My brake line adventure
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bearskill, Jan 15, 2010.
  1. Jan 15, 2010 at 12:25 AM
    Bearskill
    Bearskill [OP] Well-Known Member
    Sac
    06 Access cab PreRunner Sport
    FlowMaster 40 duals out the back, T-Rex grill, Color matched TRD Nerf bars, Icon coilovers set at 2'', 2.75" OME Dakars spring packs, OME Nitro-Charger extended rear shocks, Carrier bearing drop kit, Wheeler's Extended break Lines, Total Chaos UCAs, Mojave Teflons and 31 1/2" Toyo Open Country A/Ts, Pioneer single din unit, Yakima roof rack, Malone roof basket with X2 KC 130w long range Slimmlights mounted to it, Garmin 255w nav, Fire bottle mod, Air Force standard First Aid kit mod, Hidden Muchette mod (don't ask), and 1 huge OCD about my truck.
    So...... about a week ago was putting on some extended brake lines. Stripped one out. The factory hard line that runs the length of the truck. I wrote about it and how bad it sucked on here already. Well, was double checking stuff out. The other side was totaly leaking!!! I am never "F" ing with my brake lines ever again!!! Just to be safe, when I ordered the drivers side line the first time I ordered the Pass side too. Thank god I did. Called up Wheelersoffroad.com and had them over night me another single extendy. Pretty much the last to weekends I have been laying in brake fluid under my truck. The lines I am talking about must have been one of the first thing they put on at the factory. Such a pain in the ass to get it fed through the frame and behind the gas tank!! Anyway, I hope no one ever has to do what I did. And a huge thanks to Wheeler's for selling me a single line and over nighting it to me!!!!!!!!!!
  2. Jan 15, 2010 at 8:26 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Welcome to the world of automotives & machinery. I can totally relate.
    The other day (at work), I had some problems with air cylinders not working. I traced it back to a 6" piece of air line that had a 1" crack in it. It's an airline.... easy to replace (2 fittings & cut a new air line). Yeah....not when you have to take half the machine apart to get your hands in there to work on it. OMG!! Took me 2.5 hours and my hands were black as coal and my clothes were filthy!
    Yup.....its kinda like that somedays.
  3. Jan 15, 2010 at 8:32 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Damn dude- This is a never ending nightmare for you. Is it all settled out now?? or are we still waiting to see??
    And did you get all the brake fluid cleaned up?? That shit will wreak paint and plastic if it's left there.
  4. Jan 15, 2010 at 8:38 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    Might have been worth buying a shorty section of SS line, brake line flaring tool, and a quality coupler. You could have cut off the stripped end and attached a length of line to compensate for what you had just removed.
    I know it's a bit late for the advice but it's an option if you run into trouble in the future. For what it's worth, your approach is the better one anyway. The fewer couplings in your brake system, the fewer points of failure.
    Congrats on getting the job done. It's gotta feel good to drive the truck again! :thumbsup:
  5. Jan 15, 2010 at 8:40 AM
    HondaGM
    HondaGM CallSign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    i heard oil is good for old peoples skin:cool:
  6. Jan 15, 2010 at 8:55 AM
    Janster
    Jandy
    Lancaster, PA
    :D
    Too bad it was just on my hands. Is that why oil wrestling is good for you?
    :eek::p:D
  7. Jan 15, 2010 at 8:59 AM
    mjp2
    NJ
    Works great for sorority girls! Pillow fights too. :drool:
  8. Jan 15, 2010 at 9:16 AM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    yes,it can be very benificial to waller all in it.
  9. Jan 16, 2010 at 9:36 AM
    Bearskill
    Sac
    See, when I stripped it the first time my buddy busted out his flairing tool and tried. But it just mushroomed the wrong way instead of flairing. thats what led to ordering new lines. Also, We were playing with the old lines and you can bearly kink these lines! We just about had to tie the line in a knot to get it to kink on us. GOOD break lines.
  10. Jan 16, 2010 at 9:46 AM
    Bearskill
    Sac
    Ya, all said and done. After I bled my system I had my helper hold the break peddle down for like five min as I watched for leaks. No drippy drippy. Still keeping an eye on it. Might have to bleed them again. But as for the lines, they seem to be good. AND THEY BETTER BE!!!!!! Just replaced 75% of my lines with new shiz! lol. Oh, and a heads up to anyone else that want to put extended lines in.
    The factory flex lines above the rear axle are side specific. the extended lines are not. the brackets that hold the flex lines have diffrent shaped holes for the diffrent line. While the aftermarket lines will fit the drivers side dedicated bracket, they will not fit the hole that holds the pass side. Save your self some swearing and take the braket off, get a little file, nothing crazy, and reshape it to hold the new flex line. just keep track which side is which. Oh ya, and don't over tourque shit. :rolleyes:
