My Front end clunk found, Finally.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dwrat, Oct 17, 2016.
  1. Oct 17, 2016 at 10:23 PM
    Dwrat
    Dwrat [OP] Well-Known Member
    Dan
    Phoenix
    2014 TRD 4X4
    I've had a intermittent front end clunk for a while now, mostly going over speed bumps aggressively. Only have 28K miles on the clock so I feel all rubber should still be good.
    I did put a lift / spacer block on top of the strut assembly a while back.
    Anyways, long story short, it was my lower shock/strut bolt was to tight.
    I backed it off a bit and no more clunk.
    I hope this can help someone else out..
    This was a tough one to find for me.
    Dan
  2. Oct 18, 2016 at 5:51 AM
    ChiefManyWrenches
    ChiefManyWrenches Well-Known Member
    Florida
    '11 Silver DCSB TRD Off Road 4WD
    How would that being too tight cause a clunk in the front end?
  3. Oct 18, 2016 at 5:53 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Beat me to it
  4. Oct 18, 2016 at 5:55 AM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    How did you find it to be that?
  5. Oct 18, 2016 at 5:57 AM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    So many questions!
  6. Oct 18, 2016 at 6:26 AM
    Dwrat
    Dan
    Phoenix
    2014 TRD 4X4
    I was able to pin the clink down to the strut by holding my hand on it while it was jacked up and I could clearly feel the clunk, clunk, clunk just before the tires came off the ground..
    I pulled the strut and removed the spring and cleaned / greased every contact point.
    Double checked the action of just the bare shock and it was still like new.
    Reinstalled everything and the f###ing clunk was still there.
    The final thing to do was to back off on the lower large shock nut and the clunk was finally gone. I used a impact to install it in the past.
    I don't know why, but for some reason when the lower bolt/nut was over torqued is caused a bind in the joint.
    I just wonder if this could be what others are fighting with after a lift.
    Crom likes this.
  7. Oct 18, 2016 at 6:34 AM
    ChiefManyWrenches
    Florida
    Interesting but I would keep an eye on that nut to make sure that it doesn't back off too much on you. I would go get a tq. wrench to be sure and maybe some loctite.
  8. Oct 18, 2016 at 6:56 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    And I believe it's torqued to 34
  9. Oct 18, 2016 at 6:57 AM
    Dwrat
    Dan
    Phoenix
    2014 TRD 4X4
    Thank you,
    You're 100% correct.
    I already locked it down and need to put a tq on it, i'm guessing i'm around 30 or so right now.
    No more 80-100 from my impact gun.
  10. Oct 24, 2016 at 1:48 PM
    Caddmannq
    Caddmannq MotoNerd
    California
    2012 PreRunner TRD Sport DC LB
    Undercover toneau
    Unless I am mistaken, that bolt should be tight enough that the serrated spacer bites into the two steel ears and never slips.
    All motion should be from flexure of the rubber.
    This is a constant characteristic of the "silent block" or torsilastic bushing type suspension. The metal is not supposed to slip against metal when things move. There are no greased pivots like my '47 Plymouth. It's just flexing rubber.
    Those shocks must be tightened with the weight on the front end, NOT up on the jack.
    That's probably why you developed a clunk.
    Too much pressure on the rubber caused the sleeve to slip against the ears, ruining the bite of the serrations.
    Thereafter it will slip & clunk whenever you approach full suspension pressure/travel.
  11. Oct 24, 2016 at 3:10 PM
    Dwrat
    Dan
    Phoenix
    2014 TRD 4X4
    Great info here, thanks.
    BTW, I did tighten it up while still in the air which now makes sense to me.
    Thank you...
    Crom likes this.
  12. Oct 24, 2016 at 3:28 PM
    TacomaMona
    TacomaMona Well-Known Member
    Good thing it was a simple fix and you didnt have to replace anything!
  13. Oct 24, 2016 at 3:33 PM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Agree. Torque most suspension fasteners when truck is on it's own weight. Same goes for UCA bolts, LCA bolts, shock bolts, Leaf springs etc. Only exception I can think of is when poly bushings are used.
