My 2004 Tacoma X-Cab PreRunner
Discussion in '1st Gen. Tacomas (1995-2004)' started by Aagill225, Apr 26, 2018.
  1. Apr 26, 2018 at 8:03 PM
    Aagill225
    Aagill225 [OP] Well-Known Member
    Arthur
    2004 Tacoma PreRunner
    None
    i have a 2004 Tacoma Extra Cab PreRunner. It’s 4x2 has the locking axle and an Automatic transmission. When I bought it off my friend in November (for $4K) it had about 117k miles. Before I could do anything I installed a new water pump and timing belt (myself) and a new radiator (because I ruined the other one accidentally.
    I’ve replaced the transmission mount and center support baring. The front brake pads and all the rear brake (shoes, springs and drums)
    I completely sanded the clear coat off the hood because it was horrible and primered it. Looks a lot better but I think that has not been compromised from the sun. Doesn’t matter to me though (at this point) I’ll dig up the pics of my work and post them (I don’t have water pump or timing belt pics though)
  2. Apr 26, 2018 at 8:06 PM
    Aagill225
    Arthur
    None
  3. Apr 26, 2018 at 8:07 PM
    Aagill225
    Arthur
    None
  4. Apr 26, 2018 at 8:08 PM
    Aagill225
    Arthur
    None
    I installed new sway bar bushings tonight.
  5. Apr 26, 2018 at 8:08 PM
    Captain Magma
    Captain Magma Well-Known Member
    Patrick
    Tucson, AZ
    2002 4wd DblCab
    Kings and desert pinstripes
    Looks good man, welcome!
    Aagill225[OP] likes this.
  6. Apr 26, 2018 at 8:16 PM
    Aagill225
    Arthur
    None
    jammer and 04Burk like this.
  7. Apr 26, 2018 at 8:16 PM
    Aagill225
    Arthur
    None
  8. Apr 26, 2018 at 8:17 PM
    Aagill225
    Arthur
    None
    I did also restor the headlights. That’s not that exciting though.
  9. Apr 26, 2018 at 8:20 PM
    Aagill225
    Arthur
    None
  10. Apr 26, 2018 at 8:21 PM
    Captain Magma
    Patrick
    Tucson, AZ
    2002 4wd DblCab
    Bear Down!
    Aagill225[QUOTED][OP] likes this.
  11. Apr 26, 2018 at 8:24 PM
    Aagill225
    Arthur
    None
    Not exactly Discrete. Hahaha. Probably the only Taco in San Diego county like this.
  12. Apr 26, 2018 at 9:15 PM
    Aagill225
    Arthur
    None
    Can anyone recommend a leaf spring bushing kit?
  13. Apr 26, 2018 at 9:38 PM
    whitetaco01
    whitetaco01 Well-Known Member
    So Cal
    01 Prerunner
    Mid Travel Stuff
    I've had pretty good luck with the energy suspension ones. You have to hammer out the existing metal sleeve in the eye though
  14. Apr 26, 2018 at 10:13 PM
    Aagill225
    Arthur
    None
    Thanks
  15. Apr 26, 2018 at 10:15 PM
    whitetaco01
    So Cal
    01 Prerunner
    Mid Travel Stuff
    Greaseable shackles would be ideal but of course more $$
  16. Apr 27, 2018 at 8:24 AM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    First, welcome to TW, nice looking truck and pretty sure you got a steal of a deal, good work!
    Being a Cali truck rust doesn't seem to be an issue so that's a positive.
    I think I have a set of the ES bushings for the leaf springs, I'd have to check. You may be due for new leafs though as I see "helper springs" are installed already and you are starting to get a negative arch.
  17. Apr 27, 2018 at 5:06 PM
    Aagill225
    Arthur
    None
    It was used as a work truck for a DIRECTV installer for about 50k miles maybe more. The springs have had a rough life. I’m looking at just replacing them now. Not sure if I should go with the regular of heavy duty. A previous reply says the heavy duty add some lift. Not sure that’s what I need. It does have a 3+1 pack on it though.
  18. Apr 28, 2018 at 9:23 AM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    yeah, 3+1 is the norm. the overload spring is the +1
    here is a very reputable site that some Tacoma owners have used
    https://www.generalspringkc.com/Leaf_Springs_Toyota_Tacoma_2001_2002_2003_2004_s/1932.htm
    they sell standard and HD for reasonable prices. the HD will hold more but a little stiffer ride.
    keep in mind you will be going from a worn out leaf pack to new so if you don't plan to haul anything you should probably stick with the standard.
  19. May 8, 2018 at 7:46 AM
    Aagill225
    Arthur
    None
    I recently replaced the rear brakes. When I went to use the e-brake it was very very loose. It’s odd because before the replacement it was tight and I probably only got 3-4 inches of pull on then brake lever.
    I adjusted the e-brake properly and even adjusted the brake cable. Does anyone know why there would be so much slack after installing new parts?
  20. May 8, 2018 at 9:04 AM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    did you adjust the star wheel when you replaced the brake shoes? you can do this from the backing plate, there is a rubber plug that can be removed
    https://www.yotatech.com/forums/f16/adjusting-rear-drum-brakes-easy-way-43741/
