My clutch replacing efforts
Discussion in '1st Gen. Tacomas (1995-2004)' started by dylandercole, Nov 15, 2009.
  1. Nov 17, 2009 at 11:33 AM
    #41
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    the second one down show a picture
  2. Nov 17, 2009 at 11:35 AM
    #42
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Id look for ya, But Im kinda busy....It should be in here:
  3. Nov 17, 2009 at 11:42 AM
    #43
    dylandercole
    dylandercole [OP] Well-Known Member
    Dylan
    Santa Cruz Mountains, CA
    03 SR5 TRD 4x4 5-speed
    sway-a-way 2.0 coilovers, 1.5'' AAL, 1'' toytec shackle lift, Go-Rhino 3000 Grille Guard, Kicker KS6502 speakers, JVC KD-S24 Head unit, billstein 5125 rear shocks, Deck Plate mod, K&N air filter, Wheelers offroad front and rear braided brake lines, diff breather mod, power slot rotors, ebc yellow stuff pads
    I wouldnt have you waste your time looking for me chris. Youv done plenty bringing these up for me. your awsome. but im still having trouble finding it. ill look through these. I just wanted to see if anyone that hod done this knew if i assembled it right
  4. Nov 17, 2009 at 11:53 AM
    #44
    AlexForbesR6
    AlexForbesR6 My R6 Eats Me
    Alex
    Houston, TX
    07 4x4 6-Spd
    hmm...where can i buy a throwout bearing anyways?
    i just ordered my clutch and flywheel set but i can't find where to get a throwout bearing?
  5. Nov 17, 2009 at 11:56 AM
    #45
    dylandercole
    Dylan
    I got the throw out bearing, pilot bearing, clutch pad, and pressure plate all in one box from napa autoparts
  6. Nov 17, 2009 at 6:31 PM
    #46
    dylandercole
    Dylan
    bumping this just to see if anyone could help me with the thowout bearing situation.
  7. Nov 17, 2009 at 6:44 PM
    #47
    BLKTRD6SP
    BLKTRD6SP Well-Known Member
    Tim
    Crane Lake Alberta
    09 Black TRD 6 Speed
    2 way remote start,3M rockguard
    Repair Manual##Clutch##Clutch Unit##Removal
    Scroll down
  8. Nov 17, 2009 at 6:57 PM
    #48
    dylandercole
    Dylan
    where can i find the repair manual online. google failed me
  9. Nov 17, 2009 at 6:59 PM
    #49
    dylandercole
    Dylan
    nevermind i saw it on the last page. my bad. Yea i have that picture and others but i still ant get it
  10. Nov 17, 2009 at 6:59 PM
    #50
    Yoytoda
    Roland
    completely stock
    You have it right. The spring on the back side clips over the pivot point on the housing.
  11. Nov 17, 2009 at 8:31 PM
    #51
    dylandercole
    Dylan
    no i get that. im talking about the clip that holds the bearing to the lever. not the clip that holds the lever to the transmission
  12. Nov 17, 2009 at 9:21 PM
    #52
    Yoytoda
    Roland
    completely stock
    that looks right too. the pressure plate does hold tension on the bearing. I undwerstand your concern but without being there it is hard to say whether it is too loose. the bearing stays lined up over the shaft. As long as its not "falling apart" you should be fine. I had an isuzu amigo that didnt have a clip, it only relied on the shaft to keep it in line and the pressure plate "fingers" for tension. The isuzu design was a bit different than yours but with the clip it should hold the bearing to the lever. Like i said its not going to slide off but the clip keeps it lined up and keeps it from pulling away from the "fork"
  13. Nov 17, 2009 at 9:33 PM
    #53
    gofas
    gofas Well-Known Member
    Russell
    Ukiah
    4x4 Timberland Mica Access
    ImMrYo review mirror bracket.
    turned flywheel?
    just curious
  14. Nov 18, 2009 at 12:33 PM
    #54
    dylandercole
    Dylan
    ok update time. I have everything put back together besides the front and rear driveshafts and refilling the master resavoir and bleeding it and making sure thats all nice and good. But of course theres a problem. Somehow Im missing 4 bolts that connect the clutch cover to the bell housing..... had to call a stealership and for $20 ill have them either tomarow morning or friday morning at the latest. It sucks because even when i get it all together I dont want to test drive it for fear of that cover falling off and exposing everything. project is brutal. almost been at it for a total of 30 hours. almost done though
  15. Nov 18, 2009 at 12:36 PM
    #55
    Yoytoda
    Roland
    completely stock
    itll be worth it in the end to say "I fixed my truck" Great job, two thumbs up. You ought to be proud of yourself most people wouldnt take on a tough job...gives you respect to the grease monkeys who do that crap day in day out though...F that!
  16. Nov 18, 2009 at 12:41 PM
    #56
    dylandercole
    Dylan
    hell at least i know why they charge so much now. by the way just hooked you up with a rep. thanks for all the help, support and kind words. I really appreciate it
  17. Nov 18, 2009 at 12:43 PM
    #57
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Good Job!!
  18. Nov 18, 2009 at 12:47 PM
    #58
    dylandercole
    Dylan
    Oh boy, dont jinx it. Job aint done yet. Ill be able to breath when that truck a) starts. b)doesnt blow up. c)shifts gears without exploding.
  19. Nov 18, 2009 at 12:48 PM
    #59
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The hard part is done, and you went at it fist first. Thats reputable. :)
  20. Nov 18, 2009 at 12:58 PM
    #60
    Masada
    Masada Well-Known Member
    Taylor
    Laveen, AZ
    05 Tacoma 4x4 TRD Off Road
    All Pro Steel Plate Front Bumper| All Pro Light Bar| All Pro IFS Skid Plate| All Pro E-locker guard| PIAA 510 Fog Lights| Hella 700FF| Fox 2.5 Coilover| Bilstein 5100 on the rear| BHLM| Grill Craft MX Series insert| Added two D-rings to bed|AVID Off Road sliders| AFE Dry Flow S| Gibson Cat Back| Custom Bedbar with hilift mount| Camburg 1" Uni-Ball UCA's| Hi-Lift 48" Extreme
    I just caught this thread, I remember doing this in my '94 pick up. It was a beast, you're doing a great job. keep up the work and it will be back together and on the trails soon! Next time will be easier... ;)
