My A/C compressor turns on and shuts off every 20 seconds.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by PuyallupJon, Jun 30, 2016.
  1. Feb 27, 2017 at 11:07 AM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    How would you know, you can't hear or see it while driving?
  2. Feb 27, 2017 at 11:08 AM
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    Just an FYI on this, the 2016-17 Tacoma does not use R134a, it uses R1234yf. Don't use R134a in the A/C system.
    Jeff
  3. Feb 27, 2017 at 11:08 AM
    PuyallupJon
    PuyallupJon [OP] 2020 AG Pro
    Jon
    Puyallup, WA
    2020 Tacoma
    It feels like the engine misses.
  4. Feb 27, 2017 at 11:10 AM
    JoeCOVA
    Joe
    Colorado Springs
    I'm not sure what you mean by misses, unless you are referencing a misfire but how the heck would the AC create a misfire feel. Its just a pully on a belt..
  5. Feb 27, 2017 at 11:11 AM
    PuyallupJon
    Jon
    Puyallup, WA
    2020 Tacoma
    When the compressor comes on and off is what I'm told.
  6. Feb 27, 2017 at 11:12 AM
    JoeCOVA
    Joe
    Colorado Springs
    RPMs may change slightly. Every car I have ever owned has had the A/C cycle like you described. A misfire is more drastic, then engine will clunk/shudder and bog and despite giving it full power it won't go, is that what is happening? The issues may be unrelated.
  7. Feb 27, 2017 at 11:14 AM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz, CA
    99’ Bro-Coma’s Revenge 3RZ 345k+
    Stock
    Couple of things, do you have an auto temperature setting, and is the defroster on. I'm pretty sure that anytime the defroster is on, so is the AC pump.
    Let me tell you, my 2.7 knows when the defroster is on.
  8. Feb 27, 2017 at 11:17 AM
    Hank Heel
    Hank Heel Well-Known Member
    WA
    Not sure if this has been mentioned, by default ac will cycle(will do this wether or not hvac is in auto) when heater is set on windshield defog, I now run it at feet and hands setting, unless it's raining heavy. Not a solution, just what I have to live with.
    Op what you gonna replace it with?
    Edit: I wanna like this thing given the fact i spent 40k+....I do kinda wish I had gotten a 15 pro, despite it having less interior gadgets
    smitty99 likes this.
  9. Feb 27, 2017 at 11:23 AM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz, CA
    Stock
    Another thing, looks like the OP has an SR. My 2.7 will hesitate if I go from light throttle and then punch it. I always attributed it to the VVTI changing. It does sort of feel like a miss.
  10. Feb 27, 2017 at 12:15 PM
    PuyallupJon
    Jon
    Puyallup, WA
    2020 Tacoma
    Actually, I have the TRD Sport now.
    I guess it's just normal.
    JoeCOVA likes this.
  11. Feb 27, 2017 at 12:50 PM
    Tacoma_MS
    Tacoma_MS Active Member
    Mississippi
    2017 White TRD Sport DCSB
    2017 Tacoma TRD Sport here. Had a similar issue to what you are describing. Turns out is was a bent pin in one of the A/C connectors components. It was cycling constantly, but would not blow cool air, and eventually wouldn't blow at all. Does this sound similar to your problem? I can get the full report on what they fixed on mine if it helps. Good luck.
  12. Sep 8, 2017 at 2:04 PM
    BULL84
    BULL84 Active Member
    SC
    17' Quicksand Tacoma TRD OR 4X4
    Did anyone ever find a resolution for this? My 17 OR does something similar when it's around 85 degrees outside, constantly seems like it's switching off and on, but when it's 90+ it blows ice cold. Mine doesn't have any "lag" though. Pretty frustrating.
  13. Sep 9, 2017 at 7:56 AM
    EdgeCrusher
    EdgeCrusher Well-Known Member
    Chicagoland
    '16 OR DCSB Fully Loaded
    normal for vehicles of the modern age
    Herniator likes this.
  14. Sep 9, 2017 at 8:51 AM
    r1200gs4ok
    r1200gs4ok Well-Known Member
    O. K.
    Irvine, Ca
    2016 Tacoma TRD Sport DCLB w/ Tech, Nav, Tow Pkg, MGM
    i have owned several Toyota's over the years......all of them have had the a/c cycle at idle.....very annoying......however, of my 4 Lexus's, none of them cycled where it was noticeable at idle..... being a Toyota product, they would probably use the same compressor
