mpg down after changing from 89oct to 87oct
Discussion in '4 Cylinder' started by emacpgh, Oct 25, 2009.
  1. Oct 25, 2009 at 10:46 PM
    emacpgh
    emacpgh [OP] Well-Known Member
    eric
    pittsburgh
    silver streak mica sr5 sport
    Aries stainless steel bull bar , afe pro dry s filter , secondary air filter removal, scangauge II
    i was getting around 25 to 26 mpg on the hwy when i was using 89oct. gas. i changed to 87oct after being swayed by my internet research where people universally said that premium gas was a waste of money. I have ran three tanks of 87 and my hwy milage has dropped to about 21 mpg:(!! could this be from the computer not readjusting to the 87? over 1000 miles seems like a long time to adjust. anyone else downgrade to 87 and see similar results?
  2. Oct 25, 2009 at 11:07 PM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    I upgraded from 87 to 89 or 93 (depending on gas station/ethanol content) and noticed a significant improvement. Ethanol has had the most affect than any other variable in fuel.
  3. Oct 25, 2009 at 11:15 PM
    crawl
    crawl Well-Known Member
    Greg
    Valencia, CA
    2010 reg cab 4x4 sr5
    my motor seems to like the more expensive juice too. don't second guess yourself - your own test results are better than any advice from the internet universe.
  4. Oct 25, 2009 at 11:16 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    If you really wanna find out whether or not its saving you anything....Figure out the COST PER MILEfor each octane. That'll let you know exactly how much money you're paying PER MILE based on what your gas prices are.
    For example:
    Cost per gallon divided by the MPG will give you cost per mile.
    Do this for each octane and costs involved.
  5. Oct 25, 2009 at 11:23 PM
    DanGer
    Thats what I did and found that ethanol free 93 and 89 both got me to almostthe exact same price per mile as 87. I just have longer to go between fill ups, but I dont save or lose money
  6. Oct 27, 2009 at 1:26 PM
    JDCPA
    JDCPA Well-Known Member
    Jim
    SW FL
    09 5 Lug Access Cab SR5
    Curt Hitch and etrailer.com wiring harness.
    Shell 87
  7. Oct 27, 2009 at 3:51 PM
    neslerrah
    neslerrah Taco lovin'
    Harrelsen
    Tucson
    5 lug BEAST!
    Secondary air filter removed, elbow mod, BFG T/A KO (31x10.5R15), 15" American Racing Mojaves, BHLM, Dome Light MOD (Blue), Pioneer headunit, Sockmonkey 'TACOMA' Decals, Readylift 5-lug SST, Rear Shocks - Bilstein TRD, Dynomax Super Turbo #17748, DDM Slim Ballast HID Kit H4 Hi/Lo -35W 6000K in headlights, Apexcone Raptor HID Kit H3 - 35W 6000K in Hella 500s, aFe CAI #51-10762, WeatherTech Floorliner, 200W Smart AC Inverter
    I would suggest going back to 89 for the next couple of tanks and see how your MPG is affected. After I installed my lift and wheels, I started to use Shell 89 in town, when I travel on the highway I use Shell 91.
  8. Oct 31, 2009 at 4:40 PM
    def4pos8
    def4pos8 Well-Known Member
    Ohio
    White Tacoma AC 2.7L/5spd SR5
    undercoat, running boards
    The computer likely DID adjust to the reduced octane fuel -- by dialing back spark advance. The new ECUs ARE that sensitive.
    My 2010 Taco (and Wifey's '09 Honda Fit, FWIW) runs much more smoothly on Shell 93 than the wonder water the dealer bought for the initial fill. I ran 93 in my Taco's predecessor because detonation demanded it. I use it in the Taco because it just works better.
  9. Nov 1, 2009 at 4:42 AM
    Flyinhigh
    Flyinhigh Well-Known Member
    GA
    2018 SR DCSB 4x4
    i use shell or ampco 87 and always get 26-27 at fill ups i usually try to use one or the other and stay away from racetrack and places like that
