my BLHM post
Discussion in 'Lighting' started by eschonle, Apr 2, 2010.
  1. Apr 2, 2010 at 5:56 PM
    eschonle
    eschonle [OP] Well-Known Member
    eric
    Seattle, WA
    2006 V6 SR5 4x4
    TRD Cat back Exhaust, Leer Shell, BHLM, Satoshi Grill
    finally got that damned 4th bolt out...that son of a bitch is a pain
    I accidentally took out the bolt below it though.. doesn't look like anything serious will fall off because of this.
    oven is preheating now at 300
    How do i get the bulb out of the assembly?
  2. Apr 2, 2010 at 5:59 PM
    eschonle
    eric
    Seattle, WA
    2006 V6 SR5 4x4
    Before
  3. Apr 2, 2010 at 6:00 PM
    Rucas
    Rucas 1st gen
    Lucas
    1st gen. 4x4
    Custom Aluminum Camper
    should just twist outa there
  4. Apr 2, 2010 at 6:09 PM
    eschonle
    eric
    Seattle, WA
    2006 V6 SR5 4x4
    ok so the bulbs are out of the lens/plastic housing. Does the entire thing go into the oven?
  5. Apr 2, 2010 at 6:25 PM
    Viet2100
    Viet2100 Well-Known Member
    Viet
    South Florida
    2016 Prius 4T
  6. Apr 2, 2010 at 6:27 PM
    eschonle
    eric
    Seattle, WA
    2006 V6 SR5 4x4
    sorry to be a pain man, i got like 3 seperate tabs open on Tacomaworld for research, I missed this mod. Thanks
  7. Apr 2, 2010 at 9:44 PM
    eschonle
    eric
    Seattle, WA
    2006 V6 SR5 4x4
    welp, I finally finished the BHLM. What a sense of accomplishment!:D It's dark now so I'll post some pictures tomorrow. The only thing concerning me is 1) when i was going for the elusive 4th bolt removal i accidentally took out the bottom one. 2) i have 3 of those black plastic clips left over :confused:..yikes. everything seems snug though!
    the third thing is my headlights might need adjustment...not sure though. anyone have problems with that?
    Edit: Did anyone else's oven smell weird afterward?
  8. Apr 3, 2010 at 1:02 PM
    yosh2000
    yosh2000 Well-Known Member
    CO
    '17 Tundra CM 5.7
    1 - so put it back in
    2 - did you put the ones for the bottom trim piece in?
    3 - no adjustment should be needed
    4 - yes, oven smells a little weird, it will go away quickly though!
