MrGrimm's Mall Crawler
Discussion in '2nd Gen. Builds (2005-2015)' started by MrGrimm, Jul 25, 2010.
  1. Dec 30, 2013 at 1:34 PM
    #1501
    MrGrimm
    MrGrimm [OP] Mall Crawler
    Dean
    Wisconsin
    2006 Toyota Tacoma 4WD w/TRD Sport Package
    See build page
    Finished up the Dual Battery System after waiting seven weeks for a Columbia Overland Dual Battery Tray. Used a National Luna Isolator with their controller.
    Isolator is mounted on the passenger side with the wires going under the fan/radiator shroud.
    Battery tray holding down two Die Hard Platinum Group 35 batteries. The fit was snug but not too tight.
    Auxiliary battery has all of the accessories plugged into it. The winch also runs off of the auxiliary battery. With the National Luna controller, you can switch to the auxiliary battery to get more juice out of it when winching. Works very well when I turn on the ARB compressor too.
    angeldavid216 likes this.
  2. Dec 30, 2013 at 1:47 PM
    #1502
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    Bad ass! Well done Grimm.
  3. Dec 30, 2013 at 1:53 PM
    #1503
    HolyReptar
    HolyReptar Well-Known Member
    Bry
    Thousand Oaks
    17 TRD Offroad 4x4
    Some Bolt ones here and there
    :bowdown:Looks good man
    Where did you get the caps for your air hose quick connects on the bumpers? I'm getting parts together to do my install like that.
  4. Dec 30, 2013 at 2:06 PM
    #1504
    MrGrimm
    Dean
    Wisconsin
    See build page
    Got them at Lowes. They are actually the bottoms of chairs to prevent them from scratching up the floor. Got that idea from barlowrs.
    Link
  5. Dec 30, 2013 at 2:13 PM
    #1505
    NYCO
    NYCO go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
    how much room do you have behind your headlight? with the HIDs i'm wondering if i'll be able to squeeze in two batteries on that side or if i'm stuck having to run batteries on both sides...
    looks good tho..seeing all the wires is making my head :violent: thinking about the wiring that lays ahead of me...
  6. Dec 30, 2013 at 2:34 PM
    #1506
    MrGrimm
    Dean
    Wisconsin
    See build page
    There is only about a 1/4" of room behind the headlight. The wiring took up the most time for this. I still want to clean up the wiring and protect them by putting on some braided sleeving.
    Link
  7. Dec 30, 2013 at 3:00 PM
    #1507
    NYCO
    NYCO go explore...
    bOb
    Colorado
    dents & scratches
    damn...i was afraid of that...
    i saw those braided sleevings in the dual battery thread...looks like a nice peace of mind item when you get the layout finalized. especially when you have wires going over and through so many different places
  8. Dec 30, 2013 at 3:04 PM
    #1508
    Socalduckslayer
    Socalduckslayer Pelfreybilt Off-Road
    Tyler
    San Diego, Ca
    12 Tacoma
    Odds and Ends
    Looks great Dean, as always.
    Who did the wires with connectors? Did you have them done at a place like West Marine or do you have the ability to do those yourself? They look very clean and I would like to clean some of mine up and also relocate my winch solenoid at the same time.
  9. Dec 30, 2013 at 4:07 PM
    #1509
    MrGrimm
    Dean
    Wisconsin
    See build page
    The winch, isolator and fuse box wiring I did at West Marine. The compressor and inverter were done by local shops. I just noticed that the compressor and inverter wiring didn't have shrink wrap on the ends so I fixed that up today. I threw some screw protector caps over the exposed battery tie down screws as well.
    West Marine will have everything you need to get the job done there.
  10. Dec 30, 2013 at 10:06 PM
    #1510
    skygear
    skygear                    
    Hey Dean. Post it in the Dual battery thread also?
  11. Dec 30, 2013 at 10:29 PM
    #1511
    jobrien
    jobrien shit happens then you die
    Josh
    Ontario California
    2011 single cab base 4x4
    Bed mat, cleats, scangauge, new headlight bulbs, weather techs, more to come
    You need to stop or slow down just to let us catch up man. Looks good and clean :thumbsup:
  12. Dec 31, 2013 at 6:37 AM
    #1512
    Justin
    Justin Well-Known Member
    Justin
    Colorado Springs
    2018 4Runner TRD-OR
    285/75/17 on SCS 6's. ADS front & rear w/ adjusters. Relentless front bumper & roof rack. BAMF sliders
    Hey I was curious about the way you have the AC power coming out of the center console. Where do you have the inverter installed and which one did you go with? Eventually I want to run 2x batteries like you have and an inverter as well, I'm just trying to figure out everything I need.
    Love the truck by the way, it looks great.
  13. Dec 31, 2013 at 7:06 AM
    #1513
    MrGrimm
    Dean
    Wisconsin
    See build page
    The inverter is under the drivers seat. It is a Wagan 1000W DC to AC power inverter model 2294.
    Build Link
    Amazon Link
  14. Dec 31, 2013 at 7:38 AM
    #1514
    luka
    luka Well-Known Member
    Kailua, HI
    Prerunner -> 4WD Converted
    Pelfreybilt, Warn, BAMF, DTRL toggle on/off, FJ OEM Fog/Aux Light switches, 2012 lower center console swap, wired in auto-dimming rear view mirror, Wet-Okole inside, Weathertech , Rigid, Tint, Roto-Pax, Bestop, OME, Extended SS brake lines, TRD TX Pro/Baja Graphite 16" Rims
    is there much benefit to running the winch off of the aux and not the main battery?
    I have the IBS system and running the winch to the main battery..
    just curious.
  15. Dec 31, 2013 at 7:58 AM
    #1515
    Slimwood Shady
    Slimwood Shady I love your mom!
    Linwood
    San Antonio, TX
    '23 TRD Pro Tundra; 996TT; '16 Odyssey
    #nomods
    NICE! I am running the same setup. I love mine! The only thing I am not a fan of is that the batteries are touching my DS headlight connection. Is your touching or is it a hair away?
  16. Dec 31, 2013 at 10:12 AM
    #1516
    MrGrimm
    Dean
    Wisconsin
    See build page
    I would like to keep my main battery as just a starting battery. I don't think it would hurt running the winch off the main battery though.
    My battery is about a 1/4" off the back of the headlight.
  17. Dec 31, 2013 at 10:17 AM
    #1517
    ckeene9
    ckeene9 Well-Known Member
    Chesterfield, VA
    '12 DCSB Supercharged 4x4 TRD Sport
    See Build Thread
    Hmmm I wonder if the ATO battery tray sits a bit further back? I'm in the same boat as Slim and NYCO and have the big HID connectors on the back of my headlights.
  18. Dec 31, 2013 at 11:05 AM
    #1518
    Wynner
    Wynner Member
    I hate this truck... makes me want to spend LOTS of money on mine. ;)
  19. Dec 31, 2013 at 2:23 PM
    #1519
    Justin
    Justin
    Colorado Springs
    2018 4Runner TRD-OR
  20. Dec 31, 2013 at 2:26 PM
    #1520
    MrGrimm
    Dean
    Wisconsin
    See build page
    Yea, super easy to extend the wiring.
