Mph/Rpm ?
Discussion in '4 Cylinder' started by Veder225, Feb 27, 2021.
  1. Mar 3, 2021 at 5:55 PM
    #41
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    If it makes you feel better.
    You aren’t the first person to do this.
    I can’t find the post, but there was someone else that did the same thing.
    But I think it was on the 4.0 Auto truck.
    All good, Carey on man.
    Enjoy your truck:thumbsup:
    Veder225[OP] and Bikinaz like this.
  2. Mar 3, 2021 at 6:00 PM
    #42
    TnShooter
    Deogee
    STOCK
    Veder225[OP] likes this.
  3. Mar 3, 2021 at 6:19 PM
    #43
    rphillips
    rphillips Well-Known Member
    Rick
    Norene TN.
    2013 Reg. cab 4x4
    none
    Glad you got this figured out, & glad all is well with your Taco. Congrats, great little trucks. But now you've got me second guessing myself. I know I've read that "all" reg. cab 4X4 Tacos since "05" or "07" or something came with 4.10 gears, no matter what trans. they have. Now I can't find it. I did find this, a Google search for 2005-2016 Tacoma axel code. My 2013 has the code A02A & that by that chart is a 4.10. Now your dealers service man says 3.58. I searched your tire size (30.5") with 3.58 gears, & @ 70 mph will be running 1932 rpm. From the gear ratio charts, if your taco's tach shows just above 2000 rpm (2177) @ 70 mph, you will have a 4.10 gear, if your Taco's tach shows just under 2000 (1932) @ 70 mph will have a 3.58. Dang this is confusing.
  4. Mar 3, 2021 at 6:44 PM
    #44
    Bikinaz
    Bikinaz It wasn't me!
    Hey You!
    Phoenix, AZ
    2014 Regular Cab 4x4 5MT
    Pelfreybuilt Skids. ModCo wheels. Sliders. Cruise Control. Intermittent Wipers. Fog Lights.
    Hey, my kid can't drive a manual. :D
  5. Mar 4, 2021 at 5:40 AM
    #45
    pod74
    pod74 Member
    Wondering about this also, can anyone clarify? Thanks
  6. Mar 4, 2021 at 5:49 AM
    #46
    Dbarffish
    Dbarffish Well-Known Member
    Doug
    Montana
    2024 dcsb TRDOR blue crush
    Stock
    Another odd symptom of COVID-19- inability to find 4th gear! I hope this is your worst symptom. Glad you figured it out and hope you stay on the mend! Enjoy your Taco.
  7. Mar 4, 2021 at 7:46 AM
    #47
    JL8Jeff
    JL8Jeff Well-Known Member
    Jeff
    Ewing, NJ
    2013 Tacoma reg cab
    OME 885/nitros, SPC UCA, 305/65/17, AAL
    At least it was an easy solution! I had a feeling it was not in OD based on the rpm readings. I'm pretty sure all the 4x4 auto trucks had the 4.10 gears, it would be a real dog with 3:58.
    ABA180 and Veder225[OP] like this.
  8. Mar 5, 2021 at 6:45 PM
    #48
    Veder225
    Veder225 [OP] Active Member
    Bill
    Toyota tacoma reg cab 4x4 2.7 liter
    none
    My door sticker shows A02A also, the dealer showed me where the code was. I wrote it down and found a chart on here (Tacoma World) from 2015 posted by a chris4x4. I've been doing some research everything else I've been reading says the 2.7 liter with 4x4 got a 4.10 gear. The only one I read about with a 3.58 was a reg cab 2.7, 2x4. I'm reasonably sure I miss read or missed something on that chart from 2015, I'm very sorry about that.
    Regardless my truck runs and drives great now. I want to recondition the undercarriage this summer. There's some surface rust mainly on the axles and knuckles, only a few small spots on the frame. I also noticed the skid plate is missing, someone cut the bolts off flush but that I can fix and replace relatively easy as long as it doesn't require shifting ha ha.
  9. Mar 5, 2021 at 7:44 PM
    #49
    rphillips
    Rick
    Norene TN.
    2013 Reg. cab 4x4
    none
    Now that you got that figured out, Rekon your little Taco could use a little more pep?? I've just installed a throttle controller on mine. I've been disappointed with it since I got it a couple yrs. ago. Just seemed weak & sluggish. Not any more, very happy now. Just want folks to know, for me the throttle controller really woke the thing up, like driving a completely different truck. May be worth researching & checking in to.
  10. Mar 9, 2021 at 4:13 PM
    #50
    Veder225
    Bill
    none
    OK thank you I appreciate the info. I'm used to driving a jeep wrangler 2.4 cylinder with 33" tires. My taco does pretty good compared to the that. I'm used to getting in the right lane with the other herd of turtles. My biggest concern right now is the rising cost of fuel prices. I've noticed my taco is a little piggy on the interstate.
  11. Mar 9, 2021 at 5:42 PM
    #51
    JL8Jeff
    Jeff
    Ewing, NJ
    2013 Tacoma reg cab
    Yeah, these trucks with the 4 speed automatic don't do well with gas mileage. You want to keep it around 65 mph to max out your mpg, running higher speed will hurt the mpg.
  12. Mar 9, 2021 at 5:51 PM
    #52
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    A good solution..free! I suspected reading the thread from the start just now you might be doing that..I've put mine in 3rd before not thinking or realizing it.
    Same same, though I'm a 2WD that sounded way high
    Yup. I can do good enough on mine between 20-24 depending on where, but that's not carrying a transfer case around
    Veder225[QUOTED][OP] likes this.
  13. Mar 11, 2021 at 2:02 AM
    #53
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    I tested this yesterday on my way to work. I have 31" tires.
    At 70 MPH my tach is at 2200-2300 RPM.
    Stock gears, 4 cylinder, automatic transmission.
  14. Apr 28, 2021 at 8:20 AM
    #54
    Brian422
    Brian422 I fell into the pit that is TW
    Brian
    Birmingham, AL
    2012 DBCSB F/R Locked, 35's ,Long travel, 23 Tundra 4x4 limited
    Not Stock
    thats what mine is at with 5.29's. Yours should be much lower than that.
  15. Apr 28, 2021 at 9:00 AM
    #55
    rphillips
    Rick
    Norene TN.
    2013 Reg. cab 4x4
    none
    I love the West Coast differential charts. 31" tire, 4.10 gear, auto. W/OD, 70 mph = 2177 rpm... 31" tire, 5.29 gear, auto. W/OD, 70 mph... = 2810 rpm. Also found @ 70 mph., a Manual W/OD will turn appx. 400 rpm higher than an auto. W/OD.
