My Clutch is Squeaking?!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Taco227, May 23, 2012.
  1. May 23, 2012 at 6:15 PM
    Taco227
    Taco227 [OP] Well-Known Member
    Maryland
    TRD Sport
    3" Pro Comp suspension kit, 1.25" front wheel spacers, tinted clearance lights, 4 pioneer speakers, Sony head unit, Custom Sub enclosure with 10" MTX, dash kit, wicked flow exhaust, Firestone Airbags.
    I have a new noise coming from the engine bay. It appears to be a squeak from the clutch system. When I push down the clutch pedal you can hear it. Any ideas on what it could be? Throw out bearing? Clutch grabs fine, just squeaks.
  2. May 23, 2012 at 6:29 PM
    iroh
    iroh Well-Known Member
    michigander
    07 AC SR5 2.7 5MT 4x4
    tonneau
    You have the 1st revision fork+throwout bearing. Those will all start to squeak eventually due to wear on the transmission nose. Supposedly bad geometry with the fork causes too much side-loading on the aluminum nose from a steel throwout bearing.
    Many with the condition go the route of the URD oversized throwout bearing + steel sleeve that fits over the aluminum part.
  3. May 24, 2012 at 6:13 PM
    Taco227
    Maryland
    TRD Sport
    What's the repair bill on that one? Parts? No labor
  4. May 24, 2012 at 6:22 PM
    ouyin2000
    ouyin2000 Well-Known Member
    Nova Scotia
    '11 DCSB TRD Sport
    Leer 100XL Canopy, OEM Side steps, TRD Oil Cap, TRD License Plate Cover, WeatherTech Digital Fit Liners, Elite O/R Hitch Shackle, Katzkin Leather Interior, LED Interior Lighting, Foglight Anytime mod, Illuminated 4x4 switch, Grom Audio Aux adapter, Redline Goods leather shift boot console cover and door handle pulls, Sockmonkey bedside decals, Dynolock electric tailgate lock
    Umm...see if you can identify where the noise is coming from. If it's at the clutch pedal itself, it's just a plastic bearing rubbing, nothing serious at all. I had that issue on mine after only 11,000 km.
  5. May 24, 2012 at 6:26 PM
    Taco227
    Maryland
    TRD Sport
    How much longer do you think i have until it goes up?
  6. May 24, 2012 at 6:29 PM
    Taco227
    Maryland
    TRD Sport
    It's definitely from the engine bay or underneath in the case.
  7. May 24, 2012 at 6:31 PM
    Forster46
    Forster46 Very nice how much?
    Nick
    Mount Vernon, WA
    The doritos locos taco
    6000k HID's, AUX Reverse Lights, 3" Rough Country Suspension Lift, Pioneer AVH-P4200 Double Din, Underglow and footwell Lights, Camo Seat Covers, Duralast Tool Box, Blacked Out Badges, Grill, Front Emblem, Midland CB Radio, Amber Strobes, POWER REAR WINDOW, cup holder LED's, Firestik 3' in bed, console divider, Ultragauge.
    Mine squeaks ever since I got it, really really loudly. Sounds like the same place you described. Seen a lot of posts about fixing them, just been too lazy to do it.
    I really hate squeaking it at every stop sign and stop light though.
  8. May 24, 2012 at 6:47 PM
    Taco227
    Maryland
    TRD Sport
    It's not an inside of the cab squeak. It's definitely coming from the clutch underneath the truck in the case.
  9. May 24, 2012 at 7:58 PM
    Honda650
    Honda650 Member
    Fort Worth, Texas
    08 DC TRD 4x4 SB
    DE-BADGED, Billies @.85, TSB Leafs, TRD Seat Covers, TRD Cat Back Exhaust, Seat Belt chime mod, pop lock. BFG AT 265/75/16 Load Range E, Front Mud Flap Off! Alpine INE-S920HD, AFE Pro Dry S Filter,Access LE Tonneau Cover
    Deal with it! If your truck is under warranty tell the dealer and the squeak will be gone. If your over warranty grease the clutch by the spring, also the squeak is almost non existent in cold weather, hot weather like now it comes back:(
  10. May 25, 2012 at 9:38 PM
    Taco227
    Maryland
    TRD Sport
    I've had it year round but it's much noticeable now. I think it's the throw out bearing.
  11. May 25, 2012 at 9:47 PM
    jassco
    jassco Well-Known Member
    NH
    2023 TRD Offroad
    If the truck is on then could be the shaft tsb.....what everyone said, but if the truck is off then you may have what I have. The shift fork rusts to hell and you can see where it binds on the slave when you press the clutch in. I had to soak my slave and fork in silicon spray for it to go away. Comes back after driving in the rain.
    Dealer(s) won't do anything for me, so I keep spray in my door. It sure sounds like the pedal until you open the door and listen to it under the truck. 25k lovely miles in.....
  12. May 25, 2012 at 10:07 PM
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2023 White TRD Off-Road doublecab
  13. May 26, 2012 at 5:55 AM
    iroh
    michigander
    tonneau
    That's good for fixing the creak, not so much the squeak. I have to do that every couple months
  14. May 26, 2012 at 6:36 PM
    Stick Sh1ft
    Stick Sh1ft Active Member
    Tim
    Southern IL
    11 White Reg Cab 4x4 5spd
    Tonneau Cover
    I know what problem you're talking about, Gelo, but it seems his is coming from the engine bay rather than the free play adjuster. My dad's Yaris had this exact same problem, some Cheetah Grease on the linkages fixed it right up. Getting the boot back on was a major PIA though. Also not sure of the exact location of the one on the Tacoma, haven't looked recently.
