MPG Mods
Discussion in '4 Cylinder' started by kylefrdavis, Apr 20, 2009.
  1. Jul 8, 2013 at 12:42 PM
    #741
    91r100gs
    91r100gs Understand the Voice Within
    Dan
    Kansas City area
    '08 Impluse Red SR5 I-4
    Factory bed mat, TacomaWorld.com sticker, EGR In-Channel Vent Visors, AFE ProDryS drop in air filter
    Welcome to the forum Janine, :rimshot:
    Lots of good info here on any subject. Mods R Us
    Need a pic of the Tacoma, it sounds nice!!
  2. Jul 10, 2013 at 9:29 AM
    #742
    wiknern
    wiknern New Member
    nils
    clayton, N.M.
    07 Tacoma sr5
    My Toyota dealership (Street Toyota, Amarillo, Tx.) Recommended
    an EFI service ($150). What does that exactly entail, and why is it
    that costly? Also, any other way I can maximize fuel economy other
    than keeping my truck properly maintained, tire pressure up, etc?
    I have a K&N filter in my 07 Tacoma which helps some.
  3. Jul 11, 2013 at 10:08 AM
    #743
    ThrSitRep
    ThrSitRep Member
    Greg
    Puna, Hawaii
    hilomoto.com
    Frantz bypass oil fiter
    I get 31 mpg on my 2012 2.7 base
    I use M1 0w20 to which I add Molybdenum.
    I have a Frantz bypass filter and I change the sh!tpaper in it at 2500 and change my oil at 5K. I also use a Napa gold oil filter (it's twice the size of stock Toyo filter) which is relocated to the firewall passenger side for clean no mess filter change.
    My totally oil capacity is 7 qts.
    I burn virgin (non-ethanol) 89 octane Top Tier fuel to which I add 3 oz / fill Techron and 1 0z TCw3 oil/ 5 gallon gasoline.
    My goal is to get 35mpg.
    If you leave your filter in and just pull the cover off to the side you just need to drill the rivet off one corner then you can just get a hold of the corner of the filter and rip it off. blow away any debris. boom ur done.
  4. Jul 11, 2013 at 10:33 AM
    #744
    ThrSitRep
    ThrSitRep Member
    Greg
    Puna, Hawaii
    hilomoto.com
    Clean your MAF
    clean throttle body
    check your TPS
    Check thermostat
    Use lighter wt oil 0w20 and moly.
    start adding TCw3 oil to your fuel at 1 oz:5 gall ratio
    If you can't find non-ethanol gas then only use Chevron, Texaco or shell.
    Use lower octane fuel 87
    Use some Techron (whole bottle on half tank)
    Service your tranny replace all fluid with syn ws-T-IV
    get stock high mileage tires and max inflate
    Is a check engine light on? (O2 sensor)
    Get rid of any bullshit like racks, brush guard and any excess weight.
    If it is lifted, un-lift it.
    Drive smart.
    I get 31 mpg and I'm going for 35.
  5. Jul 11, 2013 at 10:37 AM
    #745
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    Join the fun on this thread.
    35mpg is possible, I've had tanks as high as 37.7. I'm jelly you can get E0, E-10 is all I can get and it sucks.
    http://www.tacomaworld.com/forum/4-cylinder/174620-4-bangin-fuel-sippin-full-tank-challenge.html
  6. Jul 11, 2013 at 10:55 AM
    #746
    ThrSitRep
    ThrSitRep Member
    Greg
    Puna, Hawaii
    hilomoto.com
    Oops!
    I'm an idiot, I just saw that it is an 88. some of my post does not apply.
  7. Jul 11, 2013 at 11:10 AM
    #747
    adriancast
    adriancast Well-Known Member
    Adrian
    Upland, Ca
    2005 Tacoma 4x4 TRD Off-Road
    -2.5 Donahoe Coilovers -All Pro Standard Leaf Pack -All Pro U Bolt Flip Kit -Firestone Airbags w cradles -Extended rear Bilstein 5100s -Flowmaster 40 Series -All Pro IFS Skid -All Pro Transmission Skid -Bruteforce Hybrid Bumper -30" Double Row LED bar -400 Watt Anytime -TRD Seat Covers -ABS Kill Switch -Locking Center Console Mod -Rear Differential Breather -BHLM -Anytime Fog Light Mod -Toyota Hilux Snorkel
    Get a softopper. They weigh less than camper shells.
  8. Jul 11, 2013 at 2:00 PM
    #748
    91r100gs
    Dan
    Kansas City area
    It is one of most profitable services for them. They are trying to soak your wallet. That is why they are sometimes referred to as %$&(#$%^&. Go read the 4 banger fuel sipping challenge thread in the 4 cyl section. Lots of good advice int that thread.
  9. Jul 12, 2013 at 9:02 AM
    #749
    piglett
    piglett Member
    wolfeboro,nh
    01 exstended cab TRD
    sounds like the timing may have jumped
  10. Jul 20, 2013 at 3:13 PM
    #750
    josepenajr
    josepenajr Well-Known Member
    Laredo , Texas
    13 Texas Edition Double Cab
    3 inch lift, Painted black rims, black bull bar, black bug deflector, Black PlasTi Dipped Emblems, 275/70/17 Tires
    any advice for a 2013?
  11. Jul 31, 2013 at 9:17 PM
    #751
    bbatka
    bbatka Member
    brad
    chicago
    96 taco 4x4
    Amsoil in both differentials and transfer case..... 1.3mpg gain. Amsoil signature oil and I'm getting 2 mpg over stock.
    I know this is my first post, and I'm an unknown entity here, but bear with me please. This is not a sales pitch either, I swear. I have a '96 Tacoma 4x4 v6. Agreeing that a 4x4 will never get comparable MPG to a 2WD, I've noticed most people mention synthetics, but not changing ALL the lube fluids with synthetics. I want to say, if you go synthetic, go all the way and put synthetics in your differentials, transfer cases, and trans. Each component adds a little bit, but in total, the effects add up. 4x4s will see the greatest gains from synthetics due to the additional front differential and transfer case (friction/resistance). I bet you will gain 5-10% if you own a 4x4.
    Use whatever synthetic brand you want, but synthetics do perform better than conventional oils by reducing friction and resistance. Almost everybody has tried just about everything under the sun, but I'm impressed with my gains. I began by going to full synthetic oil in the engine. Mobil1 was my first choice because it was readily available. I did gain a little bit, probably about a half MPG.
    Then I researched gear lube.... I settled on Amsoil (because of the 100,000 mile lifespan) in both differentials and transfer case. Fluids were due to be changed anyway- so had to try it..... and DANG if I didn't go from 20 MPG (stock) to 22MPG (oil & gear lube) on the highway (keeping it under 70). I'm sold on this stuff. The first change of Mobil1 and filter was good for 7,000 miles. SWEET! But then I thought about it and realized I wanted more. So I switched to the signature Amsoil and I can't complain about anything. The cost is more, but so far the oil hasn't really even started to get dark with 12,000 miles. Choose the Mobil1, RedLine, or Royal Purple filter, as long as its top-of-the line for synthetics. I haven't noticed any thickening yet either.
    The oil is not 3 times more expensive than conventional oil, so I'm actually saving money and saving oil. Now that's "efficiency" too, ya know.
    Consider: The cheapest conventional oil is 3.99/qt, so that's $20 for oil plus $8 mid-range filter= $28 every 3,500 if you're lucky. Compared to approx $50 for top-of-the-line synthetic, and $12 for a filter= $62. I'm already at 12k, so 3 times 28= $84. I'm already $12 ahead, allowing me to buy more gas.... Thereby in essence increasing my fuel range and overall efficiency even more. Think of MPG as an overall cost per mile driven.
    That's my take on efficiency. Stew on that a while.
    Just my perspective.
  12. Aug 5, 2013 at 9:43 PM
    #752
    euro911s
    euro911s 'Plays with Toys'
    Mark
    So Bay, So Cal
    96 Tacoma 4x4, V6, Ex Cab
    I used to have a a TRD supercharger on the Tacoma, converted back to NA when I bought the Tundra. The SC was tons of FUN!!!
    My first Toyota was an '89 2.4L EFI 5-speed 4x4 Ex Cab. I ran a 100# Sprint 'Competition' shell and had 31x10.50R15 Goodyears on it. It only got 13~15 mpg city, but high 20's on the highway.
    My '96 Tacoma is equipped the exact same way, but it has the 3.4L V6. It too only gets 13~15 city, but only 19 on the highway.
    My 2002 Tundra has the 4.7L V8/auto and a Snug Top bed lid ... it only gets 10~12 city and 16~17 hwy :mad:
    I recently went with a little narrower tire, Goodyear Fuel Max M+S 245/75-16, and saw a mild mpg increase.
    The main reason 4x4s get worse mpg than 2WDs is that the differential gearing is lower. I've been looking into changing the gearing on the Tundra's diffs. I'd like to get the hwy mpg up to 20.
    Guess I'll check on synthetic fluids too.
  13. Aug 14, 2013 at 4:38 PM
    #753
    shunut
    shunut Active Member
    Josh
    Gilbert, AZ
    PreRunner SR5 Magnetic Grey
    None... yet
    What does this do to increase your MPG?
    AFE air filter VS AFE air filter and secondary air filter removed VS Full CAI
    Is one better than the other for higher MPG?
  14. Aug 14, 2013 at 4:48 PM
    #754
    91r100gs
    Dan
    Kansas City area
    My best MPG over a period of similar driving conditions, was with the OEM air filter with the secondary filter removed.
  15. Aug 14, 2013 at 6:46 PM
    #755
    tooter
    tooter play every day
    Greg
    Los Angeles
    2012, std cab, 5 lug, 2.7, 5 speed
    Built for maximum low end torque, tooter II.VII intake manifold spacer, LCE long tube header, Injen long tube intake, 2,900 rpm torque peak.
    My latest fillup was 28.0mpg with a mix of stop and go city traffic and freeway. This is with intake and exhaust mods.
    Warm weather always helps. :)
  16. Aug 14, 2013 at 7:46 PM
    #756
    worthywads
    No intake will improve mpg.
  17. Aug 15, 2013 at 4:47 AM
    #757
    shunut
    Josh
    Gilbert, AZ
    None... yet
    So do they hurt your MPG? or Do they do nothing either way? And what about just removing the secondary filter and running an OEM filter?
  18. Aug 15, 2013 at 2:04 PM
    #758
    91r100gs
    Dan
    Kansas City area
    That has been my best combination. although removing the secondary filter can cause problems in areas where emissions testing is done. Probably not to many inspectors would catch that.
    The main reason I put my OEM filter back in was that when cruising on the interstates, the AFE ProDry S made a moaning noise, like a cat in heat. Gets to be annoying on long trips.
  19. Aug 15, 2013 at 3:33 PM
    #759
    shunut
    Josh
    Gilbert, AZ
    None... yet
    I brought my GTI through inspection here in AZ a little over a year ago. I have a CAI, 3" turbo back exhaust, aftermarket diverter, ECU Tune and various other mods, and the inspector didn't say a word. So, I think if I removed the secondary air filter, as long as it doesn't mess with any of the readings they pull via the OBDII port, I should be good.
  20. Aug 15, 2013 at 4:29 PM
    #760
    91r100gs
    Dan
    Kansas City area
    Like I said, a slim chance but making sure you are aware of it.
