My Differential Breather Mod Photos
Discussion in 'Technical Chat' started by David K, Sep 5, 2010.
  1. Sep 5, 2010 at 5:44 PM
    David K
    David K [OP] Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    After getting muddy water sucked into my 2010 Tacoma differential, on the trail to/ from Mision Santa Maria in Baja California... and being instructed by HB Murphy to do the mod described here on TW... I ordered the parts from my dealer (Union & Breather for $12) and bought 6 feet of 3/8 x 5/8 yellow pressure tube from Lowes plus a couple of hose clamps.
    The breather is on top/ left side of the pumpkin (rear differential) 18 inches above ground level. It is a there to allow hot gear vapors to vent. The problem is that if we cross any streams or mud pits deeper than the breather (18"), contamination can occur... and did in mine, per the tech at my dealer.
    I dropped the spare tire to permit easier access (and to turn the spare over, so we can get to the air fill valve stem in the future).
    I removed the stock breather with a 14 mm or 9/16 open end wrench.
    I installed the union (#90404-51319) with teflon tape wrapped on the threads.
    I added my 6 foot piece of 3/8 x 5/8 pressure tube (later trimming about 1 foot of excess)... having the excess made working the tube through the frame and openings easier.
    I drilled a 5/8" hole in the side of the storage box on the left side of the bed.
    I pulled the tube through the hole, cinch tied the run to the differential in a couple of places with extra along the route to allow for axle movement.
    I cut the excess amount of tube, added the hose clamp, the breather (#90930-03136) and tightened the clamp.
    DONE... High water beware!
    PS, for those who are wondering... the front differntial has an extended breather, in the engine compartment... who knows why Toyota didn't do the same on the rear?
  2. Sep 5, 2010 at 5:48 PM
    David K
    Here is the stock (threaded) breather from the differential, and the new one with the insert barb for placing at the end of a tube.
    Note that there is a chance the factory front breather we use for this mod could become blocked, perhaps from repeated contact if installed in the fuel bay, as done in another thread on this mod.
  3. Sep 5, 2010 at 5:49 PM
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    Nice writeup!
  4. Sep 5, 2010 at 6:27 PM
    1TUFFTRD
    1TUFFTRD WTF
    out and about building powerlines
    06 AC with a skewp
    06 With a Skewp.
    i still gotta do this!
  5. Sep 5, 2010 at 6:40 PM
    David K
    It is easy... otherwise I may have been still doing it!
    BajaBirder likes this.
  6. Sep 5, 2010 at 7:03 PM
    RideFast
    RideFast on the flats.
    Jesse
    Albuquerque New Mexico
    Tacoma
    great directions and pics! this thread should be on the cheap and free mods page!!!
    BajaBirder and SandyTaco4x4 like this.
  7. Sep 5, 2010 at 7:21 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    good job on the write up.
    ramonortiz55 likes this.
  8. Sep 5, 2010 at 7:28 PM
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    PlatyTaco likes this.
  9. Sep 5, 2010 at 7:35 PM
    Rich Beauregard
    Rich Beauregard Well-Known Member
    Rich
    New London, CT
    17 Taco 4x4 SR5 Access Cab White
    Thank you for the detailed photos. Looks great!
    TRDSport10 likes this.
  10. Sep 5, 2010 at 7:58 PM
    OH-MAN
    OH-MAN Well-Known Member
    Sunny Az.
    10 4X4 O.R. White
    TRD skid painted black,
    I re used the stock breather fitting with a female IPS to barb fitting to connect to the hose.
    Is the other breather fitting better?
    Mine is hiding in the fuel filler cubbie.
    Taco351 likes this.
  11. Sep 5, 2010 at 11:37 PM
    David K
    Thanks for the replies everyone... mine is a little different in that I routed the breather extention tube into the truck bed's side storage compartment instead of the gasoline fill bay. I would be honored if this thread was added to the other mods list!
    The new breather fits perfectly inside the 3/8" I.D. tube. Unlike the original breather, the new one does NOT have a check valve (a one way valve that lets gear fumes out, but nothing in)... That was reported already, so I was not surprised. I guess my diff. was contaminated by muddy water getting in through the axle seals...?
    Having a two-way breather would act as a vacuum breaker and allow clean air to return to the differential during a negative pressure occurance (like dipping a hot differential pumpkin into a cold stream)!
    TRDSport10 and BajaBirder like this.
  12. Sep 6, 2010 at 7:23 AM
    RideFast
    Jesse
    Tacoma
    oh yea I knew it was there I just really liked reading this writeup and I think this one has very descriptive pics and written directions. No offense to the authors of 24 and 25.
  13. Sep 6, 2010 at 7:53 AM
    senna
    senna Well-Known Member
    San Jose CA.
    09 DBL CAB TRD-OR OME shocks 885 and AAL
    Nice write up, I did my breather recently as well. I see you found a factory fitting (union) that is the same size as the breathers hose end, I went through a few and could not find the right one. all though you used 3/8 hose and I measured it at 5/16.
    Also you have an Off road as do I, there is also a breather for the E-locker motor, if you look under the truck you see a small tube, you can follow this to the cross member above the diff. If you look at the front breathers mounted in the engine compartment there are two. one for the diff and one for the actuator on the diff, the small breather is what I used for the rear e-locker.
    edit: in photo #6 you can see the e-locker breather going into the cross member, upper right of the frame.
    Here is a photo of where I mounted mine, they are in the small cubby in the front of the bed, drivers side.
    Uploaded with ImageShack.us
  14. Sep 6, 2010 at 11:45 AM
    David K
    Thanks Senna... Can you explain why an electric motor (E-locker) needs a breather? I wish I knew that and could run it too, or is it located high enough?...
  15. Sep 6, 2010 at 12:08 PM
    senna
    San Jose CA.
    I don't know why, but decided to err on the side of caution and have it at least as high as the diff breather, plus then you know what level both are at.
    On a side note I changed the diff fluid on my 03 tahoe 2wd this weekend and it had a remote breather located up by the fuel door, found that a funny coincidence :eek:.
  16. Sep 6, 2010 at 7:06 PM
    RideFast
    Jesse
    Tacoma
    so now I am wondering if my 1st gen has a breather on my e-diff locker
  17. Sep 6, 2010 at 7:08 PM
    trd7
    trd7 4wd tacoma
    Tyler
    Columbia, SC
    95.5 Tacoma 4x4 4cyl auto
    AEM air intake
    I like the yellow hose ;)
  18. Sep 6, 2010 at 8:12 PM
    David K
    I am still waiting to hear from you smart Taco mechanics why a breather for an electric motor (e-locker)?
  19. Sep 6, 2010 at 8:15 PM
    TRICOMA
    TRICOMA Tacoma with the TRI package
    Tri
    Carlsbad, CA
    2010 Tacoma DC SB 4x4 TRD Off Road
    King Off-Road Shock Coilover 2.5 with Resi in the front. King Off-Road Shocks 2.5 with Resi's for the rears, Rear Spring TSB, KMC XD Enduros 16x8, Black Vinyl Fenders, Bed compartment locks, Cobra 19 DX IV with Lil Wil mag mount antenna, CoverKing Seat covers front and rear, Built Right UCAs, Aluminess Expedition Bumper, GY Wrangler MT/R with Kevlar 265/75-16, Custom hybrid style rock sliders.
    Nice. I need to do this.
  20. Sep 7, 2010 at 10:19 PM
    David K
    It's so easy, a caveman can do it!
    SR-71A likes this.
