MT. Regearing. Should I go 4.88 or 5.29?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Pablo8, Nov 14, 2019.
  1. 4.88
    36 vote(s)
    50.7%
  2. 5.29
    35 vote(s)
    49.3%
  1. Nov 14, 2019 at 4:01 AM
    Pablo8
    Pablo8 [OP] Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    MT Currently running 31.5" tires may eventually go ~33"
    Getting lockers and doing driveline related mods. Dec 12 installation date.
    Amchuge likes this.
  2. Nov 14, 2019 at 4:20 AM
    GBR
    GBR Well-Known Member
    19 TRD OR
    Might want to add your intended tire size.
    t0nyvalenzuela likes this.
  3. Nov 14, 2019 at 4:26 AM
    Pablo8
    Pablo8 [OP] Here!
    Paul
    Everson WA
    Good point. Thanks!
  4. Nov 14, 2019 at 5:32 AM
    Pablo8
    Pablo8 [OP] Here!
    Paul
    Everson WA
  5. Nov 14, 2019 at 5:35 AM
    Pablo8
    Pablo8 [OP] Here!
    Paul
    Everson WA
  6. Nov 14, 2019 at 6:26 AM
    Turd Hawg
    Turd Hawg Well-Known Member
    2018 DC SB OR AT (Sold)
    Seems you have all the information you need, pick one
    Pablo8[OP] likes this.
  7. Nov 14, 2019 at 6:34 AM
    basshole
    basshole Well-Known Member
    chicagoland
    2018 OR MT
    I think stock gearing is ok with my 255/85r16
  8. Nov 14, 2019 at 6:36 AM
    Pablo8
    Pablo8 [OP] Here!
    Paul
    Everson WA
    I do. Just yet to find the person who regretted either ratio!
    :eek::D:D:thumbsup:
    Which actually speaks volumes.
  9. Nov 14, 2019 at 6:38 AM
    Pablo8
    Pablo8 [OP] Here!
    Paul
    Everson WA
    What is OD on those bad boys?
    But for me no way is stock gearing low enough.
  10. Nov 14, 2019 at 8:08 AM
    awdvkd115
    awdvkd115 Well-Known Member
    Bud
    2017 Tacoma TRD OR
    Toytec lift, White Knuckle sliders, RCI Armour, ECGS (Nitro Gears), Victory 4x4 Striker Front bumper, Smittybilt X20 10K winch, Dobinson snorkel, Spidertrax 1.25 spacers and 255 R80 16 BF Goodrich KM2s.
    Stock gears and 255/85r16's I doubt your truck will be in 6th gear much. I've run them for two yrs now with 4:88s and love the combination. I think most people find that if you do a lot of hwy miles stick with the 4:88s, if you do mostly city driving stick with the 5:29s. I personally think 5:29s are to much rpm wise. That is assuming you are not going bigger than 33s. 4:88s and 33s will leave 8% better than stock 3 when said and done. One thing you might think about is that 4 lo with 5:29s will make 4lo useless unless you are wanting to actually crawl. I also tow an RV (4k) and find 60 mph, 4th gear and 3k rpm a good combination. This truck will run all day long at 3k rpm and still get 8 to 12 mpg. Most of my time is spent in the Moab and Colorado areas driving trails and mountain passes so getting there from Kansas I've spent thousands of miles to and from and won't change a thing. For full disclosure I also have OVtune and it was money well spent. Good luck!
  11. Nov 14, 2019 at 9:26 AM
    basshole
    chicagoland
    2018 OR MT
  12. Nov 14, 2019 at 9:29 AM
    basshole
    chicagoland
    2018 OR MT
    I have dick cepek extreme country installed, I'm pretty sure manufacturer spec is 32.8"
    Lifted about 1" front 1.5" rear, caster pushed forward, no Rubbing issues. Had to do a little plastic trimming on bumper and mending the fender liners. So far so good for me at the offroad parks I visit here and there.
    As for gearing.. I can still cruise at low speeds in 6th gear. OVtune 87fob. Doesn't feel like a slob at all. 4lo is awesome.
    This is just my experience as an offroad noob. I wanted to keep this truck simple for most of my driving which is local short trips. Highway I stick to 60-65mph to get decent mpgs.
  13. Nov 14, 2019 at 9:35 AM
    chaotic_taco
    chaotic_taco Well-Known Member
    ATX
    2017 DCSB TRD OR MT
    Depending on the tire manufacturer, around 32.8"
    Turns out the manual has 4.3 gears already, it's pretty nice with the 255/85s, I think.
    Anytime I'm over 65 and not accelerating hard, I'm in 6th. Sounds like you're in an auto though...
    Pablo8[QUOTED][OP] likes this.
  14. Nov 14, 2019 at 9:47 AM
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    @BlakeM you have 5.29's right?
  15. Nov 14, 2019 at 10:13 AM
    friendlywithbears
    friendlywithbears a tree falling in the woods
    B
    The Wild
    2016 TRD OR MT
    Manual gearing is pretty spot on for 33s. I'd do 4.88 for 35s and 5.29 for 35+ or heavy weight hauling.
    BlakeM, Pablo8[OP] and basshole like this.
  16. Nov 14, 2019 at 10:20 AM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    4.88 with 33's if you keep the truck light. 5.29 if you go bigger or plan to have a very heavy armored rig down the road. I have buddies running 285/75/17 Armored to the nine and very heavy and 5.29 was solid.
    BlakeM and Pablo8[OP] like this.
  17. Nov 14, 2019 at 11:19 AM
    BlakeM
    BlakeM Well-Known Member
    Blake
    Gonzales, LA
    2023 T4R.SR5.4WD.OMG.LOL.WTF
    Yessir. Well, I did. Sold the truck about a month ago.
    This. ^
    Just an opinion, but I think 4.88s would be a better choice for the manual if you’re running 33-35s.
    I had 33s and was planning to move up to 35s. Then I re-geared to 5.29 and started thinking I should go up to 37s instead.
    Even as low as the gearing was, it made the truck so much more enjoyable to drive over the stock gears. I would’ve loved to keep it, but priorities changed and I needed a full size truck.
  18. Nov 14, 2019 at 5:16 PM
    Pablo8
    Pablo8 [OP] Here!
    Paul
    Everson WA
    Yeah thanks fellows, I started all gung ho for 5.29 but with 4.88 believe it or not 80mph is still just under 3K RPM and yet plenty of RPM range in first. 4.88 runs 2000 RPM at 10 mph and 3000 RPM is 15 mph, for example. 5.29 is 9 and 13 mph. A bit of a different way to think about it.
  19. Nov 16, 2019 at 8:34 AM
    Pablo8
    Pablo8 [OP] Here!
    Paul
    Everson WA
  20. Nov 17, 2019 at 5:23 AM
    Pablo8
    Pablo8 [OP] Here!
    Paul
    Everson WA
    5.29 in the lead. Very surprising!
