MunkeyWrench's 2nd Gen LS swap
Discussion in '2nd Gen. Builds (2005-2015)' started by munkeywrench, Apr 13, 2020.
  1. Jun 5, 2023 at 11:30 AM
    #121
    johnw
    johnw Well-Known Member
    john
    orlando florida
    06 prerunner v-6 4.0L 4 door
    well you asked for specs..... 06 trd sport speedway blue 5.3l v8 4.0 camburg lift spindles extended travel icons total chaos lowers allpro 4" leaf pack 17" xd hoss rims 37/12.5/17 mickey thompson baja atz Allpro hybrid bumper grill craft grill wicked flow muffler inside i have..... wet okole real tree camo seat cover blue oznium dome light stealth sub box with 2 10" kicker comp subs kicker 400 watt amp weathertech floor mats
    I appreciate the response I got my motor and tranny and all so I was thinking bout just getting the tac unit and swapping pins on plugs to align everything properly
  2. Jun 5, 2023 at 3:08 PM
    #122
    munkeywrench
    munkeywrench [OP] Well-Known Member
    LS Swap
    No problem, let me know how it turns out. Im curious to see if there are any issues.
  3. Jun 5, 2023 at 4:23 PM
    #123
    johnw
    john
    orlando florida
    Will do I will be sending you some messages in the future most likely to see how you had stuff hooked up for wiring and all that jazz. But currently just going thru motor and tranny putting in some bolts on making sure everything else is golden and getting this thing thrown in there
  4. Sep 10, 2023 at 6:45 PM
    #124
    The_red_taco
    The_red_taco New Member
    Brock
    2011 trd Tacoma
    After market speakers and radio 32inch light bar 22x12s on 35s
    What did you do about the drive shaft
  5. Sep 11, 2023 at 8:13 AM
    #125
    munkeywrench
    LS Swap
    I used the stock drive shaft and put a GM yolk for 4L60.
  6. Oct 18, 2023 at 11:19 AM
    #126
    TacoHank1998
    TacoHank1998 Well-Known Member
    Will
    Panama City, FL
    1998 Green Tacoma Base
    Really good write up.
    So... I'm in the idea stages of potentially making this happen on Hank. I was wondering if you could make a single post with links to all the resources so I don't have to bounce through 7 pages to find them all.
    Also... in your process have you heard of someone doing the swap with a manual?! That would be the route I'd want to go. Didn't know if it would cause any additional problems.
  7. Oct 18, 2023 at 11:23 AM
    #127
    munkeywrench
    LS Swap
    Im not sure what you mean by resources?
    Yes, theres an x runner around here with a T56. You can go with a TR6060 also.
  8. Oct 18, 2023 at 11:25 AM
    #128
    TacoHank1998
    Will
    Panama City, FL
    You mentioned plenty of sites you used to help you along the way... and maybe links to a few of the needed parts.
    I'm either going this route... or 1UZ. this looks like the more cost efficient solution.
    It's for a gen 1 Taco but I can't imagine there being too much difference.
  9. Oct 18, 2023 at 11:38 AM
    #129
    munkeywrench
    LS Swap
    I can try to do that when I have some time. I used LT1swap.com pretty heavily though.
    1st gen and 2nd gen tacos are very different and the swap will not be same. Id suggest watching Project Firebolt on YouTube to get an idea of what is involved. I believe the firewall needs to be moved but not positive. The engine bays on the 1st gens are definitely smaller.
    1UZ is giant compared to an LS from a physical standpoint. Id imagine stuffing a 1UZ into a 1st gen taco will require quite a bit of fab work.
  10. Nov 18, 2023 at 9:11 AM
    #130
    laurencevillegarage
    laurencevillegarage Driven to build, built to be driven
    Sunset, Tx
    LS swapped 2nd gen
    Hello! I am new to the forum but have been very interested in your ls swap. I’m currently swapping a 5.3 into a 2nd gen truck and appreciate all your hard work and willingness to share with everyone. I do have a specific question…where exactly did you connect your ls fuel pump wire? I have constant and “key on” power, but am having trouble finding the correct connection point for the fuel pump. My pump connector has 4 wires: orange, yellow/blk (these appear to be for the dash gauge), white/blk stripe is ground leaving black /red stripe. I connected to the black wire with red stripe just outside the fuse box under the hood, no power to the pump. I’ve tried using one of the blue wires coming off of the 20 amp, EFI fuse, and again, no luck. Where did you attach your wire at, thank you in advance.
    hayrider2.0 likes this.
  11. Nov 18, 2023 at 9:40 AM
    #131
    munkeywrench
    LS Swap
    This is what I did for my fuel pump. Its on page two of this thread under PCM and Wiring.
    Fuel Pump Relay Control - Dark Green/White - PIN # 9 - This wire will be coming from your fuse box. Once the PCM triggers the relay it will supply the 12v needed to turn your fuel pump on. I connected this wire to my sending unit. By using the stock sending unit I got my fuel gauge to work on my dash
    I just spliced into the 12v wire to my sending unit. I cannot remember right now what the color combination was for the wire but I was able to splice into it under the drivers door sill.
    Hope this helps!
  12. Nov 18, 2023 at 10:14 AM
    #132
    Camazon
    Camazon Well-Known Member
    Cam
    Vancouver,BC
    06 Tacoma TRD Off Road DCSB
    This might help for the Tacoma wiring
    https://www.tacomaworld.com/threads/pigtail-connector-help.802785/
  13. Nov 18, 2023 at 11:09 AM
    #133
    laurencevillegarage
    Sunset, Tx
    LS swapped 2nd gen
  14. Dec 14, 2024 at 7:09 PM
    #134
    ethan lett
    ethan lett Member
    Ethan
    2009 ac 4x4
    How did you mount the gm radiator?
  15. Dec 19, 2024 at 1:38 PM
    #135
    munkeywrench
    LS Swap
    I never used the GM radiator. I used the stock Toyota radiator at first and later upgraded to a 3 row aluminum radiator.
  16. Dec 20, 2024 at 6:34 PM
    #136
    Camazon
    Cam
    Vancouver,BC
    I’m also running the stock Tacoma radiator. No issues so far.
  17. Jan 15, 2025 at 6:46 PM
    #137
    ethan lett
    ethan lett Member
    Ethan
    2009 ac 4x4
    How did you route the hoses? If you bought some which ones?
