muffler vs full exhaust system
Discussion in '1st Gen. Tacomas (1995-2004)' started by I h8 winter, Jan 23, 2015.
  1. Jan 23, 2015 at 6:11 AM
    I h8 winter
    I h8 winter [OP] New Member
    Hi guy's and Gals,
    My muffler has a hole in it and after looking at the system (Cat Back) that all seems good, however, I'm thinking R&R all of it.
    What would you guys do?
    What system should I get?
    If I go muffler only which one?
    Thanks for any and all input.
  2. Jan 23, 2015 at 7:57 AM
    Tac0NM
    Tac0NM Well-Known Member
    Aaron
    ABQ, New Mexico
    12' Tacoma Dbl Cab short bed 4x4
    OME Suspension, Adjustable UCA's, Demello Front bumper w/Winch, Rigid LED Lighting (Front), Custom Rock Sliders.
    I just went through all of that and ended up just doing a magnaflow free flow muffler. I talked to several shops around town and was advised to go that route considering the cost vs gains with a full system.
    Also how big is the hole in your muffler? Depending on the damage and hole size you might consider patching it.
  3. Jan 23, 2015 at 9:55 AM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    your pipes will last nearly forever so leave em alone and just get a magnaflow free flow muffler
  4. Jan 23, 2015 at 11:16 AM
    Indy
    Indy Master of all I survey.
    The little toy engines don't move enough air to really benefit from an exhaust upgrade, so any parts you replace are basically personal preference. If you want to spend the $$$ on a full system, do it. Just don't expect it to turn into a ground pounder when you're done.
    My mustang is fairly quick, fairly loud with the top up. My toy is slow, I prefer it as quiet as possible. Slow and loud just annoys me.
  5. Jan 25, 2015 at 3:54 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Just want to add the muffler, anyone have a link to the MagnaFlow Free Flow muffler stated above?
  6. Jan 25, 2015 at 4:21 PM
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    Dont know where you live, but here in the winter the salted roads and salty air eat exhaust systems. If your muffler is rotted out, the pipes probably aren't in great shape either.
    I went with the repair route with a new muffler only to discover there was rust holes in the pipes too. Should've just went with a complete cat-back to start with.
    I would throughly inspect the entire exhaust before buying just a muffler.
    I went with an AFE cat-back and it was easy to install. Kind of loud for my liking but it doesn't leak and it isn't rusty.
  7. Jan 26, 2015 at 8:32 AM
    Voyager
    Voyager Well-Known Member
    Bob
    Virginia
    04 Tacoma DC 4X4 TRD V6
    OME Suspension kit Magnaflow SS catback, ARE cap, Yakima kayak & bike racks, Deck Lid, Westin Safari Light Bar.
    I did the full Magnaflow SS cat back system on my ’04 DCV6. Easy to install at home. Fairly expensive. A touch too loud for my tastes.
