MPG Mods
Discussion in '4 Cylinder' started by kylefrdavis, Apr 20, 2009.
  1. Dec 15, 2017 at 8:25 AM
    #1181
    Bowers86
    Bowers86 Well-Known Member
    Vancouver, WA
    2013 RC 2WD 5-speed
    Access Cab Buckets, OE backup cam, AFE Air Filter/Secondary filter removed/Fender Elbow removed, Magnaflow 11225, XII springs/4x4 leafs/XR Bilsteins, Prodigy P3 brake controller, 3.73 Third, Undercover Tonneau, Koomus CD slot iPhone mount, Paint matched rear bumper, Drag 18x9 et20 wheels, 3rd Gen Airdam.
    It's a literal plug-n-play into the OBD-II port near the hood release.
  2. Dec 20, 2017 at 3:42 PM
    #1182
    Indy
    Indy Master of all I survey.
    Possibly. Over inflating will make the centers wear faster, the only way to know if 38 is overinflated for your ride is to check your patterns. Saving money on gas but buying more tires isn't a savings.
  3. Dec 20, 2017 at 4:08 PM
    #1183
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    Hmm, yes your wear may vary, but I've been running 45psi for decades with no evidence of more wear in the center, probably those bias plys did that but not radials from my experience.
  4. Dec 21, 2017 at 12:33 PM
    #1184
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    Overinflation will reduce the tread contact patch and therefore reduce rolling resistance (and increase MPG) just remember that a smaller contact patch also means less traction. So don't go overboard. I run 35 front/32 rear (standard 5-lug radial tires) which is 6psi extra in the front -- on an unloaded truck, the size of the contact patch is about equal front/rear with these pressures. I usually let a few pounds out of the tires during wet weather to provide better traction, since they are overinflated to begin with.
  5. Jan 11, 2018 at 7:59 PM
    #1185
    Ziggy the Piggy
    Ziggy the Piggy Member
    2004 Tacoma Double Cab 4x4, 3.4L V6, Gold
    Westin Bull Bar (Black), Aftermarket Rims (Silver & Black)
    I bought the AFE Pro Dry Air Filter from Auto Anything about 3 yrs ago, zero problems since. Take it out clean it off with a vacumn cleaner and pop it back in, no oil necessary like K&N. I noticed a boost in horsepower after putting the initial one in the first time & it's worth the extra cost.
    donny likes this.
  6. Feb 1, 2018 at 5:38 AM
    #1186
    datilderek
    datilderek New Member
    2015 Silver Tacoma Base
    Intermittent wipers, cruise control, backup camera
    Subscribed.
    Will start with removing the carbon filter and adding an AFE Pro Dry Air Filter. Already using 0W-20 synthetic oil, and will use synthetic transmission and rear differential fluids when I replace them at 50,000 - 60,000 miles.
  7. Feb 1, 2018 at 5:57 AM
    #1187
    worthywads
    If you've read this thread you would know that intake modifications do nothing for mpg. Waste of time.
  8. Feb 2, 2018 at 5:08 AM
    #1188
    Indy
    The only way to see ant difference in an simple bolt on is with a dyno. It's not going to be noticeable.
  9. Feb 16, 2018 at 12:42 AM
    #1189
    kalaukia37
    kalaukia37 Member
    Bob
    Hawaii
    SR5 3.4L 5 SPEED
    ALARM, BEDLINER, OPEN AIRBOX, WHITE LETTER TIRES, RUSTPROOF,STAINLESS WHEEL GUARDS, HOOR AND WINDOW SHIELDS, ETC.
    Aloha Guys, I Live Here in Hawaii. We are Allowed to put on Headers, and Other Filters. We DO NOT HAVE A DRAG STRIP! Property is JUST TOO EXPENSIVE! I have A 4x2 1998 SR5 V-6 5 Speed Extra Cab. I have had it for Almost 20 Years. Hardly ANY Trouble at All. With Only 90,000 original Miles on it. Always Maintained and Enclosed Garage, Plus Always Use Mobil Synthetic Fluids. Will Keep this truck Forever.
    May You All BE Blessed Forever!
    Aloha Hawaiianbob
    tacoburrito likes this.
  10. Feb 17, 2018 at 4:43 AM
    #1190
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    I agree "never have to buy a new filter again" I got the air filter and made a cabin filter - I just clean them when I do oil change if they look at all dirty - again "never have to buy a new filter again" can't beat that.
  11. Feb 17, 2018 at 6:28 AM
    #1191
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    only thing is how well does the AFE filter filter out harmfull particles that could end up inside your engine compared to a OEM paper filter? if you get a more free airflow from the AFE that means less restriction (filtering) and more harmfull particles getting by the media into the engine.
    ClassicVW likes this.
  12. Feb 18, 2018 at 6:00 PM
    #1192
    tuanhuy0301
    tuanhuy0301 Well-Known Member
    2017 Tacoma SR DCSB 2.7l 4X2
    I just test out mine 2017 4x2 SR DC, 47 miles on highway and get 30 mpg. Truck is stock with sr5 alloy wheel, 34psi front and 32 psi rear. Keep speed around 60-65 mph.
  13. Feb 24, 2018 at 12:15 AM
    #1193
    Norsemanvike
    Norsemanvike Well-Known Member
    Escondido, CA
    '18 Sport 4x4, DblCb, ShBd, BBP
    56
    Correct me if I'm wrong, but one of the catalysts of MTBE being outed and eventually stopped was animal scientists discovering through necropsies being conducted on Bald Eagles and the eggs they crushed when they sat on them. The MTBE consumed by the Bald Eagles in their dietary sources caused their egg shells to be thin, so this became a federally investigated Who Done It to save our national bird. Before MTBE was approved, the only companies that wanted it approved were the ones developing it while everyone else railed against it. The EPA bowed to the financial wooing of the MTBE makers. The EPA is just as corrupt as every other agency that is allowed to impose their own regulations without congressional approval. They're not completely evil, but they are certainly this is overzealous and too big for their britches.
    To tie this this in with MPG part of this thread, the EPA regulations are what drive manufacturers to increase MPG's from the factory as best as possible within reason for the consumber. Manufacturer's are always tinkering with ways to improve it, but not always successful. Also take into consideration that big oil/gas companies also work against better MPGs so that they can retain their built-in flow of money. My brother misses the old days where he could just punch a few pin holes into a carb or something like that and get almost x1.5 improvement on his MPGs. I know little about engines, so I'm not sure what he's talking about, but my old '91 Civic used to get 40mpg new and 39 when I sold it 8 years later. Tacos could get better MPGs but it's up to us to figure out legal ways of doing it.
    I like the suggestions in this thread so far and have about 3-4 more pages to go. :D
  14. Feb 24, 2018 at 1:10 AM
    #1194
    Norsemanvike
    Escondido, CA
    So, for a '18 Sport, DC, 5' bed, 4x4 ( planned purchase )...
    1) AFE Pro Dry Air ( for HP, not MPG )
    2) Driving habits ( try not to exceed 2000 rpm is my take away )
    3) Increase front tire pressure by +2/3 over rear
    4) Synthetic oil ( change others when the time comes )
    5) Hard top bed cover
    6) Stick between 65-70 MPH
    7) Chip from autochipsdirect.com ( ? )
    8) Discard unnecessary weight from vehicle, i.e. spare tire? Makes sense if you have roadside assistance and can get a free tow home.
    Am I missing anything? Is something listed unnecessary?
    I'm okay with driving at or just over the speed limit for one reason... It makes sure that someone else is always faster than you, so they'll get the speeding tickets instead of you and the middle lane of the interstate is just fine and perfectly legal. Of 'course, this gets thrown out the door with the Oceanside, CA PD motorcycle cops since they write up their own lieutenant's wife for being 3mph over the limit ( I fell victim to them twice ).
  15. Feb 24, 2018 at 8:13 AM
    #1195
    worthywads
    9) Drive like your brakes don't work.
    If you drive in a way that requires you to slam on your brakes a lot you are doing it wrong.
    10) look further down the road and anticipate the lights, no need to rush to the next red light.
    None of the things listed above will have as much effect as smart driving.
    ecoterragaia and DGXR like this.
  16. Feb 24, 2018 at 8:31 AM
    #1196
    worthywads
    You are confusing DDT with MTBE. Your conspiracy theory doesn't work
    ecoterragaia likes this.
  17. Feb 24, 2018 at 8:49 AM
    #1197
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Many don't drive with mpg as a priority but there will be times when it's a useful ability. Like most things, doing it well requires enough practice fostering the right habits to make them stick. Removing roof racks(or any other crap) when not in use is also really helpful.
  18. Feb 24, 2018 at 10:17 AM
    #1198
    Norsemanvike
    Escondido, CA
    LOL - I stand corrected.
    worthywads[QUOTED] likes this.
  19. Mar 3, 2018 at 1:06 PM
    #1199
    Thulsa Doom
    Thulsa Doom Well-Known Member
    Manderthal
    Rhode Island
    2012 Tacoma regular cab 4x4 automatic
    Since aluminum wheels weigh less (but cost more) than steel has anyone switched to aluminum wheels and found any real life MPG benefits?
  20. Mar 3, 2018 at 6:49 PM
    #1200
    SilverToyTaco2012
    SilverToyTaco2012 Old Enough to Know Better, Young Enough to Try
    Al
    Central Coast CA
    '12 4x4 TRD Off Road
    Stock!
    Tires, Tires, Tires. the more knarly the thread, the worse the MPG (in my experience). I have got 200k on my 2012 Taco and every time I move to a more "off-road" pattern with Thicker Sidewalls the MPG drops. Go back to Street tires with the thinner sidewall and the MPG pops back up. I am certain the weight is an issue and I suspect the tread pattern effects the rolling resistance too...
    BillsSR5 likes this.
