Mounting sliders
Discussion in '1st Gen. Tacomas (1995-2004)' started by Madjik_Man, Dec 5, 2011.
  1. Dec 7, 2011 at 4:18 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    i know how to put em on, its not too complex, but if i can get some of these and not need to weld onto my frame, why the hell not. My truck is my DD and will be for some time, so im hopefully not going to be rock crawling to the point where i am going to need full on welded sliders and bolt on wont cut it.
    http://www.cbioffroadfab.com/store/...id=77&osCsid=fbeb85d06bb6b23a9e35b9e7456346be
    also just realized that cbi was in idaho falls, pretty dam cool! might need to go check it out
  2. Dec 7, 2011 at 4:54 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    maybe they give 208 residents a discount:D
  3. Dec 7, 2011 at 4:57 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    lol not good enough. they need to share the love!
  4. Dec 7, 2011 at 5:05 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    the stock one? I think cbi bumpers/armor are my favorite by far, but fuck they are the most expensive:(
  5. Dec 7, 2011 at 5:52 PM
    Madjik_Man
    Madjik_Man [OP] The Rembrandt of Rattle Can
    Colorado Front Range
    m3bassman -
    I checked out your build thread to see your front bumper... what is it?
  6. Dec 7, 2011 at 6:25 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Do the CBI sliders require a body lift? There is not much space between the frame rails and the body.
    I'm thinking of doing something like this myself.
  7. Dec 7, 2011 at 9:48 PM
    capetaco12
    capetaco12 .<>./
    Cleveland Ledge, MA
    Sold: 33's,armor,crawler,dents, ect. 2020 Gladiator
    OME lift CBI sliders, front bumper homemade rear bumper 33x12.50 m/t Gears Aussie locker inchworm crawlbox Homemade flat belly
    I will get pic's tomarrow. Im surprised they dont have under body shots on the site.
    You dont need a body lift in order to put them on the truck. I had one small section where the top of the braket touched the bottom of the body ever so slightly (it would squeak a bit when i hit a potholes). I clearenced it with a hammer and punch then sprayed it with paint. I also wonder if the clearence issue has something to do with the fact that that side of my truck had been hit in a parking lot and may have damaged the body mounts/tweaked the floor.
  8. Dec 7, 2011 at 11:15 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    its the stock bumper, minus the entire lower plastic valance, with a metal bar (welded?) across the front above the skid plate,
    was i close?!
    also your photo shops look shittier and shitter the more i see them, way to go
  9. Dec 8, 2011 at 8:37 AM
    Madjik_Man
    Did you paint or plasti-derp the stock bumper?
    It's hard to tell with the pics I only see.
    I only ask because it looks good
  10. Dec 8, 2011 at 11:34 AM
    capetaco12
    capetaco12 .<>./
    Cleveland Ledge, MA
    Just to let you know bolt on with nothing but self tapping screws wont cut it. However the style of brackets that CBI has developed are more than strong enough. The only weak link is the strenght of the tube i think that you could twist the tubing into a pretzel before the brackets would fail. Hell they may even be stronger than a weld considering they wrap around all the way not just welded to the side and bottom.
    Edit: Also its pretty cool that i can remove my sliders in about an hour and a half with needing to grind and paint the frame again.
  11. Dec 8, 2011 at 12:26 PM
    01Tac0ma
    01Tac0ma Bash Fabriction & Off-Road
    Chad
    West Columbia, SC
    SAS 01 TRD 4x4
    Look at build!
    Its bolted on??? Mine had 2 nuts on each side holding it on, so you shouldnt have to cut it off.
  12. Dec 8, 2011 at 12:47 PM
    01Tac0ma
    Chad
    West Columbia, SC
    SAS 01 TRD 4x4
    Look at build!
    oh ok yea, thats right..those beams are considered "crush cans" in case of an accidenty but when i installed my bumper i cut those off and welded the new cross member that came with the new bumper over the frame ends in place of the crush cans.
  13. Dec 8, 2011 at 12:58 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    oh ya thoes were the ones i was looking at. they are pretty pricey as far as sliders go but they wrap around the frame and look like they bolt together and hold tight pretty well, i guess the only concern would be them actually sliding along the frame, but i believe you said earlier what that was not an issue with them
  14. Dec 8, 2011 at 2:26 PM
    01Tac0ma
    Chad
    West Columbia, SC
    SAS 01 TRD 4x4
    Look at build!
    Yea i cut mine right behind that hole and welded it all back up
  15. Dec 8, 2011 at 3:12 PM
    #35
    capetaco12
    capetaco12 .<>./
    Cleveland Ledge, MA
    AT the moment they are on sale on the website. Factor in the cost of paying someone to weld them on (if you dont have the capability) and your in the same price range with half the effor and a much higher resale value shall you choose to get out of wheeling.
  16. Dec 8, 2011 at 3:31 PM
    #36
    capetaco12
    capetaco12 .<>./
    Cleveland Ledge, MA
    IDK why you guys cut those cans off... Im like 99% sure there is a bolt on the inside of that can that you can take them off with.
    In the mounts when i put the sliders on the brackets were a little tight so i just used a jack to lift them on because i was by myself.
  17. Dec 8, 2011 at 3:56 PM
    #37
    01Tac0ma
    Chad
    West Columbia, SC
    SAS 01 TRD 4x4
    Look at build!
    I damn sure didnt see a bolt...but o well its done now:rolleyes:
  18. Dec 8, 2011 at 7:02 PM
    #38
    capetaco12
    capetaco12 .<>./
    Cleveland Ledge, MA
    Look inside the can... I just checked my frame rail and there is no can and a nice threaded hole in the middle of the flat frame rail end. Besides if the can is ment to be replaced then it must be able to be removed with ease.
    Looks like this with the cap removed.
  19. Dec 8, 2011 at 7:55 PM
    #39
    01Tac0ma
    Chad
    West Columbia, SC
    SAS 01 TRD 4x4
    Look at build!
    I believe you, but theres not way in hell id get to that now!
  20. Dec 8, 2011 at 8:42 PM
    #40
    Madjik_Man
    THREAD JACK!!!!
