my bed is crooked
Discussion in '2nd Gen. Tacomas (2005-2015)' started by builthatch, Jan 22, 2011.
  1. Jan 22, 2011 at 2:30 PM
    builthatch
    builthatch [OP] MiG-21 superfan
    Tony Mandarich
    near the ocean, NJ
    '11 SSM SR5 6 speed 4x4
    Hella DOT wattage high performance 9003 headlight bulbs, Optilux by Hella XY h10 fog light bulbs, Suntek HP50 tint, AFE Stage II Si intake
    it is a brand new truck. apparently this is somewhat normal. it's probably about a 1/4 of an inch over to one side vs. the cab. i'm trying to remember which side - i believe it's further over on the passenger side.
    there is an old thread on here about it and it was said that trying to adjust it is like opening a can of worms. i agree. usually stuff like this bothers me but if it's within spec and normal, i'll leave it.
  2. Jan 22, 2011 at 2:35 PM
    paintdiddy
    paintdiddy Machine gun shits
    shithead
    nj and not from "the jersey shore"
    silver bullet
    My truck is the same way.it's like 1/2"in inwards on the drivers side and perfect on the passenger side. It goes to dealer Monday for that and my chirping blower motor. I'll let you know what bullshit the dealer gives me
  3. Jan 22, 2011 at 2:37 PM
    Hoyal
    Hoyal Whiskey bent and hell bound.
    Devin
    N 39.2249 W -106.16974
    2013 Tundra
    Big tires, big lift, Lots of stuff's.
    The lean should be more on your drivers side and this is the "taco lean" A 1/4 top plate spacer on the drivers front will fix it. If that is what the problem is.
  4. Jan 22, 2011 at 2:42 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    15 Lariat Sport 5.0L
    i think they're talking about the alignment of the bed on the frame, not the taco lean. the bed alignment can be remedied by loosening the bed bolts, adjusting to where you want it, then tightening them back.
  5. Jan 22, 2011 at 2:44 PM
    builthatch
    Tony Mandarich
    near the ocean, NJ
    yep : )
    thanks.
    yeah, like i said, i found one thread where it appears to be pretty normal. there is a tolerance, though i am not sure what that is.
    the fan...i hope they are redesigning them because they have been on back order for a while. it was making the cricket sound on low and i took it in, and couldn't reproduce it. it hasn't done it since BUT if it does, unless i find proof of a redesign, i'm gonna sit tight. apparently someone installed the TYC piece available online and IT does the same thing, lol.
  6. Jan 22, 2011 at 2:44 PM
    Hoyal
    Devin
    2013 Tundra
    Ah yeah I've heard of that. Seems like it would be an easy fix with a few buddies.
  7. Jan 22, 2011 at 2:48 PM
    builthatch
    Tony Mandarich
    near the ocean, NJ
  8. Jan 22, 2011 at 2:51 PM
    The_Hodge
    SC
  9. Jan 22, 2011 at 3:45 PM
    paintdiddy
    shithead
    silver bullet
    My only problem with loosening the bed and moving it is the other side will be off.im going to push for a new compisit bed.I know its joke but I'll give it a shot.
  10. Jan 22, 2011 at 3:51 PM
    Dadic 78
    Dadic 78 Well-Known Member
    Fil
    Edmonton, AB CANADA
    08 Double cab TRD
    I think it gives it character being offset. :)
  11. Jan 22, 2011 at 3:53 PM
    jandrews
    '09 FourDubDee TRD OR
    Mine isn't.
  12. Jan 22, 2011 at 3:54 PM
    paintdiddy
    shithead
    silver bullet
    Screw you :D lol
  13. Jan 22, 2011 at 3:57 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    There is possibly some mismatch between the bed and frame. There may also be some mismatch between the composite bed and the metal bed sides.
  14. Jan 22, 2011 at 3:59 PM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    Go outside and tell him if he doesn't straighten up he's not getting any gas. That will make him think twice about being crooked.
  15. Jan 22, 2011 at 4:10 PM
    Fagro
    Fagro Active Member
    RI
    10 DC LB SR5
    Extang Trifecta, LED Console lighting, VentShades
    I noticed this on mine after I read about it here. If I eye down the outer bed sides from the rear, it is obvious the bed is shifted to the pass side a bit. You can tell by how much the cab stick out.
    Not a big deal, but now that I know it exsists. :mad:
  16. Jan 22, 2011 at 4:10 PM
    Fire931
    Fire931 Well-Known Member Vendor
    VA
    00 4Runner
    I can tell you from installing numerous rear bumpers that it's pretty common for the beds to be off a little. I've had to adjust quite a few beds in order for the bumper to match up perfectly, and in doing so can usually make it match the cab better as well.
  17. Jan 22, 2011 at 4:14 PM
    Bumponapickle
    Bumponapickle Well-Known Member
    Ontario, Canada
    09 TRD + Leather DCLB
    Old Man Emu 3 inch lift + AAL, Satoshi and Pioneer Avic Z130BT
    I have had my 09 DCLB since brand new and wasn't till this past summer out waxing it that I noticed the box was offset. A ratchet and the four bolts in the box and easily corrected. Nothing to it, but it is a common thing....
  18. Jan 22, 2011 at 4:19 PM
    The_Hodge
    SC
    you have to find a medium between the two sides.
  19. Jan 22, 2011 at 5:20 PM
    DrRabbitFurHead
    DrRabbitFurHead Yeah, there's a TSB for that!
    Salem, VA
    X-treme Off Road Edition (4x4)
    Icon Extended Travel Coil Overs, Fox Rear Resi 8-Way Adjustable Shocks, Light Racing UCA's, OME Rear Leafs, M/T Classic Locks 17x9, Nitto T/G (285/70/R17), 5mm Billet Aluminum Spacers, Demello Sliders, All Pro Front Plate Bumper & IFS Skid Plate, PIAA 510's, Doug Thorley Long Tube Headers, O2 sims, Rear Timbren's & U-Bolt Flip Kit , 3* Rear Axel Shims, Extended Rear Brake Lines, 48" Hi-Lift with a ton of accessories, Wet Okoles, TRD bed mat, Borla Air Filter, Garmin Nuvi 765T, Viper 5901 remote start, 50% tint.
    Now THAT'S customer serivce! :D
    I swear one of these day's I'll be getting a rear bumper from you... I just keep spending my mod money elsewhere! ATO FTW!!!
  20. Jan 22, 2011 at 7:09 PM
    paintdiddy
    shithead
    silver bullet
    Yeah I guess your right
