Mozy Online Backup
Discussion in 'Off-Topic Discussion' started by Hotdog, Jul 30, 2008.
  1. Jul 30, 2008 at 7:15 PM
    Hotdog
    Hotdog [OP] My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    Anyone here use Mozy online backup service? www.mozy.com
    I just signed up for it and it is taking forever. I started uploading 320 gb last night and it is only 1% done. :confused: I hope that it will speed up later on.
    I payed $95 for unlimited uploads for 2 years.
    There is also a free 2gb backup service.
  2. Jul 30, 2008 at 10:25 PM
    genxer36
    genxer36 Lord of Tomfoolery
    Sean
    Bethlehem,GA
    Tow package, XM Satellite radio, K & N Air filter, & Channel Vent Visors
  3. Jul 30, 2008 at 10:31 PM
    eordonez
    eordonez Living vicariously through mjp2
    Ed
    Chihuahua, Mexico
    TRD Sport Dcab 4x2 Black Sand Pearl
    OEM All Weather Mats, wheel locks, Toyota Silver Tube steps.....
  4. Jul 31, 2008 at 6:29 AM
    Hotdog
    Hotdog
    Wet Okole Underwear
    those are good sites but do not meet my needs. I wanted something that will auto sync my computer and an online backup. Also, I've got 300+ GB that needs to be backed up.
  5. Jul 31, 2008 at 5:40 PM
    piercedtiger
    piercedtiger Devout Atheist
    Jon
    Southern Tier, NY
    2015 F150 3.5EB SCEW 6.5ft
    How do you think I feel? I have 1TB that needs backing up. :( I'm still looking for a solution. No way in hell I'm backing that up online... Upload speeds are too slow. You're probably limited by your ISP, not moxy.
    I've been looking into one of these:
    http://www.newegg.com/Product/Produ...Server+-+Systems-_-Hewlett-Packard-_-59105382
    file redundancy, hot swap sata bays, backs up PCs in the house, can restore via network and boot CD.
    Figured I'd get the 500gig version, and move files around to be able to add my 2 250's and 750 gig drive with maybe my 3rd 250 as a usb or eSATA. Then migrate it to 1tb drives as the prices come down. :D Or just stock it full of 1tb's if the price is low enough by the time I can afford the server. :laugh:
  6. Jul 31, 2008 at 7:11 PM
    genxer36
    Sean
    Bethlehem,GA
    Sounds like you need EMC corp for a mirror backup.
  7. Jul 31, 2008 at 7:24 PM
    rhoppas
    rhoppas Land of Oz
    Topeka, KS
    07 Double Cab V6 TRD Sport Tow
    Earnhardt Cannons, Terra Grapplers, Viper alarm, Hunter4x4 Bull Bar, 6" Pro Comp Off-Road lights, extra set of bed D-rings, Chrome exhaust tip, Metra Ipod/MP3 adapter, Garmin GPS, CarriageWorks grill, Maglite mounted to driver seat, 9" Stubbie Antenna, WeatherTech floor liners, Saddleman Neoprene seat covers, DeeZee bed mat
    Once it gets everything backed up initially it should only backup things that have been modified, therefore it will not have to run very often. Getting that initial backup uploaded is painful though...
  8. Jul 31, 2008 at 7:26 PM
    piercedtiger
    Jon
    Southern Tier, NY
    I've seen those drives. Any idea how many external USB enclosures I've had come into my office in the last month because the drive failed? :rolleyes: No. I'm not putting everything on a single drive. Maybe 2 of them, manually mirrored, but not just 1.
    Mirrored RAID's are fine, but I'd like RAID5 at least for a little better performance with the redundancy. Also, by the specs for Windows Home Server I could technically lose more than 1 drive and be fine (assuming both copies of each file aren't on the drives that fail). The other thing is, I have 3x250gig and 1x750 drive in use. I might as well keep using those since they're new and work, but all RAID arrays I know of require identical sized drives. Or you'll only be able to use as much as the smallest drive in the array. WHS actually uses software to copy files to 2 drives, with an index (or shadow copy maybe) on 1 drive. If you remove one of the drives the other copy becomes master so you never lose access while a drive is down or being replaced. That also means you can mix and match sizes so I'd be able to reuse what I have until I can buy larger ones. Although, there is some data corruption bug still in the OS from what I hear. :rolleyes:
  9. Jul 31, 2008 at 7:27 PM
    Evil Monkey
    Evil Monkey There's an evil monkey in my truck
    Robert
    Escondido, CA
    07 4x4 DC SR5 TRD Off-road
    Weathertech front & rear mats, rear suspension TSB, Toytec AAL for TSB, Hi-Lift Jack, Bilstein 5100 & Toytec Adjustable coilovers, Built Right UCAs, KMC XD 795 Hoss Wheels, Definity Dakota MTs 285/75R16, Leer XR, Thule Tracker II & Thule MOAB basket
    I like the Western Digital MyBook drives (1 TB from WD). They're about equal in cost to buying a drive and an enclosure and the software works well. I set it up on a small server at work. I have an older version that does full backups once a week and incremental backups daily. The newer ones backup on the fly. They're very quiet and sit well on a desk.
  10. Jul 31, 2008 at 9:14 PM
    Hotdog
    Hotdog
    Wet Okole Underwear
    hmmmm...what have I succumbed to...
    My main pc has mirrored 500 gig hard drives. I've got a slide in backup drive that is 500 gigs that I do whenever I've added important files. I've got an older PC that I'm setting up ubuntu on and I will use that to operate as a in house file server but also as a backup server. I've got assorted drives lying around that have various stages of my data.
    My house would have to burn down or flood for me to lose all my pictures, music, videos, software, etc...Hence the offsite storage. I've never lost all my data, and hopefully now, it will be just about impossible.
  11. Aug 1, 2008 at 4:42 AM
    piercedtiger
    Jon
    Southern Tier, NY
    OH!!! I HATE THOSE THINGS!!!!!!!!! :mad: :mad: :mad: :mad:
    I have bits and pieces of half a dozen of them sitting in the shop, and another one came in last week! You have to jam a screw driver in 4 different slots and practically break the damn thing to get it open and replace the drive. :mad: Which of course voids the warranty if you still have one. But it's necessary if you want to attempt to clone it to recover your data before you ship it back to WD for replacement. :rolleyes:
  12. Aug 1, 2008 at 8:19 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    That's a lot of porn.
  13. Aug 1, 2008 at 8:20 AM
    Hotdog
    Hotdog
    Wet Okole Underwear
    Only 290 gb of that is actually porn. The other stuff is just erotica.
  14. Aug 1, 2008 at 8:31 AM
    mjp2
    NJ
    True connoisseurs can distinguish between the two. I am humbled by your expertise. :D
  15. Aug 1, 2008 at 9:44 AM
    eordonez
    Ed
    Chihuahua, Mexico
    Zoofillia pornography must take a lot of space.....:eek:
    You feel sexual pleasure on animals dressed like humans?? Im gonna start searching some of that stuff and post it on the MM thread so you wont close it....
  16. Aug 1, 2008 at 9:46 AM
    klown
    klown Tacoma World Ring Leader
    Lynchburg, VA
    2008 TRD sport 4x4 double cab 6-speed
    Black, leather and heated seats, borla sport exhaust, side curtain airbags, daytime running lights, all weather mats, JBL premium 6 disk changer system, stainless step tubes, window tint, tow package
    Damn, do you guys have ALL of the porn on the internets? No wonder I can't find porn on the internets, it's all on your guys hard drives.
  17. Aug 1, 2008 at 9:47 AM
    klown
    Lynchburg, VA
    Triangle dude, how much ransom you asking to release my pet?
  18. Aug 1, 2008 at 9:55 AM
    piercedtiger
    Jon
    Southern Tier, NY
    lol My wife doesn't let me have porn... Or did anyway.... :devil: We had that fight a couple years ago and my collection got shit canned. (I have a few things hidden on my xbox now tho.... :D )
    Most of mine is non-porn action/comedy movies, kids movies, TV shows (entire seasons of some), about 100gig of MP3's, and nearly 200gig of xbox games. I'd love to back up the xbox games too incase that drive ever crashes since it's a pain in the ass to download them all again, and I thought I'd lost the drive once already. But a week in the freezer, and a month or two later it was working again. :confused: Just had to reinstall the dashboard to get it booting again.
  19. Aug 1, 2008 at 9:57 AM
    klown
    Lynchburg, VA
    Yeah my wife doesn't let me have porn either. I don't even have a place to stash it like you.
  20. Aug 1, 2008 at 10:04 AM
    piercedtiger
    Jon
    Southern Tier, NY
    Burn to CD/DVD and hide those.... :devil:
    Just make sure you clean your history and Recent Documents folder on the start menu. :thumbsup:
