that bolt directly to the exsisting OEM holes. Just not sure how to fabricate the load bar holders yet. Yakima and Thule have great products but are way overpriced when you think about the simplicity of the tasks they peform.
  16. Mar 6, 2014 at 1:44 PM
    #56
    tacoholic05
    05' 4x4
    wenkev - awesome job!
  17. Mar 6, 2014 at 2:50 PM
    #57
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    The above idea of cutting a section of the tracks won't work because the narrow width of the tracks.. It will collapse the rubber molding when tightening them down and they are too wide to fit down in the channel. You will have to fabricate a wide base for the tracks to mount through . Wenkev's design is good but only works well in his case with a camper rack. I don't think the 4 factory holes will be space out well enough for rest of us to make it look good or serviceable. I have only seen a shop custom drill and mount the tracks with plus nuts next to the rubber molding. Not enough balls to try that myself.
  18. Mar 7, 2014 at 6:46 AM
    #58
    tacoholic05
    05' 4x4
    wenkev, do you remember what the distance was from the front windshield to the first set of OEM holes and then the distance from that point back or from the back to the first set of holes. Looking for the distance between the factory mounting holes. Searched but noone seems to have this info.
  19. Mar 7, 2014 at 6:52 AM
    #59
    wenkev
    Kevin
    Louisiana
    Stock
    Just pull back the rubber. It pulls off and goes back easily.
  20. Mar 7, 2014 at 8:12 AM
    #60
    wenkev
    Kevin
    Louisiana
    Stock
    A simple bolt spacer would prevent the compression of the rubber to allow for the track.
