Multiple warning lights turned on
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Ezolo, Jun 14, 2020.
  1. Jun 14, 2020 at 6:34 PM
    TacoBuffet
    TacoBuffet Well-Known Member
    AL
    Taco #13, 2022 OR DCSB Cemint
    5100s, TE37s, Toyo RTs, Tint, Bedmat, LEDs
    Yep, 12 tacos, 3 lifted, always something, even if its minor and something you can wrench on its still something. Looks great for the first year or so though before the squeaks, rattles and headaches appear.
    P-Dawg and SouthernFried[QUOTED] like this.
  2. Jun 14, 2020 at 6:38 PM
    SouthernFried
    SouthernFried Well-Known Member
    South Carolina
    2020 TRD OR DCSB
    Without fail, that’s how it goes. As I mentioned earlier, go look at very high mileage Tacos and Tundras. The ones that are at 500k and even 1 million miles. They are ALL sitting at that factory suspension setup. Not the trucks on 33s and 35s. That speaks dividends alone.
  3. Jun 14, 2020 at 6:39 PM
    TacoBuffet
    AL
    Same come resale time, what commands the most, a stock well maintained truck, period.
    MoneyMan55, Chew, P-Dawg and 2 others like this.
  4. Jun 14, 2020 at 6:43 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    So glad people got this haha :D
  5. Jun 14, 2020 at 6:44 PM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
  6. Jun 14, 2020 at 6:45 PM
    TacoBuffet
    AL
  7. Jun 14, 2020 at 7:59 PM
    Thatbassguy
    Thatbassguy Sweet or sour?
    James
    '19 T4R, TRDORP, KDSS
    RSG sliders, SOS skids, SOS bumper, wheels, tires, etc
    Subbed for the scan results... And the bickering.
    I would think a good dealership would at least be willing to scan for codes.
    As far as the modding VS keeping it stock debate; I think most guys understand that lift and big tires will cause parts to wear faster. But, there's also a huge difference between 2-3" of lift on 33's and 6" of lift on 35's. If done properly, a lift doesn't automatically affect the longevity of a vehicle.
    71tattooguy, Scott4032 and VirusCage like this.
  8. Jun 14, 2020 at 8:03 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    I'm just here because I got a chuckle out of this image.
  9. Jun 14, 2020 at 8:53 PM
    stun gun
    stun gun Well-Known Member
    Aaronski
    Tacomas.
    17 4X4 sr5spd/01 LT sr5spd
    All the tacomas I’ve wrenched on, welded on, spent thousands on travel kits etc...I’ve learned that the stock tacomas failed a lot less when it counted.
    I don’t have a chase team or rebuild my truck after every outdoor excursion, so I’d prefer it last the trip and then some. Which means proper drive angles all the way around.
    JNG, jmauvais, TacoBuffet and 4 others like this.
  10. Jun 14, 2020 at 8:54 PM
    Thatbassguy
    James
    Haha! It was all of those Bilstein commercials on CNN. They got into my head!
  11. Jun 14, 2020 at 8:54 PM
    stun gun
    Aaronski
    Tacomas.
    Bro im coming for you first.
  12. Jun 14, 2020 at 8:58 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Thats only because you're confused with one foot in both worlds.
    If you listen carefully, through the sound of that howling rear axle, you can hear the sound of how right I am.
  13. Jun 15, 2020 at 4:05 AM
    ClassyTacos
    ClassyTacos National Treasure 3, Times a ticking Nickolas
    Papalote
    Florida
    2017 TRD Sport 4x4
    Stockish
    Thank you all for a well documented, dramatic thread. I enjoyed it this morning with my coffee.
    Both sides of the argument have credible points, however, it's important not to communicate in absolutes.
    As soon as you start wrenching on anything future issues are more likely, not always the case but there. I've seen my share of cheap parts, horrible installs, welds, and short cuts. Enough of those and you'll see why stock is a great option.
    I will also say, if your idea of working on a car is opening the hood once a month to fill the window washer fluid. Maybe just keep it stock, I'm not saying you can't learn. But, anything that has been modified from mopeds to rocket ships requirers a bit more love and will give you more headaches down the road. Thats just my experience.
    do your best to keep the Geology Right. o_O
  14. Jun 15, 2020 at 6:36 AM
    FLA_Hoosier
    FLA_Hoosier Well-Known Member
    Rick
    Space Coast
    2017 White TRD Sport AC
    Hell, AutoZone will scan the codes.
    Thatbassguy[QUOTED] likes this.
  15. Jun 15, 2020 at 7:18 AM
    #35
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    Exactly. Why anyone who has the slightest interest in diagnosing their own problems won't have something to scan codes is beyond me. I mean there's literally a system on your truck you can plug a sub $100 thing into that will tell you where it has flagged an issue. I now keep not one, but 2 readers in my truck.
    Thatbassguy likes this.
  16. Jun 15, 2020 at 7:29 AM
    #36
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Bought an older odb2 reader for under $20 to use on my 01 tundra when i got my my first check engine light at 120k. Turned out what i suspected with the heaters in the 02 sensors failing, but at least i knew which ones. Found later i should of just replaced all 4 of them at the same time instead of waiting for one at a time to crap out. Now if something craps out i'll need to get a newer code reader for the tacoma.
  17. Jun 15, 2020 at 7:32 AM
    #37
    DetroitDarin
    DetroitDarin Specified
    York County PA
    Scratches and Whatnot
    I'm here to say Stop Lifting your own codes! When you lift a code it changes the balance and the code won't last for 500,000 miles!! Raising your codes beyond OEM is probably what started the Coronavirus!
  18. Jun 15, 2020 at 7:32 AM
    #38
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    I had my morning coffee and my morning dump LOL!!
    ClassyTacos[QUOTED] likes this.
  19. Jun 15, 2020 at 7:37 AM
    #39
    DetroitDarin
    York County PA
    Wish my wife was as-easy to turn on as warning-lights on a lifted Tacoma.
  20. Jun 15, 2020 at 7:38 AM
    #40
    DetroitDarin
    York County PA
    She is OEM though - except aftermarket "headlights" :)
    ClassyTacos likes this.
