moved my horns and now they don't work
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mntnjoe, Mar 26, 2014.
  1. Mar 26, 2014 at 4:48 PM
    mntnjoe
    mntnjoe [OP] Active Member
    Joe
    Alta, UT
    06 Tacoma TRD Off Road
    Went and relocated my horns over the drivers side wheel well today. Seemed pretty straight forward. Unbolt the horns, unplug the cables, pop the wire clips, backtrack the wire, plug the horns back in and bolt them to the wheel well. After doing all this I went to go test my horns and they weren't working. I can't seem to figure out why this happened, I might just be missing something dumb and small here, but does anyone have any ideas what could be going on?
  2. Mar 26, 2014 at 4:54 PM
    avw4x4
    avw4x4 Well-Hung Member
    (M)Andrew
    Rochester, NY
    2003 Yota
    ...loading....
    Check the grounding. The horns must be grounded to function.
  3. Mar 26, 2014 at 4:55 PM
    wannabetrd
    wannabetrd Well-Known Member
    Zach
    Michigan
    SR5
    3inch front 2inch rear lift with add a leaf and extended brake lines trd exhaust
    You don't have a good ground the horn is grounded thru the body so if it isn't a clean surface where you mounted them they won't work
  4. Mar 26, 2014 at 4:57 PM
    Aw9d
    Aw9d That one guy
    What the other 2 guys said.
    Unless the cable got cut somehow.
  5. Mar 26, 2014 at 5:02 PM
    transplant
    transplant resident know-nothing
    theo
    Crestline, Ca
    89 sr5, 99 OR, 11sport, 14 offroad
    pretty sure they ground through the mounting hardware. how did you re-mount it and where?
  6. Mar 26, 2014 at 5:05 PM
    AaronArf
    AaronArf Well-Known Member
    Aaron
    VA Beach
    2023 LR OR DCSB
    This.
  7. Mar 26, 2014 at 5:06 PM
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.04
    1.04. Kbro2s. ICONS.
    x5!
    I had this same problem. Be sure your new location, the mounting bracket is bolted to an unpainted surface.
  8. Mar 26, 2014 at 5:20 PM
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Devil Horns by Andres, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers, Pop and Lock tailgate theft deterrent mod 2.0, Plasti-dip rear bumper. Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    I must concurre with the consensus. Check your ground. Easy check would be run a wire from the negative post of your battery and touch it to the mounting bolt for the horn while someone is pushing the horn button. Or you could just make sure you have good metal to metal contact. :D
  9. Mar 26, 2014 at 5:42 PM
    mntnjoe
    Joe
    Alta, UT
    thanks for info. i'll check it out tomorrow when its not freezing cold outside.
  10. Mar 31, 2017 at 3:55 PM
    lawless
    lawless the rent is too damn high
    Lawson
    San Jose, CA
    2012 dcsb mgm sc
    bumping an old thread because i'm having the same issue but i'm not sure it's a grounding issue. i installed the horns with the snail opening facing up so they got full of water. i have not been able to get all the water out. anyone else encounter a wet horn issue?
  11. Mar 31, 2017 at 4:07 PM
    cliffyk
    cliffyk Well-Known Member
    Cliff
    Saint Augustine, FL
    2009 DCSB SR5 TRD Sport 145k miles
    If they have not "sat" too long full of water try squirting them, into the horn, with WD-40. Let them sit a bit then drain out any excess, then connect 'em to 12V (repeatedly if needed) and see if they will squawk and then honk. The "WD" in WD-40 stands for Water Displacing which is what it was invented for, in the aerospace industry. The "40" is because it was the 40th formula they developed.
    It's a crappy lubricant but it works great for its intended purpose...
  12. Mar 31, 2017 at 4:20 PM
    lawless
    Lawson
    San Jose, CA
    2012 dcsb mgm sc
    nice, thanks man. i'll give it a shot.
  13. Mar 31, 2017 at 4:23 PM
    cliffyk
    Cliff
    Saint Augustine, FL
    No pun intended right?
    Just out of curiosity, with gravity working the way it does why did you mount them with the opening facing up?
  14. Mar 31, 2017 at 4:28 PM
    lawless
    Lawson
    San Jose, CA
    2012 dcsb mgm sc
    it was just a dumb thing for me to do. i think wiring for the supercharger water pump is tied to the horn loom and so there's not much play to move the horns about to a nice mounting location. basically, i installed them where they fit.
  15. Mar 31, 2017 at 4:31 PM
    cliffyk
    Cliff
    Saint Augustine, FL
    I'd love to be able to tell you I have never been in one of those "it seemed like a good idea at the time" places--but I can't...
    Let us know if the WD-40 does any good. Repeat applications are OK too as it is electrically non-conductive¹, spray away...
    ¹ - I had a '74 Jeep w/ a Buick V6 that would stall if you drove it by a drinking fountain. Carried a can of WD with me and when it did I'd pop the distributor cap and we down the rotor and cap with it, then put the cap back on and spray the coil and wires for good measure--it would pop right off after that and run great until the next fording...
  16. Mar 31, 2017 at 4:37 PM
    Cazzwell
    Cazzwell The Circuit Rider Signman
    2018 Silver Sky DCSB TRD Sport
    Stock.
    You're right about the naming.
    But it wasn't designed to be a lubricant as many think. It was designed as a parts cleaner for the atlas missiles.
    It is hygroscopic which will attract moisture back into whatever you spray it with and make it rust again. It will penetrate the rust to dissolve it, but will need to be followed up with a propper lubricant (mineral, Teflon, graphite).
  17. Mar 31, 2017 at 4:40 PM
    cliffyk
    Cliff
    Saint Augustine, FL
    Oh, you can buy replacement horns at , $8 with one of their 20% off coupons. Pretty much the same as the OEM horns, if the chrome bothers you just hit 'em with some flat black from a rattle-can...
  18. Mar 31, 2017 at 4:51 PM
    cliffyk
    Cliff
    Saint Augustine, FL
    As I stated WD-40 was not designed as such and is a crappy lubricant; however it is not hygroscopic though this is a common myth. Being 90-95% petroleum based hydrocarbons (here's the MSDS) which are immiscible with water it fundamentally cannot be--nor will it dissolve in water. If it were hygroscopic this would be near impossible to prevent.
    Wikipedia has a great entry about it
    This is from the MSDS:
  19. Mar 31, 2017 at 4:53 PM
    TheCookieMonster
    TheCookieMonster cookies!!!!!!!!!!!
    North East
    1995 Hi Lux 22re 4x4 5speed
    Michelin MS2 K&N drop in filter
    nice infos, never knew this
