my first attempt at rust repair
Discussion in '1st Gen. Tacomas (1995-2004)' started by megalodon, Dec 3, 2019.
  1. Jan 4, 2020 at 6:45 AM
    megalodon
    megalodon [OP] Well-Known Member
    FingerLakes Ny
    2003 v6 Ex.Cab
    Right, I was reading about Noxudol being a good option (from not washing off standpoint) it is waxed based and self healing from my understanding what Toyota spec'd out for the frame recall treatments (although, prep is of course key to anything and it won't fix stuff that might already be damaged.)
    just found this thread which might be worth checking out (reading through it now myself)
    https://www.tacomaworld.com/threads/rust-prevention-treatment-consolidation-thread.355928/
    I'm renting a couple bays at a mechanic with a two post lift in one. If I were to be trying this at my house I'd be doing this in the driveway which I think would be the opposite. :)
    GQ7227[QUOTED] likes this.
  2. Jan 4, 2020 at 9:11 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    this pic here of yours is probably the area i need to look at and what is lurking behind my fender liners way up and under the arch, i did not have any clue how that is all put together
    going to have to get a mirror & light and and try to get a glance up under in there when the weather gets warmer
    maybe it has not progressed very far but IDK yet
  3. Jan 4, 2020 at 9:17 AM
    Clearwater Bill
    Billy
    Largo Florida
    While you have the bed off it's the right time to give that frame proper protection. And it will be much easier for you to do too, access wise.
    Slather it up with Fluid Film or the like.
    Good job in taking on the metal work. I'd have just looked for a healthy bed to swap on. :anonymous:
  4. Jan 4, 2020 at 9:27 AM
    megalodon
    FingerLakes Ny
    2003 v6 Ex.Cab
    Yup... rust removal and frame prep with fluid film/etc is the plan while things are apart.
    I looked briefly for a decent bed, but tough to find one in good shape up here. I decided it was a good opportunity to learn a new skill buy a couple new tools and if needed I can always look/buy a new(ish) bed later on.
  5. Jan 4, 2020 at 6:25 PM
    ELMO67
    ELMO67 Well-Known Member
    Ct.
    04 Tacoma 4wd reg. cab
  6. Jan 4, 2020 at 9:23 PM
    SkunkMan17
    SkunkMan17 Jerry-rigging everything
    Owen
    Montana
    1997 Tacoma RC 4x4
    Tasteful modifications :)
    For y’all on here welding up your beds and stuff, practice your beads before you go welding on your bed and stuff! Better beads = less body filler = less money spent.
  7. Jan 5, 2020 at 12:25 PM
    megalodon
    FingerLakes Ny
    2003 v6 Ex.Cab
    Thanks. Good tip for those who haven't embarked down this path.
    most of what I'm welding will be covered by fender flares so as you say, while my welds might have be better if I started on some practice stuff, learning to butt weld at different angles and various positions may or may not have been as easy to replicate. . . but I don't do this for a living. For me sometimes to make progress I have to dive right in.
    Anyway sanded down the rusty spots and welded in some more patches on the other side last night.
    IMG_20200104_151443_1.jpg IMG_20200104_151709.jpg IMG_20200104_151725.jpg IMG_20200104_160329.jpg IMG_20200104_160313.jpg IMG_20200104_171051.jpg IMG_20200104_181139.jpgIMG_20200104_181128.jpg IMG_20200104_183604.jpg
    cruiserguy and CrustyTaco like this.
  8. Jan 5, 2020 at 2:06 PM
    SkunkMan17
    Owen
    Montana
    1997 Tacoma RC 4x4
    Looks sorta like my repair on my fender but I used bondo because I’m out on a welder right now, looks decent thou for a first time bondo job thou.
    I don’t have any pictures of the product at the end but I’ll tell you you can hardly notice, I don’t know if I’d even be able to tell if I clearcoated it!
    Good luck thou! Keep in mind the better the wire you buy sometimes the better the welds come out.
    Here’s what my go to on really thin square tubing/round tubing was when I was doing some side steps for my friend.
    275 in/min wire speed
    18.0 Volts
    10 Ga Thickness
    C25
    Hotter the wire speed you go the more prone the wire is to penetrate the metal your welding on and leave you with a hole in your panel, but with a too slow wire speed you can also end up with welds that don’t fully penetrate your panel or metal. I’d try out lower then 275 maybe minimum 230 on the wire speed. For the volts try to travel within 17-18.5. This is just what I used to weld at on my Lincoln machine so I guess try it and see if it works for ya
    Babybluetaco likes this.
  9. Jan 6, 2020 at 6:13 AM
    megalodon
    FingerLakes Ny
    2003 v6 Ex.Cab
    Thanks for the settings and tips, I'll check to see what I'm using.
    NYS salts the heck out of our roads (one of the reasons vehicles here rust out so bad) looks like your repair turned out decent, how is it holding up against winter in Montana?
    GQ7227 likes this.
  10. Jan 6, 2020 at 7:13 AM
    Duty Bootie
    Duty Bootie Well-Known Member
    Richard
    Vancouver Island
    96 Taco Bush Truck - Now in Restoration
    Once completed you need to treat with an oil/waxed based coating on the inside and underneath, and top it up every year. I use Pro-Form (amber) wax based permanent rust proofing. Spray it F'n everywhere I do. inside doors and rockers, fneders U name it. Bought a fluid film spray gun kit with multiple extensions. Works well if ProForm wax is heated or on a baking hot day.
    cruiserguy and GQ7227 like this.
  11. Jan 6, 2020 at 7:39 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    is the Pro-Form a different type of product than something like this?
    https://www.eastwood.com/ew-brush-on-seam-sealer-quart.html
  12. Jan 7, 2020 at 12:00 AM
    TRVLR500
    TRVLR500 Well-Known Member
    Wyoming
    Tacoma SR5 4X4 2.7 4CYL
    I did automotive restorations decades ago on collectors vehicles and not much has changed to this day as far as paint, sealers, primers and everything else. If you're doing welding of patch pnls with this microscopically thin sheet metal they are using on these newer vehicle you need a TIG welder or, if you're using a MIG welder the AMPS need to be turned way down. That reduces the blow through holes when you're welding this newer paper thin sheet metal. Kudos to you, the OP. With tips from your bodywork friend you're doing everything right. Patch PNLS were the way to go for that rust.
    I might suggest a product that works wonders. It's called DP40. An epoxy, catalyzed sealer that you can coat with anything from Bondo to a metal body filler. It won't even chip if hit with a hammer once it cures. It's great for rust because it has Zinc Chromate in it. You can spray it or even brush it on. Once done doing the welding get all that black crap off with Dremel tools or whatever then apply the DP-40 which is an olive green. They make other colors of DP-40 but the green is the best. You can topcoat it with anything and it's works wonders for rust. Bondo, liquid metal paint anything will stick to it if you follow the directions..
    DP-40 is made by PPG and it works so well that it has probably been illegalized in many states. If they sell it where you live, use it. If you're going to spray it on then use a very good respirator as it is extremely toxic and will coat you're lungs causing you possible months of health problems. Use it right with the proper equipment and you will be fine. You can apply it with a brush if you want though. Just don't reduce it too much or it will run onto the floor.
    The DP-40 was developed for aircraft. 747's and stuff like that. It will adhere to any topcoat for up to 7 days as long as the surface isn't contaminated with grease, oil, WD40 , wax or anything else. After 7 days you need to "abrade" it with a red Scotchbrite pad. It will stop rust in it's tracks so any "holes" you have in you're welding job will not start rusting as long as they are clean from welding slag etc. Apply the DP over clean, bare metal as well as you can. Those little holes in the welding job might be a problem. That's why I mentioned the Dremel too.
    I had a '73 Cadillac Coupe DeVille which was my only car up until 5 years ago when I got the Taco. I degreased the engine compartment, let it dry and then coated everything, including the very badly rusted battery box with black DP and when I got rid of the Caddy 18 years later there was no rust coming through on that battery box. I never even painted it which you should do. The Caddy was in the salt states throughout that 18 years. I don't know what primer you have used so far but once it's good and dry you can apply DP over it if it's dry through and "abraded with 320 grit sandpaper or a red Scothbrite pad thuroghly. Even if it's a lacquer primer. Which I certainly hope you haven't used on a rust job like this. It takes a lacquer around 6+ months to completely dry through at 70 degrees with low humidity.
    When you're done, slather everything with Fluid Film and you be good to go for quite some time.
    2002Tacoma4x4 likes this.
  13. Jan 7, 2020 at 12:06 AM
    TRVLR500
    Wyoming
    Seam Sealer is for sealing around windows. Welds where you have welded on a new panel. etc. It's not for any type of rust repair. Only for rust prevention for filling gaps. Around an air conditioner on an RV etc., etc. It's used to stop the ingress of water from rain, car washes etc. so water doesn't start causing rust problems between body panels or get past windows and cause leaks. I might add that no one makes better seam sealers than 3M.
  14. Jan 9, 2020 at 7:56 AM
    megalodon
    FingerLakes Ny
    2003 v6 Ex.Cab
    Thanks for the tips! I'll check into seeing what the availability of DP40 might be in NYS, sounds pretty powerful and a bit dangerous just the way I like it :thumbsup:
  15. Jan 9, 2020 at 6:14 PM
    #35
    SkunkMan17
    Owen
    Montana
    1997 Tacoma RC 4x4
    Holding up well except for the fact that I sanded too much in a small spot and the bondo split but other then that looks great haha
    GQ7227 likes this.
  16. Jan 10, 2020 at 8:54 PM
    #36
    TRVLR500
    Wyoming
    DP is good stuff. Real good. Don't stand around breathing the fumes from it either. I'm sure it's still the same. It requires an "induction period" of 30 minutes before you spray it. Mix it and get away from it. In NY? I'd be shocked if they still sold it. If they do though you'll be good to go. Make sure you use a respirator when you spray it. Survivar used to make a respirator with filters for "VOC's" I'm sure they still do. I think 3M bought Survivar. VC stands for "Volatile Organic Chemicals" which is what you are breathing standing over an open can of paint. If you can get a Survivor respirator with the proper filters use it when you are mixing as well. Are you going to get sick or do any damage to yourself mixing DP or any other paint a few times as a hobby and breathing the vapors? No. But it's a good idea to wear a respirator. Not using a respirator if you spray it? Yeah, that could cause problems just once with DP. Those that are painting for a living these days use a fresh air system which you don't need for hobby work.
  17. Jan 30, 2020 at 9:14 AM
    #37
    Ebro09
    Ebro09 Active Member
    Eric
    Dutchess County, NY
    2020 TRDOR
    Looks great, amazing work!
  18. Nov 19, 2021 at 6:16 AM
    #38
    megalodon
    FingerLakes Ny
    2003 v6 Ex.Cab
    Since my last post I’ve done a ton but haven’t had a chance to upload the results … (life gets in the way)
    However, short version:
    - I completed the bed repair
    o Forgot to drill the flare holes, color matched with the spray can that was supposed to match the paint color
    o Paint color I got is a color mixed by napa – martin semour Crossfire brand, slightly lighter than the OEM (ah well) / doesn’t match where
    - My gas cap cover hinge snapped I’ve replaced with a used one from ebay and … as noted above, the paint color doesn’t match and I haven’t painted it yet.
    I'm gonna need a new sticker as I also put got the cap wrapped up
    I'm going to need a new sticker
    #38
  19. Nov 19, 2021 at 6:26 AM
    #39
    w8tdstrgecube
    w8tdstrgecube Well-Known Member
    Brian
    Wisconsin
    2004 Gold Regular Cab 2.7L Manual 4x4
    Well done, OP...hats off to you for having the guts to try this. Welding is something I won't touch, and also something that I wish I had experience with.
    Looking forward to seeing the results of your work.
    megalodon[QUOTED][OP] likes this.
  20. Nov 19, 2021 at 6:27 AM
    #40
    megalodon
    FingerLakes Ny
    2003 v6 Ex.Cab
    Cap:
    - Well… 2 years later I just… got the multi-color Cap painted (Same paint as what I used on the bed)
    o Primed with an epoxy primer, stuff is pretty sweet, coated the underside of my bed with it.
    - I added some angled L-Track (I ordered it from here https://www.cargoequipmentcorp.com/) to it because I liked the ‘idea’ of having multiple connection point options and gives me the ability to add a variety of things to the roof (and interior)
    - I added a 3rd brake light to it and ran a wire through the bed.
    o Took some pictures to show how I ran it (was actually pretty tough to find anyone that has done that…
    - The Harness:
    o I don’t really like cutting into factory wiring harness if possible to avoid so I had an old trailer harness that bombed out so I cut the old tail light connection point off and piggybacked it up. I elected to run a 4 - wire trailer quick connect so I can run a dedicated 12v for a cap light (which I’ve not installed yet)
    o The harness is wrapped in wire wrap and I added a terminal block to give me easy expansion later on for that 12 volt direct connection
    - Got it finished up last night. It’s too soon to tell if I’m going to really keep it on all the time or not. But for the winter its going stay and help keep the stuff I haul around out of the weather.
    BuelltonTacoma and CrustyTaco like this.
