my new taco came with 245/65/16
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Thomas Lee, Nov 7, 2010.
  1. Nov 7, 2010 at 4:06 PM
    Thomas Lee
    Thomas Lee [OP] Shogun
    work truck
    3" lift
    Isnt that a 29" tire
    It was 29" when I measured it but lots of the tread is gone
    just bought 31/10.5R15s. What is the in hard language (example) 245/75/16
    need to know so I can enter it in the tire thingy that tells you the difference in mpg, performance, size, etc
  2. Nov 7, 2010 at 4:14 PM
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    click on the Mods & Tutorials link at the top of the page
    then click on Tire size calculator
    but yes, that is considered a 29 inch tire
  3. Nov 7, 2010 at 4:18 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners.
    Thats what mine came with.
  4. Nov 7, 2010 at 4:21 PM
    Thomas Lee
    work truck
    3" lift
    just bought 31/10.5R15s what size is that in hard language, (example) 265/75/16
    need to know so I can enter it in on the tire thingy that tells you the difference in mpg, performance, height, etc
  5. Nov 7, 2010 at 4:23 PM
    skistoy
    Western New York
    mine are 265/75R16 on the stock rims.
    no problems.
  6. Nov 7, 2010 at 4:27 PM
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    Pacific Northwest
    2018 OR DCSB 4x4
    Are you sure a 15 inch wheel will clear the calipers?
  7. Nov 7, 2010 at 4:28 PM
    skistoy
    Western New York
    15 inch ????
    good catch
  8. Nov 7, 2010 at 5:14 PM
    Thomas Lee
    work truck
    3" lift
    its the stock wheel. Its a 16" but the tire is 15 so it can go deeper into the wheel
    thats why I want to know the hard language for defining this tire
  9. Nov 7, 2010 at 5:16 PM
    Ted Nugent
    Ted Nugent Well-Known Member
    Tim
    NEPA
    2010 Reg cab 4x4
    What are you talking about? The 15s arent gonna fit.
  10. Nov 7, 2010 at 5:17 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Uhhhhhhh, you're either confused, or you're throwing us off track with too many typos.
    But NO 15" tire WILL EVER fit on your stock 16" rim.
    15" or 16" is the diameter of the rim, and the INNER diameter of the tire must match or the tire won't fit on the rim.
  11. Nov 7, 2010 at 5:18 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
  12. Nov 7, 2010 at 5:24 PM
    Thomas Lee
    work truck
    3" lift
    WHEN I GO TO THE SPECS FOR THE TIRE THE 31 IS THE TIRE HEIGHT THE 10.5 IS THE WIDTH AND THE 15 IS THE INSIDE OF THE CIRCLE
    WHEN I LOOK UP WHAT SIZE RIM IT FITS ON IT SAIS 16"
    IF YOUR RIM IS 16" TALL AND YOUR TIRE IS 16" ON THE INSIDE OF THE CIRCLE THEN THE TIRE IS TOO BIG FOR THE RIM
    FIRESTONE SPELLS THEIR TIRES OUT IN PLAIN ENGLISH GIVING THE EXACT MEASUREMENTS OF THE TIRE WHERE AS EVERYONE ELSE SAYS 265/75/16
    THE 16 IN THAT CASE WOULD NOT BE THE INSIDE CIRCLE OF THE TIRE BUT THE RIM THAT IT FITS ON
    HAVING SAID THAT THE ACTUAL MEASUREMENT OF THAT CIRCLE WOULD BE 15"
    BY THE WAY CAN SOMEONE ANSWER MY QUESTION
  13. Nov 7, 2010 at 5:25 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    285/70/18
    *The first number is the nominal width of the tire in mm, approximately 285 mm at the widest point.
    *The second number is indicates that the height of the sidewall of the tire is 70% of the width
    *The third number is the rim size.
  14. Nov 7, 2010 at 5:26 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    xxx/xx/16 will only fit on a 16" rim. they wont fit on a 15" rim. dont think inside outside just think of whatever the last number is. you are being way to confusing
  15. Nov 7, 2010 at 5:28 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
  16. Nov 7, 2010 at 5:30 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    Your tire is somewhere near a 270/75/15, 265/80/15. This is a rough estimate. The rims size is wrong for your truck!
  17. Nov 7, 2010 at 5:30 PM
    Thomas Lee
    work truck
    3" lift
  18. Nov 7, 2010 at 5:33 PM
    toyo freak
    toyo freak Another Toyota Enthusiast
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    5100s at 2.5, Wheeler 3 leaf progressive AAL, Weathertech liners, yellow wire mod, toyota OEM bed mat, cup holder mod, afe pro dry s air filter, UWS low pro toolbox, Escort radar detector
    Please post pic of this odd tire size.....
  19. Nov 7, 2010 at 5:34 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    Where on that link should I be reading? Because I am really interested in learning how a 15" tire will fit on a 16" rim.
  20. Nov 7, 2010 at 5:35 PM
    08pretaco
    Oliver
    az
    You are being very ignorant. A 15" rim will not fit a 6 lug Tacoma and a tire that ends in /15 will not fit onto a 16" rim. Everyones mentioned this numerous time as well as given you great feedback thus far!
    ^x2
