Mufflers for V6 Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Longtaco6, May 19, 2019.
  1. May 19, 2019 at 9:23 AM
    Longtaco6
    Longtaco6 [OP] New Member
    Owen
    2005 V6 tacoma longbed trd
    Still trying to find a muffler that’s not too quiet but doesn’t sound like an angry weed eater. Suggestions?
  2. May 19, 2019 at 10:30 AM
    SunCityBob
    SunCityBob Member
    Bob
    Phoenix
    1999. 2.4 sr5
    No doubt... walker dynomax superflow turbo muffler, they even siuls great on 4 cyl.
    Deeper tone, louder but not loud.
    Bib in Phoenix
  3. May 19, 2019 at 2:05 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    The TRD exhaust is not overly aggressive but it's throatier than stock.
    goforbroke123 likes this.
  4. May 19, 2019 at 3:17 PM
    AustinWest
    AustinWest The Amazon Special
    South Carolina
    2006 Tacoma - DCSB - 4WD - Manual
    Crosis, RedSki7 and Dominic4Lo like this.
  5. May 19, 2019 at 7:51 PM
    Armkb
    Armkb Well-Known Member
    Hudson Valley, New York
    09 TRD Sport DCLB
    Bilstein 5100, OME 885X, LR UCA, ARB/EL095R, ES LCA Rack & Sway Bar Bushings, Yellow Wire Mod, ABS Switch, TPMS Mod, Scanguage, Toyota Bed Mat, WeatherTech Floor Liners, Extang Trifecta Cover, Fumoto Drain Valve
    Friend at camp has an S10 w/4.3 V-6. He installed a Welded Thrush muffler, and deleted the cat. Best sounding V-6 Ive ever heard. Thought he finally got around to swapping in a V-8 that he had been talking about. Wish a my Tacoma could sound that good.
  6. May 20, 2019 at 1:02 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Cheap, sounds a little louder than stock, minimum drone in cab, and most auto stores have them.
    Walker SS Quiet Flow muffler - bolts right in option with tail pipe and can get muffler to cat section too. Tail pipe is cheap bend with the ripples. Painted mine black so don't see much of it anyway and uses stock mounts. At full throttle sounds good. Just 1 option for you.
  7. May 20, 2019 at 1:18 AM
    HillJackJDS
    HillJackJDS Well-Known Member
    Dale
    2008 Tacoma 4WD
    My son put an AeroTurbine SS muffler on his 3.7L Gen3 Taco. Sounds pretty tough when you're into it, but isn't going to totally annoy our neighborhood every time he goes to work or comes home. Drone is minimal at highway speeds too. I am proud of all of the research he did before deciding on this one after seeing the results. It was NOT plug and play though... We took it to a buddy's local shop to get it put into place with proper fit, placement, and support!!
  8. May 20, 2019 at 9:19 AM
    KeystoneGoodie
    KeystoneGoodie Well-Known Member
    Ben
    '09 AxCab with meat shoes and axe handles
    Lots of dollars and no sense...
    Flowmaster delta 50. Sounds like the truck should sound off the factory line.
  9. May 20, 2019 at 9:28 AM
    Old Swamper
    Old Swamper Tacoma World Poor
    Will
    Northern WI.
    2012 Black Tacoma TRD OR
    5100 & OME 884 AAL
    Doesn’t sound bad.
    https://m.youtube.com/watch?v=BRA_MA2xy_o
    Paul631 likes this.
  10. May 20, 2019 at 9:35 AM
    Clearwater Bill
    Billy
    Largo Florida
    The 4.3 is a v8 with the back 2 cylinders lopped off. Very different than a Tacoma (and most other) v6s
    DriverSound likes this.
  11. May 20, 2019 at 9:44 AM
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    Welcome to the site. Sound is subjective and I know the youtube videos does not sound as good as it does in person. All depends on what you're looking for.
  12. May 20, 2019 at 9:59 AM
    Slick Taco
    Slick Taco Id Rather Be Airborne
    Lost somewhere in the PNW
    Current vehicles: 2019 Rav4 Lunar Rock. 2018 TRD OR DCSB KD Max tuned. 2010 Tundra Limited Crew Max . 1991 4Runner Crawler. Ivan Stewart Edition
    KD Max Tune, King 2.5 coil overs T.C. UCA's, Deaver leafs, 17x9 Black Rhyno Warlords, 33" Toyo M/T's, Metal Tech rear bumper, Westin HDX drop steps with Bullet Liner coating, K&N CAI, Baja Designs fog pods, Rigid Midnight addition 3" pod ditch lights. Cali Raised brackets and 32" behind the grill mounted light bar, Southern Style Offroad Lopro Stage II front bumper, Warn winch, FACTOR 55 Ultra Hook, FACTOR 55 Hawes Fairleed, full debadge, Cosmetic goodies such as 15% carbon tint, matte black in channel rain guards, interior LED's, Teton Workshop shift knob, Inferno vinyl detailing on the interior, Cali Raised multi rocker switch cubby insert with Mc Tuning LED switches and a few other mods I've probably left out.
    I've tried pretty much every known muffler and exhaust system over the years on three different model year V6 tacomas I've owned and after the Borla S Cat back system there really is no comparison when it comes to the quality of sound. Quiet and subdued under 3,500 rpm but step on the pedal aggressively beyond that it comes alive. Oh and absolutely NO cab drone at any RPM or speed (can't stand cab drone). Throw on a cold air intake and together they make sweet music. Just my 2c
    TRDSport10 likes this.
  13. May 20, 2019 at 10:10 AM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    On my 02 Pre Runner DC 2.7 supercharged 4cyl I'm running a Magnaflow muffler and a Doug Thorley Shorty header . People always comment on how my exh note sounds like a V6
  14. May 20, 2019 at 10:49 AM
    redtaco2007
    redtaco2007 Well-Known Member
    2007 Red Tacoma - TRD Off Road DCSB
    not much yet!
  15. May 21, 2019 at 3:30 PM
    Canadianguy91
    Canadianguy91 Well-Known Member
    Sean
    Halton Hills, Ontario, Canada
    2016 Limited
    Krown undercoating, Protect a plate, blindspot mirrors, Reese stainless steel towing ball, Bakflip MX4 tonneau cover, Tufskinz tailgate letter inserts, Console organiser, Tinted windows, LED interiors, Bed lights, Hood lights, Black Canadian flag decal (@bfeth), Oem bed mat, WeatherTech floor liners, Arctic Claw XSI tires, Recovery Shackle, Ultimate LED turn signals V3 @mesojdm, OEM TRD Off-Road tow hook, Bilstein 5100's with ARB's Old Man Emu 2887 coils, ICON progressive add a leaf, General Grabber ATX tires, Fuel ripper rims, Auxbeam F-16 H11 Led headlights, Borla S-type catback exhaust with black tip, custom powertray, vinyl badge inlays, (@rrentrop), Rear diff breather mod, Redarc trailer break controller https://m.youtube.com/watch?v=qqN7m1pc6AA
    Anyone have pictures of the borla?
  16. May 21, 2019 at 3:36 PM
    lenoxluda
    lenoxluda Well-Known Member
    09 Sport
    I'm very happy with the TRD exhaust. I think it sounds great!
  17. May 21, 2019 at 10:02 PM
    steveo27
    steveo27 Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    This. Subtle but just enough
    Fitz235 likes this.
  18. May 22, 2019 at 5:55 AM
    Fullboogie
    Fullboogie Well-Known Member
    Dave
    Houston
    2007 Prerunner & 2008 4Runner
    You have a V6. It's always going to sound like a weedeater.
  19. May 22, 2019 at 8:18 AM
    Jonathon777
    Jonathon777 Well-Known Member
    Jonathon
    Texas
    2005 Silver Tacoma TRD Sport
    I have a magnaflow on mine and i live the way it sounds nothing to loud but loud enough.
  20. May 22, 2019 at 8:24 AM
    Matmo215
    Matmo215 Well-Known Member
    Matthew
    Waco, TX
    2015 Sport DCSB
    I have a 24” Magnaflow and I love it. Quiet at low rpm’s but wakes up and screams at 2500+ rpm
