Mud and Alternator problems?
Discussion in '1st Gen. Tacomas (1995-2004)' started by BrianPK, Mar 17, 2007.
  1. Mar 17, 2007 at 10:41 PM
    BrianPK
    BrianPK [OP] Offroad Enthusiast
    Modesto, California
    01 TRD 4WD V6 SR5
    CB Radio, 3'' fabtec spacer lift and 3'' body lift flowmaster dual exhaust, deckplate mod, silencer mod, Work in progress pioneer 7900bt stereo with 5X8 infinity speakers all around, and eclipse ex400 amp
    so, i just bought an 01 tacoma v6 4x4. today we went out and got it dirty. it was a blast.
    it was me and one other tacoma (a 97, with a 2.7 liter)
    we both went through some deep puddles and now both of our battery lights are on. we tried spraying the alternator and battery terminals with brake cleaner, and then reset the computer by undoing the battery.
    in both cases, the battery light is still on. the manual says that this is the battery discharge warning.
    did we ruin our alternators? has this happened to anyone else?
    is there any way to fix this? or should i just get a new one?
    thanks for the help
  2. Mar 18, 2007 at 5:23 AM
    TheMaster
    TheMaster Born to Ride
    Chicky Baby
    NY
    2007 DC TRD Sport
    Bug shield, window visors, skid plate, rust proofing, tonneau cover, paint & upholstery protection, side step bars, navigation system.
    Wow, is that a coincidence? As for the 97 Taco, it just may be time to replace the alternator or what's listed below, may apply.
    For the 2001, I’m at a loss for words. How deep were you in mud and how many miles on your Taco? For you to have your alternator submerged in mud, you must have been in some serious puddle. If it was, it’s advisable to look into replacing it (alternator) since all your winding may be covered in mud and the mud may be acting as a conductor between the windings where the insulation may have deteriorated/broken down.
    If a belt drives your alternator, ensure the belt tensioner has not ceased and is not driving your alternator at the required speed. Also, check all your connectors, clean and reinstall. Let us know what you find.
  3. Mar 18, 2007 at 10:40 AM
    BrianPK
    Modesto, California
    01 TRD 4WD V6 SR5
    the mud/water we were in was pretty deep. i think i have a 6in lift, and the mud got all the way to the hood.
    both trucks hit the same puddle, and both have the same light.
    i hit the alternator with brake cleaner and doesn't appear to be binding.
    i'll try your suggestions, and let you know what i find
  4. Mar 20, 2007 at 3:20 PM
    2003greenbean
    2003greenbean Carolina Alliance Costal Div
    socaste,sc
    03 trd
    cold air intake, step bars, custom grill, 3in lift,12 in audiobahn sub, 285/75/16 procomp tires, 20% tint,
    water and mud kill alternators i think you need a new one
  5. Mar 21, 2007 at 2:18 AM
    BrianPK
    Modesto, California
    01 TRD 4WD V6 SR5
    Yeah, i ended up getting a new one. $124.99 at autozone - lifetime warantee.
  6. Mar 21, 2007 at 4:19 AM
    TheMaster
    Chicky Baby
    NY
    2007 DC TRD Sport
    When you buy critical components such as alternators, starters etc... always, I repeat always buy OEM. They might cost you 5 times more, but it will save you a lot of time and trouble and labour costs in the long run.
  7. Jul 5, 2007 at 8:23 PM
    jrallan26
    jrallan26 Well-Known Member
    Iowa
    2004 White D-Cab TRD
    Instead of replacing the alternator, find a shop in your local town that can re-build it. Usually any electrical motor place will rebuild an alt.
  8. Jul 26, 2007 at 10:52 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    Ummmmm, Toyota didn't make Tacos until 1995.5, are you referring to the Toyota Pickup instead?
  9. Jul 27, 2007 at 4:36 AM
    007Tacoma
    007Tacoma I dub thee malicious!
    Mark
    San Antonio, TX
    2015 4Runner Trail Edition Premium
    Cloaking Device
    Maybe there is a short some where in the electrical system that is draining the battery and causing the alternator to "over-work", OR maybe the alternator is over heating (bad-bushings could do that).
  10. Jul 28, 2007 at 11:10 PM
    BrianPK
    Modesto, California
    01 TRD 4WD V6 SR5
    Mine went out because it was submerged.... i just thought it strange that mine and another taco's both went out, but the stock jeep alternators (went just as far under as mine did, if not more) didn't go out. what's the deal-y-o?
  11. Jul 30, 2007 at 4:53 PM
    bowzerdoo77
    bowzerdoo77 U.S.M.C.
    North Ogden Utah
    1997 REG CAB 4x4
    None
    Note To Self Stay Out Of Seep Mud And Water:d
  12. Jul 30, 2007 at 4:54 PM
    bowzerdoo77
    North Ogden Utah
    1997 REG CAB 4x4
    None
    deep Mud I Cant Spell
  13. Jul 31, 2007 at 3:20 PM
    BrianPK
    Modesto, California
    01 TRD 4WD V6 SR5
    what's the point of having a lifted 4x4 if you can't hit some serious mud?
    the jeeps both had mud on top of their hoods, and both came home w/ no electrical problems.... but the two tacoma's one with a 2.7L and mine with a 3.4L had both alternators fail.......
    what's the difference?
