My lift plan and price...
Discussion in 'Suspension' started by FloridaFeMan, Aug 29, 2009.
  1. Aug 29, 2009 at 9:01 AM
    FloridaFeMan
    FloridaFeMan [OP] Well-Known Member
    Southwest Florida
    '10 FJ Cruiser 4x4, '09 Tacoma TRD DC Sport
    I think I have finally decided on which kit I am going to use to lift my Tacoma DC TRD Sport.
    1) OME kit as featured on Toytec website for $699
    2) Light Racing Upper Control Arms $449
    3) Installation price $439 including alignment
    I think I am going to go with the Nitto Terra Grappler 265x70x17 and stick with my stock wheels for now. This will cost me $160/tire mounted and balanced.
    My overall budget was $2000 but I am a little bit over but I think I will be much happier than if I were to go with the more economical spacer lift such as the Readylift or the Daystar lift.
    Any thoughts/comments/further recommendations?
  2. Aug 29, 2009 at 9:17 AM
    IndigoTaco
    IndigoTaco Well-Known Member
    07 Access Cab Sport 4x4
    If you're gonna go with tires that fit on stock, why not just go with 5100's all around? Much cheaper, and will still give you a small amount of lift.
  3. Aug 29, 2009 at 9:27 AM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    good call on avoiding the spacer lifts. your prob gonna want a bigger tire cause your lifting the truck and thats the stock size. you'll regret not going bigger. 285/70/17 will fit.
    as for the OME kit. i have heard from alot of people that after a while their coils start to sag and ride quality declines. check these guys out. Best Coilover out there and they are a steal at this price...and w/ your aftermarket UCA's you will be able to get more travel using a CO as opposed to a lift coil.
    http://www.outlawoffroadstore.com/22243/72/223/3476/2006_TOYOTA_TACOMA_4.0_V6_GAS.html
    http://www.outlawoffroadstore.com/22243/72/223/0/2006_TOYOTA_TACOMA_4.0_V6_GAS.html
  4. Aug 29, 2009 at 10:38 AM
    FloridaFeMan
    Southwest Florida
    My original plan was to go with the 5100 Bili's and an AAL but I read several people on here that hated the ride afterwards that I started second guessing myself. Seems like the more I research, the more confused I BECOME. My goal is to improve upon the factory ride and give the truck a more aggressive look. I won't be off-roading at all.
  5. Aug 29, 2009 at 10:49 AM
    r12rex
    r12rex Well-Known Member
    Cleared headlights, Black emblems, Painted black valence on front bumper, 2.5" 5100 Billys front, 1.5" AAL rear, Satin black TRD O/F wheels with 265/75 16 Definity M/T, Spidertrax spacers
    OME makes an awesome set-up. I run them on the truck. The sagging issue the above poster stated was an issue a long time ago. They have since fixed the problem.
    I would say that your set-up is great and overall complete. The only thing is I would install them myself. Very easy to do and save yourself the $400. I would go with 285/70 tires. They fill the wheel well nicely, but the 265 are not too bad either.
    Kind Regards,
  6. Aug 29, 2009 at 10:53 AM
    rick
    rick `
    if you want to install it yourself. hit me up. i'll help ya.
  7. Aug 31, 2009 at 9:43 AM
    8th sin
    8th sin Swollen Member
    Tampa, FL
    2015 DCLB 4x4 Sport
    Llumar CTX Tint, Grillcraft MX Upper, Pro Comp Rockwell 5034 17x8.5, Nitto Terra Grappler G2 LT285/70/17, Icon Stage III
    If you're 2WD, I would consider camburg or total chaos lift spindles. Once you consider the cost of aftermarket UCA's (which you don't need with spindles) they are more often than not cheaper. If you're 4x4 then they won't work.
    I would look at getting someone with experience to help you install DIY. It is not that difficult, and will save you several hundred dollars.
