My FX-R Retro-fit
Discussion in 'Lighting' started by G-Sak, Jan 17, 2010.
  1. Jan 27, 2010 at 8:19 AM
    s2kvtak
    s2kvtak Well-Known Member
    Lee
    Tulsa, OK
    2004 Tacoma 4x4 SR5
    Grillecraft grill w/ TRD badge, Bilstein 5100s on all 4 corners set at 2.5" and Toytec AAL in the rear. 285/75-17 Interco TRXUS M/T
    thank you and yes that car was also arguably the best car i have owned however being that im only 21 i was putting way too much money into it and decided to get something a little more practical for the time....i really miss that car!!
  2. Jan 27, 2010 at 9:21 AM
    raskal311
    raskal311 Well-Known Member
    S. Cal
    5100 set to max, pending LSD and TRD CAI
    Did you have to trim the shrouds to fit? If so was it a lot of trimming? What did you use to trim them?
  3. Jan 27, 2010 at 2:00 PM
    G-Sak
    G-Sak [OP] Well-Known Member
    PNW
    2005 TRD Offroad SR5 DC 6 speed
    FX-R Projector Retrofit with Apollo Shrouds, Digital HID 55 watt ballasts, D2S Philips 85122+ bulbs in the Winter and Digital HID 55w 5k bulbs in the summer, Bakflip G2, Pop N Lock, Tint, Grillcraft with PIAAs behind it, ScanguageII and a few audio/video upgrades.
    I did have to trim the Apollo shrouds to get them to fit correctly, but not very much. I used my dremel tool with an almost cone shaped grinding attachment (not sure what it's called) and it worked great. The only parts that needed trimming were on the inside of the shroud on the bottom for the hi beam solenoid to clear and then the right and left edges where the projector contacted the shroud. I also used those three contact points to mount the shroud with hi-temp Permatex RTV gasket sealant that Yosh2000 suggested in his write up.
  4. Jan 27, 2010 at 2:03 PM
    raskal311
    S. Cal
    Ohh looks like I know what my next project is.
  5. Jan 31, 2010 at 2:38 PM
    Rhino8541
    Rhino8541 I like ze best!
    WA
    2017 QS DCSB OR
    Nice work, looks like you did a very nice, clean install. Did you use the dremel to cut the reflector bowls, or something else?
  6. Jan 31, 2010 at 2:41 PM
    G-Sak
    PNW
    I ended up using my dremel to cut the reflector bowls. It turned out nice and clean with the projectors fitting snug as well.
  7. Jan 31, 2010 at 5:16 PM
    Rhino8541
    WA
    2017 QS DCSB OR
    Looks like you did a very good job at doing so. All of your cuts look nice and straight. You also did a very clean job putting the epoxy on. Mine is a little messier, but it all works the same! I need to take pictures of my retro.
  8. Jan 31, 2010 at 5:26 PM
    G-Sak
    PNW
    Thanks for the compliments! I saw in a thread that you stripped one of the black pieces for the reflector adjustment. Did you get that fixed yet? Funny how the little things go wrong and mess everything up. I hate when that happens.:mad: When I finished my retro and was installing the lights back on the truck I misplaced some of the bolts and spent about an hour trying to find them. I guess I was a little too anxious, haha. That was frustrating since all I wanted to do was drive around and enjoy them!
    You should takes pics as well! We'll be waiting........:)
  9. Jan 31, 2010 at 6:58 PM
    Rhino8541
    WA
    2017 QS DCSB OR
    The lights work, but if I push too hard on the back of the light, the adjustment knob allows it to shift up and down, so once I get one I can get them fixed. Should be an easy fix. They are in now, and I love them!
  10. Feb 2, 2010 at 1:06 PM
    AzogSS
    AzogSS Well-Known Member
    Andy
    Soda City, SC
    2008 Tacoma / 2011 FJC
    I am planning a FX R retro soon. One question for those that have already done it. Does the weight of the projectors move the bowls and knock the light out of alignment when going over bumps or off road? Thanks in advance.
  11. Feb 2, 2010 at 1:53 PM
    1BlkT
    1BlkT Mod'n on a Budget
    Ty
    90603
    2006 Black Sport Double Cab
    Allied 4'' Spindles, Sway A Way 2.5 Coilovers, Donahoe Remote Reservoir Shocks w/ Deaver 11Pack Leafs, Goodyear Duratrac 285's, Pro Comp Series 8128, Recessed Grill w/Hella 500's behind, Tint, Black TRD Skid Plate, Debadged, Tailgate Hose Clamp, Weathertech Mats, Aero Turbine 2525XL Exhaust, Volant Intake, RETRO'D Headlights by Yosh2000
    Well I haven't gone offroading per say but I have hit some pretty good bumps/potholes and other crap lately and mine are still aligned just like the day they were installed.
  12. Feb 2, 2010 at 2:02 PM
    G-Sak
    PNW
    I haven't had the chance to take the truck off road since I installed my retrofit, but I have driven roughly 800 miles with them which included mountain passes as well as rough city streets. They have held together well and have not been knocked out of alignment yet even with some of the big bumps.
  13. Feb 2, 2010 at 3:39 PM
    IamTacO
    IamTacO red balls got me!
    adam
    QC az
    01 Prerunner SR5 TRD-Offroad
    4x2 Prerunner. Hankook Dynapro ATM rf10 265-65-16, e-locker FTW! Morimoto d2s bi-xenon HID projectors, Philips 85122+ 4300K, Cobra 75 w/ 3' firefly, Kenwood KDC-MP342U w/ SIRIUS, Line-x bed liner, 4' coretrax(black)
    nice retro! i'm going to be retro'ing a set of g37 bi-xenons with a fx-r clear lense soon. hopefully it goes as nice as yours did.
  14. Feb 2, 2010 at 3:49 PM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    nice what kind of sealant did you use on the back of the reflectors? (the gray sealant in the last photo)
  15. Feb 2, 2010 at 3:51 PM
    #35
    G-Sak
    PNW
    That is just regular JB Weld. Seems to be working great so far.
  16. Feb 2, 2010 at 3:53 PM
    #36
    blackhawke88
    SGV, CA
    07 TRD Offroad
    ^ oh sick, haha. One thing that has puzzled me is that if the projectors are jb welded on, how do you adjust them? or do the adjustment knobs adjust the entire reflector that in turn, adjusts the projector that is attached to it?
  17. Feb 2, 2010 at 4:01 PM
    #37
    G-Sak
    PNW
    Yes, the stock adjustment knobs aim the projectors since they are bolted/jb welded to the reflector.
  18. Feb 2, 2010 at 4:04 PM
    #38
    VissionMx
    VissionMx Socialist States of America
    Chase
    Canyon Lake, CA
    06 PreRunner Sport Dbl Cab
    DTRL,Blinker DTRL, fogs anytiime, relocated and blacked badges, Decepticon emblem(by MetalMiller)
  19. Feb 2, 2010 at 4:13 PM
    #39
    G-Sak
    PNW
    I had them on my old set up. They were built into the shroud around my projector lenses that I got from Luminous Solutions. For the majority of the time I had that set up I didn't have the CCFLs wired. About the time I started compiling all the parts to do my FX-R retro I wired the CCFLs into my parking lights. It actually was kind of cool after I thought they would be to ricer or bmw looking for so long. They were white in color. Also, they did not work well when it was cold out. Below about 35 degrees they were never all that bright.
  20. Feb 4, 2010 at 3:44 AM
    #40
    AzogSS
    Andy
    Soda City, SC
    What did you use to attach the shroud to the projector? Also did bolts to mount the projector to the bowl come with the kit or did you just pick some up at a hardware store?
