My Doors Make So Much Noise!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by LJrubi, Jan 15, 2020.
  1. Jan 15, 2020 at 7:21 AM
    LJrubi
    LJrubi [OP] Well-Known Member
    Dan
    North West NJ
    2015 MGM TRD Sport DCSB
    2015 DCSB and the 2 front doors make so much f'n noise it drives me insane. I've search the forum and tried everything suggested. Lubed the door seals with silglyde, taped up the painted areas, etc etc, and there is still this super annoying sticking/unsticking sound while driving down the road. Anyone else have it and successfully fix it?
  2. Jan 15, 2020 at 9:51 AM
    BlkDakDave
    BlkDakDave Well-Known Member
    David
    CC TX
    07 AC PreRunner TRD/Off Road
    Coming from a Dakota (quad cab 4x4) one of the first things I noticed with my Tacoma was the overall noise in the cabin when driving. Since my youngest son got the Dakota, I was able to compare the insulation or deadening material in the doors, floors and roof. A simple tap on the doors and roof told me right away that the Tacoma sounded like a tin can while the sound from the Dakota was more like a thud. This prompted me to totally gut the cab of the Tacoma and install a two part sound deading anywhere and everywhere I could. The result was a much quieter ride (along with screen spline for the windshield) and going from a tin can sound to a deep thud.
    Not sure if my reply answers the question to your dilemma, but it did mine. Have you looked at the door hinges and latches to see if they're snugged up?
  3. Jan 15, 2020 at 2:18 PM
    whipper
    whipper Well-Known Member
    2007 PreRunner
    My 07 makes a sound as you described. I use Aerospace 303 on all the weather striping and the noise does go away for a while. Then when it starts making noise again I just reapply.
    mikalcarbine likes this.
  4. Jan 15, 2020 at 2:32 PM
    BlkDakDave
    David
    CC TX
    303 is good stuff. I use it on my truck and trailer tires.
  5. Jan 15, 2020 at 2:41 PM
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2023 White TRD Off-Road doublecab
    2nd Gens use thinner sheet metal than my 1st Gen, I've noticed. Rattles and vibrate more.
  6. Jan 15, 2020 at 3:43 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Yep, I find if silicone the rubber seals, it’s much better
  7. Jan 15, 2020 at 3:43 PM
    EdinCincinnati
    EdinCincinnati Well-Known Member
    Ed
    Ohio
    2014 4x4 TRD OR
  8. Jan 15, 2020 at 3:48 PM
    gotoman1969
    Did you spray that on the seals or directly on the body of the truck?
  9. Jan 15, 2020 at 3:50 PM
    EdinCincinnati
    Ed
    Ohio
    2014 4x4 TRD OR
    both. All around the door and the matching face of the body.
  10. Jan 15, 2020 at 3:52 PM
    gotoman1969
    :thumbsup: I’ll give that a try too.
  11. Jan 16, 2020 at 9:27 AM
    LJrubi
    Dan
    North West NJ
    Thanks for the suggestions. I'll give that stuff a try too.
    EdinCincinnati likes this.
  12. Jan 16, 2020 at 9:32 AM
    EdinCincinnati
    Ed
    Ohio
    2014 4x4 TRD OR
    I think the real secret is keeping the dirt and grime cleaned off the door and body.
    but the Teflon spray definitely helps with that also.
  13. Jan 16, 2020 at 9:45 AM
    LJrubi
    Dan
    North West NJ
    I keep my truck pretty clean being a detailing enthusiast. The only thing that can be making noise is all that damn rubber around the doors. I just ordered that stuff so I'll spray the shit out of it this weekend. I really hope it helps b/c I love the truck but the noises make me mental.
  14. Jan 16, 2020 at 9:45 AM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    I have always used just a wet rag to clean the seals when I wash the vehicle. It’s amazing all the dirt and grit that comes off them. Then apply 303 real good. So far no problems.
  15. Jan 21, 2020 at 4:28 PM
    EdinCincinnati
    Ed
    Ohio
    2014 4x4 TRD OR
    Any improvement?
  16. Jan 21, 2020 at 6:11 PM
    LJrubi
    Dan
    North West NJ
    Got the spray but it's been cold as shit here so I haven't gotten to it yet. I really hope it works. Seems like the fall when it starts getting cold is when all the noise starts.
  17. Jan 28, 2020 at 11:25 AM
    LJrubi
    Dan
    North West NJ
    Just coated all the jams and weather stripping on the driver's side. Looks like someone ejaculated all over my door but if it shuts it up, I'm ok with that. Also snugged up the bolts holding the door hinges on. Will report back after a little drive time.
  18. Jan 28, 2020 at 4:39 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    I think this is the answer you seek. I had the same problem last summer and tried silicone, armorall, etc. The wet stuff just makes them stick and pop more. Once they dried back out and stopped trying to stick to the body of the vehicle, the seal popping sound got better. I think the dry Teflon spray is the ticket. It'll let them move relative to the body of the truck when it flexes and you won't get that 'stick and release' pop.
    Yes, something dry and slippery.
  19. Jan 28, 2020 at 7:04 PM
    LJrubi
    Dan
    North West NJ
    I'm happy to report much quieter driving conditions! Hallelujah! Thank you Ed in Cincinnati...thank you thank you thank you. I love my truck again.
    907rx7 and EdinCincinnati like this.
  20. Jan 29, 2020 at 3:20 AM
    EdinCincinnati
    Ed
    Ohio
    2014 4x4 TRD OR
    Glad to help!!
