MrGrimm's Mall Crawler
Discussion in '2nd Gen. Builds (2005-2015)' started by MrGrimm, Jul 25, 2010.
  1. Oct 26, 2012 at 10:59 AM
    #601
    NYCO
    NYCO go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
    wow...f'in amazing work on the OBA and the pressurized can idea..
    how are the rock monsters holding up? is the 6x139.7 fit well? i've always seen our wheels specified as 6x5.5.
  2. Oct 26, 2012 at 11:04 AM
    #602
    theduck911
    theduck911 Max's Canadian Twin
    Max
    Northwestern Ontario, Canada
    Locked and Geared!
    5.5"x (25.4mm/1") is 139.7mm:cool:
  3. Oct 26, 2012 at 11:09 AM
    #603
    NYCO
    NYCO go explore...
    bOb
    Colorado
    dents & scratches
  4. Oct 26, 2012 at 11:16 AM
    #604
    MrGrimm
    MrGrimm [OP] Mall Crawler
    Dean
    Wisconsin
    2006 Toyota Tacoma 4WD w/TRD Sport Package
    See build page
    I havent had a chance to run the rock monsters below 10 psi but I am pretty confident that they will keep the bead on there. I want to make a run out to Anza and Ocotillo and really put them to the test. Hutchinson does offer these wheels in 2 other colors, a lighter gray/silver version and a black. Black would have looked pretty cool and I may end up getting these powder coated black the next time I need new tires.
  5. Oct 26, 2012 at 12:41 PM
    #605
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    Freeze runs his hutchinsons at 5psi always and he hasn't had an issue. from what I've heard, they work great.
  6. Oct 26, 2012 at 4:33 PM
    #606
    alegav
    alegav TeamBlue
    Alex
    San Diego, CA
    2012 Tacoma TRD T|X Baja
    Pelfreybilt IFS Skid, Mid Skid and Plate Bumper, Rigid Industries Dually's, ARB CKMA12 On Board Air, Kenwood TM-281A Radio, Rear view mirror relocation bracket, Wheelers SuperBumps, Toytec Baja Spacer
    So hawt, want to touch the hiney!!! Man you have done exactly what I want to do with an on-board air system. Was it difficult to integrate the quick disconnects?
  7. Oct 26, 2012 at 4:52 PM
    #607
    MrGrimm
    Dean
    Wisconsin
    See build page
    Super easy to setup the on board air. I had no experience putting an air system together so I read up a little bit on it and then went to the hardware store to piece together the disconnects and all the fittings. After the price of the compressor and the manifold, it only costs about $30 in fittings, disconnects and hoses. I still am going to be putting in a tank in the next few months.
  8. Oct 26, 2012 at 4:58 PM
    #608
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Where will you be placing said tank on the truck??? :cool:
  9. Oct 26, 2012 at 5:03 PM
    #609
    Slimwood Shady
    Slimwood Shady I love your mom!
    Linwood
    San Antonio, TX
    '23 TRD Pro Tundra; 996TT; '16 Odyssey
    #nomods
    Can you PM me a list of the fittings....I just installed my compressor today and want to do something very similar to what you did...:D
  10. Oct 26, 2012 at 5:15 PM
    #610
    nfs257
    nfs257 Well-Known Member
    DFW
    She gone
    x2 I have subs behind the seat...
  11. Oct 26, 2012 at 5:19 PM
    #611
    Slimwood Shady
    Linwood
    San Antonio, TX
    #nomods
    Probably under the bed where the spare was...
  12. Oct 26, 2012 at 5:23 PM
    #612
    MrGrimm
    Dean
    Wisconsin
    See build page
    I didnt keep track of a list but I can list off what I used
    3/8" 150 PSI hose 25' (It has 3/8" fittings on each end but I cut this up in the lengths I needed), roughly $20
    3/8" Elbow to Barb fitting (This comes from the manifold, the barb then goes to the 3/8" hose above and held in place by hose clamps) $3.00
    3/8" male and a 3/8" female adapter. Drill a hole through the bottom of the cab and use this to connect the hose from inside the truck to the outside. $3.00 each)
    3/8" female 3 way adapter
    3/8" male barbs x4. Then from the splitter you will need 2 more barbs that will have 1 hose going to the front and another to the rear. At the end of the hoses will have to be another male barb.
    3/8 quick disconnect. 1 for each end.
    Don't forget about teflon tape and some washers to on the hose side of the quick disconnects.
  13. Oct 26, 2012 at 5:24 PM
    #613
    MrGrimm
    Dean
    Wisconsin
    See build page
    Yep, going to go here for now but I would like to place an auxiliary fuel tank there sometime in the future.
  14. Oct 26, 2012 at 5:29 PM
    #614
    Slimwood Shady
    Linwood
    San Antonio, TX
    #nomods
    What tank you going with? I was thinking about the ARB 1 gallon...
  15. Oct 26, 2012 at 5:32 PM
    #615
    bulhas
    bulhas the habs fan
    Joe
    Edmonton, Alberta
    1997 Rexus
    LS Swap 500 hp......
    I mounted my tank on the left side of the bed in the bed up above and behind the wheel well, 5 gallon capacity with ease, slightly slimmer than wheel well so no loss in actual bed space
  16. Oct 26, 2012 at 5:35 PM
    #616
    nfs257
    DFW
    She gone
    Picture please?
  17. Oct 26, 2012 at 5:38 PM
    #617
    precoma
    precoma Well-Known Member
    Corey
    Lake Arrowhead, CA
    2009 4x4 trd sport
    Total Chaos 3.5 Long travel, Defined SUA
    check his build thread
  18. Oct 26, 2012 at 5:38 PM
    #618
    MrGrimm
    Dean
    Wisconsin
    See build page
    ARB's is overpriced IMO. You can get a 2-3 gallon tank for wayy less. They all have the same size fittings. Not sure what I am going to go with yet.
  19. Oct 26, 2012 at 5:41 PM
    #619
    Slimwood Shady
    Linwood
    San Antonio, TX
    #nomods
    Yeah I was just on wheelers site....the viair 1 gal is only $40
  20. Oct 26, 2012 at 7:10 PM
    #620
    agv1700
    agv1700 Well-Known Member
    Angel
    Black DCSB 4wd
    Awesome truck man...motivating
