MrGrimm's Mall Crawler
Discussion in '2nd Gen. Builds (2005-2015)' started by MrGrimm, Jul 25, 2010.
  1. Jan 19, 2014 at 10:11 AM
    #1541
    Black Pipe
    Black Pipe Well-Known Member
    It doesn't. My ATO tray didn't work with hid lights had to remove them.
    Oh and you should always wire the winch to the primary battery and disconnect the two batteries when winching so in case the engine stalls out you can self jump with a full secondary battery not to mention having all the excess current flowing through the battery isolator.
  2. Jan 19, 2014 at 10:15 AM
    #1542
    MrGrimm
    MrGrimm [OP] Mall Crawler
    Dean
    Wisconsin
    2006 Toyota Tacoma 4WD w/TRD Sport Package
    See build page
    After reading around a bit more I moved the winch to the main battery.
  3. Jan 19, 2014 at 10:16 AM
    #1543
    Vanguard
    Vanguard No can remember!
    Brooks
    Kailua, Hawaii
    13' TRD Sport 4x4
    Icon Extended C/O's non resi, OME 60091/Dakar Leaf Pack, All Pro U-bolt Flip, Timberens, 17" SR8's, 285/70/17 Duratracs, AFE Stage II Intake, Magnaflow Cat back w/Resonator, BHLM, Grillcraft, 15/5 Tint, All-Pro HD Sliders @10 degr, OEM Roof Racks, TRD Skid Plate, Wet Okole's, Scan guage II, Optima Yellow
    Thanks! Were you happy with the lift and the 265/75/16's for a while? debating on whether to make the jump straight to 285's or 265's. And from all my research it seems like 16's are the way to go. Right now I have FJ 17's but I think it'll bee too much rim vs tire.
    vs
    side by side
    What do you think? I'm gonna black out either rim. Just wanted another White onwer's opinion. Thanks for your input! not sure why the last image is showing upside down...?
  4. Jan 20, 2014 at 12:28 PM
    #1544
    Curt76
    Curt76 Member
    Curt
    2013 tacoma
    Killer truck my friend! Giving me all sorts of ideas!
  5. Jan 20, 2014 at 1:57 PM
    #1545
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    you dont have to turn off the isolator. But most kit dual setups i would as they are only 200 amp solenoids. But you still can.
    Why i opted to build my own with a 500 amp relay and 0/1 gauge wire.
  6. Jan 20, 2014 at 3:40 PM
    #1546
    MrGrimm
    Dean
    Wisconsin
    See build page
    They were good while they lasted. I think they might have been a little better than the KM2's but I didn't push the KM's as hard as the KM2's. I think the blacked out stock wheels look kind of tacky. Go with some aftermarket black wheels and it would look a lot better.
  7. Jan 20, 2014 at 3:54 PM
    #1547
    MrGrimm
    Dean
    Wisconsin
    See build page
    Went to the range to sight in the guns today. My youngest one, the blonde one turned 4 so I decided to let him shoot the 22's. He had a blast.
  8. Jan 20, 2014 at 3:56 PM
    #1548
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    Thats awesome.
    TW needs a "like button"
  9. Jan 20, 2014 at 5:46 PM
    #1549
    Jetlander
    Jetlander Just trying to measure up...
    Jonathan (aka MOAB)
    Depends on the day.
    2010 Tacoma DCSB 4x4 SR5
    TKO Wheel w/ 35" BFG KM2, Volant CAI, Safari Snorkel, 3" lift, All-Pro Full Skid Underarmor, Chopped/Re-Routed FlowMaster Exhaust, CBI Moab 2.0 Front Bumper, DerpWerx High Clearance Rear Bumper, Rear Tire Swing Out, BAMF Sliders w/Kickouts, King Resi w/700# Coilovers on front, Total Chaos UCA's, King Long Travel with Resi's, Shock Hoops and King 2.5 Bump Stops, OME Dakar Leaf Springs mounted on All-Pro Shackle Flip w/ U-Bolt Flip, extended SS Brake Lines, DerpWerx Bedrack, 10# C02 Tank, Black Badges, Dual Optima Red Top's, Blue Sea 12 Fuse Block on custom Block mount, SuperWinch 9.5iSR Talon w/synthetic line, Prolink Thimble, 20" Rigid Dual Row LED Light Bar, Rigid Dually Floods, OTRATTW Switches, Cab Mount Chop, Cobra CB w/ 4' Firestik, Center Counsel Glock 23 mount (with plenty o' ammo!), Weathertechs, and plenty more mods to come!
    Here's the TW "Like" button!
  10. Jan 20, 2014 at 6:49 PM
    #1550
    Black Pipe
    true, mine is also 500 amp rated as I know most winches pull upwards of 4-500 amps at full til. Most of the painless or national luna setups are only good to 200 amps though which could cause damage and arcing of the solenoid contacts if that current rating is exceeded. I just have a habit of turning my isolator off when winching, then after a few minutes I'll flip it back on to let the primary battery come to a decent charge first.
  11. Jan 20, 2014 at 6:54 PM
    #1551
    MrGrimm
    Dean
    Wisconsin
    See build page
    National Luna rates their isolator at a peak of 400 amps.
  12. Jan 20, 2014 at 7:14 PM
    #1552
    Black Pipe
    Ah, well that's good to know, you should be fine then! For some reason I was thinking only 200 :eek:
  13. Jan 20, 2014 at 7:57 PM
    #1553
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    Dean, you're extremely badass. Very cool.
  14. Jan 23, 2014 at 12:58 PM
    #1554
    Datsik
    Datsik Well-Known Member
    Anthony
    San Diego
    Not much.
    PM'd
  15. Jan 23, 2014 at 1:21 PM
    #1555
    Blackdawg
    Monte
    Wyoming/St. Louis
    400 peak
    200 continuous.
    Mine is 500 continuous and 700 peak.
    The NatLuna one will burn up if help at 400 amp for periods of length. How long? no idea. Not long id think though.
  16. Jan 23, 2014 at 5:41 PM
    #1556
    MrGrimm
    Dean
    Wisconsin
    See build page
    I guess miltuple snatch blocks would be the key if the pulls are heavy and short. A long pull though might be sketchy.
  17. Jan 23, 2014 at 9:03 PM
    #1557
    Blackdawg
    Monte
    Wyoming/St. Louis
    True good point.
  18. Jan 23, 2014 at 9:05 PM
    #1558
    Spoonman
    Jamie
    Alberta
    I just run a battery attached to my winch. Keeps things simple. Long hard pulls ain't nothin for me.
    His winch line, my winch line & winch extension(only me pulling). We took out sections as needed. Pulling through 2-3 feet of snow. That's a long pull! Duals + isolator would be nice for running accessories and not worrying though.
  19. Jan 29, 2014 at 6:55 AM
    #1559
    jds0912
    jds0912 Well-Known Member
    Justin
    Baltimore, MD
    2007 Tacoma TRD Off Road
    Some shit I got on craigslist
    Cool ass pictures man; I'd love to make that trip some time. I like this shot.
  20. Feb 27, 2014 at 1:11 PM
    #1560
    RockyMtnTRD
    RockyMtnTRD Wanderlust.
    Noah
    Colorado
    '11 TRD OR
    hack job
    I hear Mr. Grimm's truck is a mall crawler... Just kidding but I really want to see this thing in Moab. :):burnrubber:
    Wow your kids are gonna be badass when they are older. Fuck yeah that's some good parenting right there. :cheers:
