Multipurpose 4x4 Long Travel kit?
Discussion in 'Long Travel Suspension' started by ks2socal, Aug 3, 2010.
  1. Aug 3, 2010 at 11:08 AM
    ks2socal
    ks2socal [OP] Member
    Hello all,
    Ive been lurking for a little while, I used to have a tundra dc with TC uppers and king coils, I also chase for a class 7s and others. Ive since moved on to a UTV, however my living situation has changed and am finding myself limited since its not street legal.
    I now live in Kansas, but still spend time in Havasu and the cali/mexico deserts. Being close to colorado and moab also have their benefits, which is why I was thinking a jeep, but to get a jeep to be capable in the desert is going to cost alot.
    So my question is, do any of you with LT also wheel in the rocks?
    -All pro comes to mind, but seems a little less capable in the fast sections.
    -The engage kit looks awesome, but may be a little to wide. Does anyone have real measurements? Still havent seen if they have 4x4 working yet.
    TC and Burg, both seem to be 3.5in wider per side? If thats the case the engage kit seems like a better deal.
    For the rear i would like to do a SUA, however im not sure if it will get caught up in the rocks.
    I havent purchased a truck yet, still havent decided on First gen vs 2nd gen. Obviously I could throw more money into a first gen due to a lower cost to purchase. I really hate the first gen seats, nothing that some mastercrafts cant fix lol:D
    Any input/experiences would greatly be appreciated.:cheers:
  2. Aug 3, 2010 at 11:22 AM
    FearNothing321
    FearNothing321 You gonna eat that taco?
    Tony
    Wesley Chapel, FL
    08 PreRunner SR5 TRD Sport
    Stuff and Things
  3. Aug 3, 2010 at 3:26 PM
    ks2socal
    Thanks, it sort of helps out.
    Not too much mention of the crawling aspects, or if widths are an issue.
  4. Aug 3, 2010 at 3:36 PM
    amaes
    amaes Cuz Stock Sucks
    Alex
    Chandler, AZ
    2011 FJ Built
    ICON Stage 6, RCI Skids, Blacked out
    Yes, I have.
    I can tell you by experiance that the AP kit does well in the fast sections. and Just as well on the rocks
    I have a TC kit and Like it A lot. But I have a first gen 4x4
    Yes you lose clearance with a SUA kit. It all depends on what you want to do more Rocks or Desert. On the rocks you just have to be more careful and wheel placement is key. I can tell you also by experience that a Spring over can't compete with a SUA in the desert.
    I used to have a 2nd gen and the seats and interior is what I miss most. these 1st gen seat do blow huge dick. I'm actually going to be doing new seats (Corbeau or Master craft) also when I go do an in interior cage.
  5. Aug 3, 2010 at 4:16 PM
    ks2socal
    Thank you amaes, checking out your build now.
  6. Aug 3, 2010 at 4:28 PM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
  7. Aug 3, 2010 at 4:30 PM
    ToucanV13
    ToucanV13 You think I was rollin out here naked?
    San Diego and Colorado
    Infideled out TRD Sport 4X4
    285/70 Hankook AT-M, Window vents, TRD CAI, TRD Cat-back exhaust with WickedFlow can, AFE Throttle Body Spacer, Billy 5100 @ 2.5 and 1" block rear, RBP nerf bars, Halo HIDs, 20% tint up front
  8. Aug 4, 2010 at 11:25 AM
    Mxpatriot
    Mxpatriot Well-Known Member
    Chase
    North Pole, Alaska
    '06 4x4 AP LT and Locked
    Money pit.
    All pro is exactly what you are describing.
  9. Aug 4, 2010 at 11:41 AM
    ks2socal
    Thanks again for all the links!
    Mxpatriot do you have any vids of your truck in action? Sick truck!
  10. Aug 4, 2010 at 11:42 AM
    mjp2
    Milton Juevos Portimous II
    NJ
    '06 TRD Access Cab, v6, 6-speed
    Scaffolding and a painted grill
    Crawling with a long travel setup is downright pleasant. Plenty of clearance under the front differential and the bumps are nicely absorbed.
    The rear is where you'll have issues. Things were great until I went to the SUA conversion. High speed stuff is heaven but the leaf pack WILL get hooked on rocks. I took out the bottom 3 leafs on my last trip. Bent 2 and snapped 1 in half.
    I like the suspension flex in this vid. It felt like nothing when I drove through this pit, even in bonsai mode. :p
    My buddy's Jeep in the same hole for reference:
    LT the front with bypass shocks to handle whoops at speed and link the rear to get around the ground clearance issues and you'll have a pretty killer all-around rig.
  11. Aug 4, 2010 at 11:50 AM
    ks2socal
    Ahh nice! I saw your post on RDC.
    Yeah the SUA does have me a lil worried, I think ill get some pricing for a 4link setup and compare the two.
    I wish the all pro had the option of a bypass.
    You sure made the jeep look bad:p
  12. Aug 4, 2010 at 11:51 AM
    mjp2
    NJ
    He made up for it on some BIG rocks later in the day. :eek:
  13. Aug 4, 2010 at 5:30 PM
    ks2socal
    mjp2- What size tire are you running?
  14. Aug 5, 2010 at 7:43 AM
    mjp2
    NJ
    305 70/16. Basically a 33x12 tire. They ride nice but I could definitely stand to regear. It's on the list for this winter.
    Even with the Camburg LT setup I had to trim the body mounts to clear them without rubbing. What size do you have in mind for your setup?
  15. Aug 5, 2010 at 10:38 AM
    ks2socal
    I was thinking 35's and Glass all around, maybe even a one piece front end.
    The extra ground clearance from the tires, may allow me to still do a SUA and wheel.
    Have you though of maybe making some sort of skid/slider for your leaf springs?
  16. Aug 5, 2010 at 10:41 AM
    mjp2
    NJ
    It's absolutely crossed my mind. I just haven't had time to work on it as I've been fixing other things that are more immediately needed.
    I have a driveshaft skidplate as part of my torque arm which has saved my driveshaft a ton of times. I imagine my fabricator could come up with something clever to keep that leaf pack intact. :)
  17. Aug 5, 2010 at 10:44 AM
    MrGrimm
    MrGrimm Mall Crawler
    Dean
    Wisconsin
    2006 Toyota Tacoma 4WD w/TRD Sport Package
    See build page
    From what I have been reading and what others have posted (I tend to find better information and experience on this subject from OakleyTRD on TTORA) is that the All-Pro setup is what you are looking for. This is what I may be leaning towards next year.
  18. Aug 5, 2010 at 10:47 AM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    yup, im definitely staying away from rocks after I go SUA...never liked them before, and I never will :D
  19. Aug 5, 2010 at 10:56 AM
    ks2socal
    I was the same way, until I headed to the Colorado mountains. Talk about epic scenery.
    Ill check out oakleytrd's build.
    Any word on 4x4 axles for engage?
  20. Aug 5, 2010 at 10:59 AM
    blackhawke88
    SGV, CA
    07 TRD Offroad
    yea, they are on their 3rd or 4th design thru their supplier....i havent had a need for 4x4 yet so im still waiting patiently
