My 3 in suspension lift, Do I need anything else?
Discussion in 'Suspension' started by R.etheridge, Mar 14, 2010.
  1. Mar 14, 2010 at 6:16 AM
    R.etheridge
    R.etheridge [OP] Well-Known Member
    Middle GA
    03 Tacoma TRD 4x4
    I have a 03 4x4 TRD DC and I have put together a suspension lift. I wanted to know if you guys think I need anything else to go with it. I am doing this on a budget but if I need something else then I can go get it. Tell me what you think:
    Bilstein D558TO front shocks
    Bilstein D559/0560 rear shocks
    rev tec 10mm lift enhancer kit
    rev tec dif drop kit
    wheelers add a leaf set with extended length U bolts
    extended rear brake line
    I have all new energy suspension bushings as well that will be going on. Am I missing anything for a solid 3in lift?
  2. Mar 14, 2010 at 4:57 PM
    R.etheridge
    Middle GA
    03 Tacoma TRD 4x4
    anybody, just tell me if im good with this or do I need something else
  3. Mar 14, 2010 at 9:04 PM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    Looks good to me. The only thing that you might want to add is a shim to put under that AAL. When you lift the rear it changes the angle on your driveline, a shim will effectively rotate your axle a few degrees so that it's closer to stock angle.
    It's kind of a hit or miss on a 3" lift. The best way to find out is if you have vibration coming from the rear after the AAL it's probably your driveline angle = get a shim. If no vibration then you're good!
    Also, I don't know jack about the Bilstein setups really, but do you need aftermarket springs to achieve more lift? Somebody can chime in.
  4. Mar 15, 2010 at 3:28 AM
    R.etheridge
    Middle GA
    03 Tacoma TRD 4x4
    My stock springs should be fine. Ive installed a 3in before on a 98 and sued stock springs and had no problem with it. Thanks for the input. Im ordering the parts today
  5. Mar 15, 2010 at 3:49 AM
    Mondwa
    Mondwa Well-Known Member
    Michael
    Phoenix, AZ
    08 V6 Tacoma
    remote start, Allpro bumper, Slimchubby HID, MetalMiller custom Emblem
    What are you paying for that setup if i might ask? There is a member on here selling their toytec 3" never used
  6. Mar 15, 2010 at 5:34 PM
    R.etheridge
    Middle GA
    03 Tacoma TRD 4x4
    getting it for about $650. I heard there are lots of problems with the toyo tec lifts for the 01-04's
  7. Mar 16, 2010 at 8:05 AM
    Toytec Lifts
    Toytec Lifts Toyota Suspension specialist Vendor
    Rocky Mountains
    Toyota's are awesome
    Like what?
  8. Mar 16, 2010 at 8:12 AM
    mjp2
    Milton Juevos Portimous II
    NJ
    '06 TRD Access Cab, v6, 6-speed
    Scaffolding and a painted grill
    :cool:
    Bump for an answer. I've never heard a complaint but this would definitely be the place to get a concern addressed!
  9. Mar 16, 2010 at 8:17 AM
    blake1012
    blake1012 Go Braves!
    Chazz Michael Michaels
    Duluth, GA
    2003 ext cab. tacoma.
    8000k HID's, Weathertech Digital Fit floor liners, Rhino Lined bed, 16x8 TRD Ivan Stewart wheels, bull bar, step rails, Redline Tuning hood struts, low profile tool box
    Who? Im interested
