My kid lost interest so I'll build it for the Lil Mrs. build
Discussion in '4Runner Builds' started by El Taco Diablo, Feb 17, 2020.
  1. Feb 26, 2025 at 8:55 AM
    #181
    El Taco Diablo
    El Taco Diablo [OP] Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    I'm not sure how much wider 1st Gen long travel width is over a 3rd gen axle width. But I know I would need to be wider.
    If I did a 3rd gen axle I could probably make up the width in the full float set up. But If I was doing that kind of fabrication, it's better to just do a Ruff Stuff axle.
    The Ruff Stuff axle (even with a Harrop) would also, probably be a pretty close price tag to an e-locked 3rd gen axle. And wiring a Harrop would definately be easier than trying to disipher Toyota's non-sense with the locker wiring.
    I'll just build another one of these.
    essjay and TomHGZ[QUOTED] like this.
  2. Feb 26, 2025 at 12:00 PM
    #182
    TomHGZ
    TomHGZ Well-Known Member
    2014 TRD Frankensport 4x4 AC AT
    Partial list: Vagabond Drifter 3rd Gen OR rear axle 4.30 gears Bilstein 6112s and Tundra 5160s.
    Looks like a complete third gen axle assembly with elocker is going for about $2800 delivered, on eBay. That still leaves you with a considerable amount of work to do. From my understanding though, hooking up the elocker is not nearly as complicated for the third gens as it was for the first and second gens. It just needs power and a switch on a relay. I ordered a wiring harness to make it work on my 2nd gen for $100, but that plugged into my 4wd module for a power source, and you don’t need to do that.
  3. Feb 26, 2025 at 4:47 PM
    #183
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Ordered a bunch of the water pump / timing belt stuff to pick up on Friday.
    I'll update the spread sheet tomorrow.
    Figure it's a good time to get everything to square one. Also, I'm planning on pulling the motor for other purposes. The timing belt should be way easier while the motor is out. I've done it a half a dozen times with the engine in the engine bay. This time should be way easier.
  4. Feb 26, 2025 at 6:27 PM
    #184
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Got a line on some IFS hubs and a 3rd member.
    Wheelin and dealing, shakin and bacon. lol
    kent50 likes this.
  5. Feb 27, 2025 at 8:42 PM
    #185
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
  6. Feb 28, 2025 at 9:17 AM
    #186
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Ricardo13x, Kwikvette and realsystem like this.
  7. Feb 28, 2025 at 9:42 AM
    #187
    10YSON
    10YSON Well-Known Member
    GREG
    TACOMA & 4RUNNER
    TOTAL CHAOS / KING / DEAVER / PRP / DIRTKING
    essjay likes this.
  8. Feb 28, 2025 at 9:49 AM
    #188
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Nice! Good looking out. I hadn't seen that company.
    Just looking at that... holy shit, this is going to be an f'ing pain in the ass. :rofl:
    essjay and 10YSON like this.
  9. Feb 28, 2025 at 10:31 AM
    #189
    realsystem
    realsystem Well-Known Member
    Stanislav
    SF Bay Area, CA
    2017 MGM Tacoma TRD OR DCSB | 2021 Cement Tundra SR5
    LT,37s,5.29,Kings,Camper,Deavers,snorkel,winch,CVCtune
    3D modeling can simplify the process. I would consider make it repeatable.
  10. Feb 28, 2025 at 10:34 AM
    #190
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    So, if I'm pulling the motor what are some things I need to think of doing while it's out?
    I'll doing the timing belt, water pump, valve covers, and accessories (P/S pump, Alt, A/C Idler pully) whiles out. That can all be done with it in, but it's just easier.
    Clean up the entire motor, replace rear main seal while it's split from the trans.
    Engine cage, I think I actually want to tack that together with the motor in and the full weld and gusset it after the motor is pulled.
    New motor mount frame perches.
    I think I'll do the coil bucket reinforcement and Total Chaos UCA double shear kit, so I can get the back.
    I also think I'll do the TC Long Travel Dual shock hoops with the motor out as well.
    The plan, right now, is to see if I can tie the engine cage in to the double shock hoops, or to find out if I need to tie in to the coil bucket it's self.
    The only other thing I can think of, while the engine is out, is headers. Not sure I want to spend that money at this point.
    Am I forgetting something?
  11. Feb 28, 2025 at 10:34 AM
    #191
    realsystem
    Stanislav
    SF Bay Area, CA
    When I worked on the camper I did a full 3D model for every panel and frame piece. Design took about a week, three or four versions, but it paid me back.
  12. Feb 28, 2025 at 10:37 AM
    #192
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    That would be a good idea. Especially if I was going to do a cage for another 3rd Gen 4 Runner. But, being honest, I'll likely never build another cage again.
    I wonder if I should reach out to tedesigns to see if there is a way for me to scan a 3rd gen 4 runner for them. If they'd even be interested.
  13. Feb 28, 2025 at 10:43 AM
    #193
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    I have actually considered buying Bend Tech Pro
    https://www.roguefab.com/product/be...sXK0KQH05HyCMugwBrQwe7iI-wla8O2oaAj4uEALw_wcB
    It's $295. If I knew I was going to do a lot of bending, it might be worth the investment. You can design (and save plans) for everything from cross members and rock sliders, up to full roll cages with the Pro version.
    If I could put the bender to work it would pay for it's self pretty quickly. But if I'm just going to do a one off project... is it worth it? (Is where I'm at).
    When talking investment I'm not just talking the 300 bucks, I'd also have to learn to use the program. It's probably pretty simple, but I'm probably even simpler :rofl:
    realsystem[QUOTED] likes this.
  14. Feb 28, 2025 at 10:58 AM
    #194
    realsystem
    Stanislav
    SF Bay Area, CA
    And finally we arrived to your initial question: what will you gain by doing it by yourself? Let's just buy a fabricated cage for this type of cab and move forward. Or build it from scratch and make repeatable to make race truck later. My opinion: start from the blueprint and 3D, it's 2025, computer is your friend when you learn how to use it. BTW, I'm a software engineer and have 20+ years of professional experience with different systems. They are not related to car industry but the idea is always the same: make it right, make it simple. Even if you have paper cuts for your cage and scan it later - it will be huge for somebody else or yourself in future. That's progress.
  15. Feb 28, 2025 at 11:01 AM
    #195
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    What will I gain?
    Practice
    Being able to say "I did that"
    And probably about 5 grand over having someone else do it for me :rofl:
    And... No one works on my trucks but me.
    But I do see your points.
  16. Feb 28, 2025 at 11:05 AM
    #196
    realsystem
    Stanislav
    SF Bay Area, CA
    I think the proper way for this is long term planning. Are you planning to race in future? Are you planning to fabricate stuff in future? Are you willing to share your intellectual property with others? For free or sell?
  17. Feb 28, 2025 at 11:12 AM
    #197
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Everything is a prototype at this point. The truck was a prototype leading to another project. This is that other project. There is a certain degree of repeatability that could definately help in a future project... BUT... this roll cage, for example. Will get done, and there will undoubtedly be a BUNCH of changes I will identify as we use the truck.
    Being that I'm not a cage fabricator, I'm sure there will be things here and there that I'll wish I had done slightly different. So, I'm not sure how much of it will necessarily be replicated in "version 2" in another truck. And, I doubt I'll ever build another 3rd Gen 4 Runner anyway.
  18. Feb 28, 2025 at 11:31 AM
    #198
    Kwikvette
    Fresno County
    4 run, 2 don't
  19. Feb 28, 2025 at 11:33 AM
    #199
    essjay
    essjay Part-Time Lurker
    Concord, CA
    2011 Tacoma SR5 (V6/AC/4WD)
    The C in CAD.
    edit: Or maybe this is C++?
  20. Feb 28, 2025 at 11:51 AM
    #200
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    I prefer to use these. You can get cleaner cuts.
