muffler question (magnaflow)
Discussion in 'Performance and Tuning' started by MySilverTaco13, Feb 20, 2012.
  1. Feb 20, 2012 at 10:18 AM
    MySilverTaco13
    MySilverTaco13 [OP] Well-Known Member
    HBSoCal
    2012 Trd sport PreRunner
    what size do i need for my double cab 2012 i see people with 2.5 tubing and 2.25 tubing what would be a better fit? thank you
  2. Feb 20, 2012 at 10:29 AM
    VooDoo
    VooDoo More Cowbell!
    Carter Ivey
    Baton Rouge, LA/ Starkville, MS
    '06 DC LB PreRunner
    2.25"
    You'll lose some low end power with the 2.5" IIRC
  3. Feb 20, 2012 at 2:30 PM
    MySilverTaco13
    HBSoCal
  4. Feb 20, 2012 at 2:42 PM
    BAMFTACO
    BAMFTACO Another day another beer
    Jośe
    Woodlandland hills , CA
    Taco
    Lift- king 2.5 with light racing uppers,tc coil bucket gusset, 4 in spindles,timbern bumps all around ,wheelers 3 addaleaf, ato shackle flip kit with 6 inch HD shackles. Armor- tire gate, custom tube bumper, kr fab rear bumper,trail gear wiy 78 in sliders Performance-intake manifold spacer, hps silicone hoses Random stuff- kenwood head unit,b&m t shifter, hood bug deflector, rear dust lights with custom bed bar and hi lift mount.
    Just buy the muffler only and replace the stock one little bit cheaper
  5. Feb 20, 2012 at 5:17 PM
    steve04dblcab
    steve04dblcab this tacoma protected by...
    Steven
    Boone
    04 double cab 4wd
    3 inch lift, 1.25" wheel spacers, home-made intake, single magnaflow exhaust, 6000k HID's
    there is no need whatsoever to go larger than the stock exhaust diameter unless you are already making ALOT more power than stock. you wont have adequate backpressure and you will lose power. it does change the tone but in my opinion it sounds worse. I have a magnaflow on my truck in place of the stock muffler, and the rest of the exhaust is stock. it sounds decent, and its alot cheaper. If you want a better tone from your engine, put an aftermarket intake on it if you havent already. I made mine but an AFE pro dry is a good option if you wanna buy one.
  6. Sep 25, 2012 at 6:37 AM
    sdoheny
    sdoheny Well-Known Member
    Seth
    Tampa, FL
    Sport
    N-Fab Text black 3 main tube, led interior lighting, sylvania ultra head lamps, led map/dome/license plate, rail mounted bed lights, trd skid plate, Aero Turbin muffler swap, MRBP Black Exhaust Tip, weather tech, fuel trophy, duratrac 265 70 17, plasti dip badges, Icon stage 4 suspension, TRD shift knob, AFE CAI, Raptor Light MOD.
    So did you go with a 2.25 i/o or a 2.5? I am looking to just take the stock muffler off and place magnaflow 12255 on and use stock piping. I believe our stock diameter is 2.25, and it seems like every one on the forum is opting for 2.5?
  7. Sep 25, 2012 at 6:58 AM
    fyremanpat
    fyremanpat Well-Known Member
    Pat
    757
    2013 DC LB TRD Sport w/Entune
    OME 886x and 5100's all the way around. Toytec AAL. Phillips x-treme vision headlights. 886 reverse lights. Borla exhaust. 20% tint. Hi 6 mod. 285/65/18 Nitto TG on 18" Moto Metal 955's. Airaid intake. Scanguage2.JBA LT's.GC Grill..more to come.
    yes stock is 2.25 ... unless you put performance headers and completely redo ALL the piping 2.5 is a waste of money
  8. Sep 27, 2012 at 8:29 AM
    sdoheny
    Seth
    Tampa, FL
    Sport
    After calling a couple places and speaking with magnaflow. I went with 2.5 inlet./outlet. Our stock pipe is 2.25, but i went and measured with calipers and the outer diameter is 2.38. So if you got a 2.25 inlet/outlet you would need the shop to expand the muffler and risk splitting the metal. If you get the 2.5 it will slip over and weld the gap that is only 0.06 in. anyways. Not to mention for magnaflow the core size for the 2.5 and 2.25 is the same...2.5 in. Also get your muffler off Amazon, the price is identical for 2.5 and 2.25 inlet/outlet sizes. I paid $71 for PN 12256. A lot better than the $120 the muffler shop wanted. I hope this helps people, because I researched the crap out of this topic. 2012 Tacoma V6 4.0L
  9. Sep 27, 2012 at 8:46 AM
    Neutron1212
    Neutron1212 Member
    2012 Sport
    So how does it sound and was your power any different (plus or negative)?
  10. Sep 28, 2012 at 6:41 AM
    sdoheny
    Seth
    Tampa, FL
    Sport
    The 12256 sounds amazing. Cannot hear it at idle, and is very deep. Got it welded on for 45 bucks and the welds look awesome, replaced all hangers perfectly. Seems to be a little bit more responsive.So everything turned out great. Note: This system is offset center. For my 2012 he welded it center in offset out. Everything lined up perfect and it is tucked inches under the frame. Could not be happier!
