Mounting a Thule roof rack to the factory ditch on Tacoma 4-door
Discussion in '2nd Gen. Tacomas (2005-2015)' started by powdr_dayz, Dec 20, 2011.
  1. Mar 8, 2014 at 11:17 AM
    #61
    brwndg
    brwndg Active Member
    Tim
    Reston, VA
    2006 DCLB 4x4 TRD Sport
    I, too, am looking for a way to mount adjustable tracks to the existing ditch on my DCLB. My '99 Explorer had them & it was awesome. Still have the Yakima Landing pads, control towers, & 54" poles so really am determined to make this work.
    After absorbing a lot of the data from previous posts these tracks seem to fit the bill. Comes in a curved version in a wide variety of lengths, 1 1/4" wide so it should fit into the ditch & hug the roofline contour.
    Http://www.prolineracks.com/proline-roof-end-track-slats.html
  2. Mar 14, 2014 at 1:42 PM
    #62
    chuckdb
    chuckdb Member
    Atlanta, GA
    2011 DCSB 4x4 MGM
    Kevin, this looks great. I have a 2011 DCSB I'd like to try this on. Do you have any concerns with water getting into the bolt holes? Did you use any sealer when installing the landing pads?
    Thanks,
    CB
  3. Mar 15, 2014 at 8:35 AM
    #63
    wenkev
    wenkev Well-Known Member
    Kevin
    Louisiana
    2010 Double Cab TRD Off Road
    Stock
    I did use a caulking for added precautions.
  4. Jun 11, 2014 at 8:36 PM
    #64
    TacoBen14
    TacoBen14 Active Member
    Ben
    Olympia, WA
    2014 TRD Sport Manual 4x4
    Thule roof rack; ARE mid-height topper; AVEC Grille insert with LED light bar; Magnaflow catback exhaust; Konig 6-Shooter rims; Goodyear Duratrac tires; Bilstein 5100 shocks with Toytec coilovers and 2" AAL; also, I built a bed in the back!
    Any luck with the proline track? I'm looking to get a thule rack on my 2014 double cab. Don't like the clamp-on risers, and would like to avoid drilling fresh holes if possible. So was hoping to be able to use existing ditch. Thanks.
  5. Jun 12, 2014 at 12:57 PM
    #65
    forana
    forana Well-Known Member
    Kaneohe, Hawaii
    2022 DCSB OR Lunar Rock
    No money, all went to truck...
    I'm dying for someone to solve this issue!!
  6. Jun 12, 2014 at 1:24 PM
    #66
    craigb
    craigb Well-Known Member
    Craig
    Pa
    2013 TRD Sport
    Leer Cap Bilstein Shocks under bed lighting all weather mats window rain guards bed mat
    TacoBen14 just get the OEM rack and mount your cross bars to it. The holes are already there under the plastic covers. Unless your trying to save money. but you have a 2014 new truck.
  7. Jun 12, 2014 at 6:43 PM
    #67
    wenkev
    Kevin
    Louisiana
    Stock
    This was addressed in previous thread on this page.
  8. Mar 4, 2015 at 3:09 PM
    #68
    vidicious
    vidicious New Member
    Vid
    VT/NM
    06 Taco DCLB TRD Sport
    Leer 122 Cap Yakima rack more to come
    Just wanted to thank y'all for the posts here. I just put a Yakima rack on my double-cab using landing pad 11. The only thing I had to do was get longer bolts (used 65mm).
    Thank you!
  9. Mar 5, 2015 at 4:18 AM
    #69
    brwndg
    Tim
    Reston, VA
    Vidiciuos, let me know more detail about that mount please. Bolt size & length? Cud u post a pic of the towers in place. Really appreciate it :)
    Tim
  10. Mar 5, 2015 at 5:56 AM
    #70
    lowprofile
    lowprofile Well-Known Member
    matthew
    central, ms
    '15 Prerunner V6 SR5 DCSB
    +1
  11. Mar 5, 2015 at 1:12 PM
    #71
    wenkev
    Kevin
    Louisiana
    Stock
    Here is a pic of what I did, but I was able to use the included bolts. Once I got the thread started it sucked it down with plenty of extra thread. I have carried over the weight limit multiple times and have no issues.
    I married my tacoma likes this.
  12. Mar 5, 2015 at 1:13 PM
    #72
    wenkev
    Kevin
    Louisiana
    Stock
    You can set it closer to the front, but you will hit your head getting in if you use a step.
  13. Mar 5, 2015 at 1:59 PM
    #73
    sambrody44
    sambrody44 Member
    6 Speed Crew Cab Short Bed
  14. Mar 14, 2015 at 3:59 PM
    #74
    josmbrake
    josmbrake New Member
    Joe
    05 Double Cab 4WD
    Can anyone post the distance from the front-most to the rear-most predrilled threaded holes in the channel? Thinking of using the Yakima Landing pad 11.
    Thanks!
  15. Apr 24, 2015 at 3:23 AM
    #75
    Gerrrr
    Gerrrr Well-Known Member
    Jeremy
    Ottawa, Canada
    2017 Blazing Blue Metallic (Limited 2013 Silver Streak DC Auto - Retired)
    Starting over.......
    Watching with interest
    I have been looking at the proline tracks but an nervous of the quality. Have not seen any feedback from someone who has used them.
  16. Apr 24, 2015 at 12:31 PM
    #76
    WhiteNemesis
    WhiteNemesis Well-Known Member
    Mr PattyCakes
    T-Town, AZ
    Cant get enough
    Blow it through the roof
    That is a clever use of the stock mounting holes. I may be interested as well
  17. Mar 30, 2016 at 10:03 AM
    #77
    stbear
    stbear Well-Known Member
    SE PA
    2015 DCSB TRD Sport MGM
    I'm getting ready for spring and am looking for a way to mount a Yakima bar to the cab. I have tracks for the cap on my DCSB and need to mount a bar to the cab. I carry a 17 foot canoe and don't like the long overhang being unsupported in the front. Reviving this thread to see if the Yakima landing pad 11 is still the best solution to mount one or if others have come up with something new. I can always get the clips for the towers I already have but looking for a cleaner solution.
  18. Mar 30, 2016 at 10:17 PM
    #78
    brochacho
    brochacho Well-Known Member
    Vancouver, WA
    2016 4Runner SR5
  19. Mar 31, 2016 at 7:44 AM
    #79
    TOP TACO
    TOP TACO Well-Known Member
    Marz
    Sacramento
    15 Tundra Crewmax
    Blackvue dash cam
    I used the rhino rack tracks with Yakima control towers.
    brochacho likes this.
  20. Mar 31, 2016 at 7:54 AM
    #80
    TOP TACO
    Marz
    Sacramento
    15 Tundra Crewmax
    Blackvue dash cam
    With crossbars installed
